Old 03-05-2013, 06:56 AM   #16321
Kiko
Kiko's Avatar
Oddometer: 1,753
That's not the right spacer. Mine has a lip on it that slides into the plastic piece.
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 03-05-2013, 07:02 AM   #16322
galland1
galland1's Avatar
Oddometer: 112
There is no nut. Sounds like the seal is shot. I have this setup. Check the bearings. My seal is a proper fit to the small end of the bush.
Sent from my Galaxy Nexus using Tapatalk 2
galland1 is offline   Reply With Quote
Old 03-05-2013, 07:46 AM   #16323
galland1
galland1's Avatar
Oddometer: 112
Wondering if the bushing was installed backwards at one time.
Old 03-05-2013, 09:09 AM   #16324
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,235
Originally Posted by Capt. Egregious View Post
I also have a BD LED light bar, I have been happy with it operation. I installed the light bar before the 24 hour race a few months ago so time will tell how well its made. The cost on the LED bar is 10X the HID mod.
The cost may be high, but it is offset by the durability and longevity. Your bike will be long dead and rusting away before that light will give up. And even if it does kick the bucket, I'm sure BD will get it sorted out. They're not a power hungry money thirsty mega company, they're down to earth and support their products fully
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Old 03-05-2013, 09:50 AM   #16325
Bench Racer
Oddometer: 82
Originally Posted by Shibby! View Post
Is that the right XR650R hub and spacer?
I'm not sure if it's right or not. The wheel came from JCR. Previous owner got it from them while in Baja.
I knew something was wrong. It needs to be a sealed fit. The seal looks fine. No wear points.
Wonderful
Bench Racer is offline   Reply With Quote
Old 03-05-2013, 10:22 AM   #16326
Bench Racer
Oddometer: 82
Eek
I cleaned up the parts to show what's really going on.
Front collars.
The problem collar
Collar with axle
The collar looks like it's been worn but how is this possible IF the seal doesn't even touch it?
Old 03-05-2013, 10:44 AM   #16327
Kiko
Kiko's Avatar
Oddometer: 1,753
That collar does not resemble the part I recv'd from XRsOnly last year. Xr's customer service is less than spectacular, but you could ask them if they would just sell you the right spacer that you need. Worth a try.
Old 03-05-2013, 10:47 AM   #16328
mitchn06
mitchn06's Avatar
Oddometer: 553
here is the XRs LINK looks like the right unit. is it possible the bearing isn't seated all the way in? maybe
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-05-2013, 10:50 AM   #16329
galland1
galland1's Avatar
Oddometer: 112
My spacer looks like yours. Somehow the taper heading towards the big end came into contact with the seal and hogged it out. You can see the wear on it.
Old 03-05-2013, 10:51 AM   #16330
galland1
galland1's Avatar
Oddometer: 112
Maybe the seal walked out a bit at one time and the PO tapped it back in?
Old 03-05-2013, 11:39 AM   #16331
crypto666
Oddometer: 1,257
Here is a couple beam shots of questionable quality. The first is a 100w Halogen in a Piaa 520 series housing and wide angle lens. The second shot is with the HID in a PIAA 520 pencil beam lens. Its hard to tell distance, but signs are visible well over a mile away.
Originally Posted by 1 lunger View Post
I had a cheap set up on my bike for a few night rides. it's a rigid industries 1900 lumens led flood. as you can see, it's much brighter than the OEM high beam below it. OEM led. Cost was $50
crypto666 is offline   Reply With Quote
Old 03-05-2013, 12:07 PM   #16332
cognugget
cognugget's Avatar
Oddometer: 243
Yes, the bike can eat singletrack
http://www.youtube.com/watch?v=HIPdb...Rg9udw&index=2
cognugget is offline   Reply With Quote
Old 03-05-2013, 12:31 PM   #16333
Bench Racer
Oddometer: 82
Dang it. Looks like I'll have to buy a new spacer. Thanks for the help.
Here's my PIG. Fresh new powder coated rims.
Old 03-05-2013, 01:57 PM   #16334
mitchn06
mitchn06's Avatar
Oddometer: 553
Looks Good!
Old 03-05-2013, 02:20 PM   #16335
mdlak
Oddometer: 201
Looks nice Bench Racer!
mdlak is offline   Reply With Quote
Times are GMT -7.   It's 12:14 AM.
