Old 03-08-2013, 07:40 PM   #16396
XR650Gnar
Oddometer: 14
I assume that means the cover itself as well right?
XR650Gnar is offline   Reply With Quote
Old 03-08-2013, 07:46 PM   #16397
slickwill
Exhiled
Oddometer: 209
Got any pics? I've assembled my engine twice recently following the book exactly and didn't use any red loctite but I may not have had to remove what you are talking about. I used Hondabond 4 for the cases and valve cover and really liked working with it. I used a small paint brush from my kids watercolors to apply it and it worked great.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 03-08-2013, 07:56 PM   #16398
slickwill
Exhiled
Oddometer: 209
Originally Posted by mitchn06 View Post
any recommendations on C-rods?
If you never had massive amounts of shavings your big end may be intact. I went with a Falicon rod but I had the entire Falicon "Supercrank" mod done at the same time which was around $850 with the new rod. My engine is really far from stock and I had already blown one stock crank/rod combo so I look at it as a preemptive strike.
Old 03-09-2013, 09:13 AM   #16399
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 169
yes the aluminum will wear faster than the steel parts you are measuring in the picture above.
I can see that your pressure side gear rotor has had quite a bit of particulate matter go through it and that will wear the case, so a new gear rotor can be sloppy in a old case.
Honda also recommends replacing the oil pump with the case 1/2 as a set.
Also look at the filter cover for wear.
FlyGuy is offline   Reply With Quote
Old 03-09-2013, 03:51 PM   #16400
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,616
what is this supercrank mod you speak of?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 03-09-2013, 05:03 PM   #16401
AJ..
AJ..'s Avatar
Oddometer: 1,617
Well after a long sabbatical to SE Asia Im back, just before I left last June I blew up the lower rod bearing and crankcase at 70mph on the freeway, thank god I was quick on the clutch cause she locked up tighter than a nuns asshole. .. Now its rebuild time.
Got a new (used in great shape) case and have all the bearings pulled out, steam cleaned and sparkling, just sent out the crank for a press and balance with new rod, re nikasil the cylinder, hard face weld the rockers, and a valve job replacing everything. Also throwing in a hot cams stage 1 and cutting out the rear side panel so she'll breathe better
One question Ive got after cleaning and inspecting the oil pump today is should I be worried about the pump if both sides are at their service limits? I plan on replacing the parts after the build up but am I going to see any significant loss in pressure for cam break in, some short runs, etc, the service limit is .008 and its a real snug fit?
hey man,on gour SE Asia trip,did you happened to dropby Singapore for a.set of tyres?
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 03-09-2013, 05:03 PM   #16402
cognugget
cognugget's Avatar
Oddometer: 243
street riding
http://www.youtube.com/watch?v=ICjP9...Rg9udw&index=1
cognugget is offline   Reply With Quote
Old 03-09-2013, 06:33 PM   #16403
mitchn06
mitchn06's Avatar
Oddometer: 542
unviewable
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-09-2013, 07:08 PM   #16404
cognugget
cognugget's Avatar
Oddometer: 243
unviewable
Same here.
Plated XR650R
Old 03-09-2013, 07:08 PM   #16405
jimmyx
jimmyx's Avatar
Oddometer: 167
Thumb Cool vid-not an X-r, still cool!
http://vimeo.com/59361059 F-ing breathtaking landscape
"I'd rather have a bottle in front of me than a frontal lobotomy"
Dorothy Parker
jimmyx screwed with this post 03-09-2013 at 07:27 PM
jimmyx is offline   Reply With Quote
Old 03-09-2013, 10:12 PM   #16406
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
Originally Posted by cognugget View Post
Hey, I recognize those roads. XR's on the the street are a hoot.
Capt. Egregious is offline   Reply With Quote
Old 03-09-2013, 10:24 PM   #16407
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
Anyone have the parts list for when the stock hand guards are removed. it is different bolts and bushings. I can't find it to save my life.
I remember seeing it somewhere....
Jayrod1318 is offline   Reply With Quote
Old 03-10-2013, 04:47 PM   #16408
medisyn
Oddometer: 149
Sorry guys I didnt make my last post to clear. What threadlocker or sealant should I use on these guys? http://i.imgur.com/s0vyo5m.jpg
I know the one all the way to the right had red threadlocker on it. The others I am not too sure of. The sealant and/or threadlocker was sort of dark grey colored. I want to use the right stuff so hopefully I never have to pull off this damn crankcase cover for a few years.
medisyn is offline   Reply With Quote
Old 03-10-2013, 05:18 PM   #16409
cognugget
cognugget's Avatar
Oddometer: 243
Got beat up today. Rode ~18 miles to the trails, met up with a couple woods racer buddies. We rode 30 grueling miles of very technical singletrack, then rode the ~18 miles home. I have over 400 miles on the bike since I bought it a month ago. I saw a big group of dual sport riders in the parking lot, they thought I was nuts riding with the ktm 300 and crf in the tight singletrack
The covers were almost perfect when I got them, giving them mutch needed wear. My boots do not have a metal tip either
[IMG]http://www.dirtbikeaddicts.com/attachments/p1010073-jpg.13626/[/IMG
I managed to detach 2 turn signals today
Plated XR650R
Old 03-10-2013, 05:31 PM   #16410
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,235
any recommendations on C-rods? i'm basically stock except for normal uncork, hotcams S1, and TM40. i don't think i will be able to afford a $400 crank. what are some other options that are decent or OEM like?
Figure $150 for the kit, roughly another $90 for the labor rebuilding the crank plus shipping, about $300 total plus brgs, seals and gaskets, I'd est about $450 total for going into it and fixing the crank if you split the cases yourself.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
