03-01-2013, 10:58 PM
#16246 | |
Oddometer: 75
03-01-2013, 11:04 PM
#16247 |
Oddometer: 476
I don't know, but i would be leary of the china aftermarket ones. I've seen at least 3 different ones on ebay ect,,, the thought crossed my mind....
Best probably to go oem.
03-01-2013, 11:05 PM
#16248 |
Oddometer: 75
03-01-2013, 11:15 PM
#16249 |
Oddometer: 75
03-01-2013, 11:22 PM
#16250 |
Pumpkinhead ;-)
Oddometer: 455
Before I'd accuse the CDI I'd have meticulously checked all connections, plugs, earth's etc, up to the last seemingly unimportant bit. Clean to 'new', use contact spray for this plus some grease before reconnecting, and know a bit of paint or a sque conncetor can throw the spark off. Obviously a new unit won't help here then, just my 2 c's..
03-01-2013, 11:23 PM
#16251 | |
Oddometer: 75
How do you test the stator, and pulse receiver? |
03-01-2013, 11:33 PM
#16252 |
Oddometer: 476
Nothing worse than chasing electrical gremlins by replacing parts. Been there done that, no fun and a waste of money/time.
03-01-2013, 11:36 PM
#16253 |
Oddometer: 75
03-02-2013, 12:04 AM
#16254 |
Exhiled
Oddometer: 187
I prefer the Factory Honda Service manual. There are a couple areas that it isn't clear in the OEM manual for an engine build but nothing major. I've built the engine twice in the last year using the OEM manual and haven't had any trouble.
Sent from my DROIDX using Tapatalk 2 |
03-02-2013, 12:16 AM
#16255 | |
Oddometer: 75
03-02-2013, 06:39 AM
#16256 |
Wannabe.
Oddometer: 739
Quick question-- I obviously changed the coolant yesterday when I put in the new thermostat. I haven't started the engine since. Will coolant have transferred over to both radiators even without the engine starting, or can I get away with not draining the coolant if I'm taking the thermostat out again?
03-02-2013, 06:48 AM
#16257 |
Oddometer: 437
I've got an 87 XR600 out in the garage that does the same thing,I got sick of messing with it now its just an ornament.
09 Husaberg FE 570 07 Honda XR 650R 11 BMW R1200GSA |
03-02-2013, 07:17 AM
#16258 | |
aka Birdkilla
Oddometer: 2,353
Cpt. Ron Sack-O-Tomato, CA '05.5 950 Adventure S "Bad Mutha F@&ker" '04 R1150RTP "cop motor, cop suspension.." '00 XR650R Dual Sport "Lil' Mule" '75 RL250 '01 TTR90 '01 PW50 Conti TKC80 tire swing "I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P. "Without the possibility of death, adventure is not possible"--Reinhold Messner |
03-02-2013, 07:40 AM
#16259 | |
Oddometer: 78
03-02-2013, 07:43 AM
#16260 | |
Oddometer: 1,382
Yup, there are hoses connecting the rads so it fills both. The stat is the device the stops / redirects flow of the coolant once started, but otherwise both rads fill. Keep in mind you should try to burb the engine/coolant. Try to get all the air out and double check once you put it through a heat cycle that that coolant is still full (obviously only opening the cap once cooled down).
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
