Old 03-09-2013, 07:33 PM   #16411
mitchn06
mitchn06's Avatar
Oddometer: 548
unviewable
2000 Honda XR650R (Under the Knife) LINK
mitchn06 is offline   Reply With Quote
Old 03-09-2013, 08:08 PM   #16412
cognugget
cognugget's Avatar
Oddometer: 243
Originally Posted by mitchn06 View Post
unviewable
Same here.
Plated XR650R
cognugget is offline   Reply With Quote
Old 03-09-2013, 08:08 PM   #16413
jimmyx
jimmyx's Avatar
Oddometer: 165
Thumb Cool vid-not an X-r, still cool!
http://vimeo.com/59361059 F-ing breathtaking landscape
"I'd rather have a bottle in front of me than a frontal lobotomy"
Dorothy Parker
jimmyx screwed with this post 03-09-2013 at 08:27 PM
jimmyx is offline   Reply With Quote
Old 03-09-2013, 11:12 PM   #16414
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 367
Originally Posted by cognugget View Post
Hey, I recognize those roads. XR's on the the street are a hoot.
Capt. Egregious is offline   Reply With Quote
Old 03-09-2013, 11:24 PM   #16415
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,607
Anyone have the parts list for when the stock hand guards are removed. it is different bolts and bushings. I can't find it to save my life.
I remember seeing it somewhere....
Jayrod1318 is offline   Reply With Quote
Old 03-10-2013, 05:47 PM   #16416
medisyn
Oddometer: 149
Sorry guys I didnt make my last post to clear. What threadlocker or sealant should I use on these guys? http://i.imgur.com/s0vyo5m.jpg
I know the one all the way to the right had red threadlocker on it. The others I am not too sure of. The sealant and/or threadlocker was sort of dark grey colored. I want to use the right stuff so hopefully I never have to pull off this damn crankcase cover for a few years.
medisyn is offline   Reply With Quote
Old 03-10-2013, 06:18 PM   #16417
cognugget
cognugget's Avatar
Oddometer: 243
Got beat up today. Rode ~18 miles to the trails, met up with a couple woods racer buddies. We rode 30 grueling miles of very technical singletrack, then rode the ~18 miles home. I have over 400 miles on the bike since I bought it a month ago. I saw a big group of dual sport riders in the parking lot, they thought I was nuts riding with the ktm 300 and crf in the tight singletrack
The covers were almost perfect when I got them, giving them mutch needed wear. My boots do not have a metal tip either
[IMG]http://www.dirtbikeaddicts.com/attachments/p1010073-jpg.13626/[/IMG
I managed to detach 2 turn signals today
Plated XR650R
Old 03-10-2013, 06:31 PM   #16418
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,977
any recommendations on C-rods? i'm basically stock except for normal uncork, hotcams S1, and TM40. i don't think i will be able to afford a $400 crank. what are some other options that are decent or OEM like?
Figure $150 for the kit, roughly another $90 for the labor rebuilding the crank plus shipping, about $300 total plus brgs, seals and gaskets, I'd est about $450 total for going into it and fixing the crank if you split the cases yourself.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-10-2013, 06:40 PM   #16419
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,977
Originally Posted by XR650Gnar View Post
Well after a long sabbatical to SE Asia Im back, just before I left last June I blew up the lower rod bearing and crankcase at 70mph on the freeway, thank god I was quick on the clutch cause she locked up tighter than a nuns asshole. .. Now its rebuild time.
Got a new (used in great shape) case and have all the bearings pulled out, steam cleaned and sparkling, just sent out the crank for a press and balance with new rod, re nikasil the cylinder, hard face weld the rockers, and a valve job replacing everything. Also throwing in a hot cams stage 1 and cutting out the rear side panel so she'll breathe better
One question Ive got after cleaning and inspecting the oil pump today is should I be worried about the pump if both sides are at their service limits? I plan on replacing the parts after the build up but am I going to see any significant loss in pressure for cam break in, some short runs, etc, the service limit is .008 and its a real snug fit?
I'd replace the pump, that spec your measuring directly relates to supply oil volume and subsequently the motor's oil pressure, any wear like you see on the sides of the op rotor will diminish it's output. It should look polished on the surface. You're spending allot of $$, if it was me I wouldn't put a marginal pump back in a fresh motor.
Chris
Old 03-10-2013, 06:52 PM   #16420
medisyn
Oddometer: 149
Yeah, as somebody that had to buy all the oil pump bits, its like 50 dollars to replace every bit on the parts fiche.
Old 03-10-2013, 08:28 PM   #16421
mitchn06
mitchn06's Avatar
Oddometer: 548
Thanks Chris, i was afraid the crank issue would probably set me back another $300+ oh well i guess. now i gotta find something to sell to scrape up some cash!!
Old 03-10-2013, 09:21 PM   #16422
bamfslap
Oddometer: 205
They did? Screw that noise! The BRP is awesome on the singletrack if you're in shape and got some muscle. It tractors up over anything and never stalls in the lowest RPMs. And shifting? Optional.
bamfslap is offline   Reply With Quote
Old 03-10-2013, 09:26 PM   #16423
cognugget
cognugget's Avatar
Oddometer: 243
It is not ideal, but I'm also not a huge guy. The thing is amazing at tractoring! They were just jealous that their wideass bmw1200's couldn't fit down the entrance to the trails hahaha.
Plated XR650R
Old 03-10-2013, 09:36 PM   #16424
bamfslap
Oddometer: 205
I'm not huge either, they say the easiest way to make your bike lighter is to lose weight so maybe that's why it doesn't feel that heavy to me hehe.
Old 03-10-2013, 09:46 PM   #16425
cognugget
cognugget's Avatar
Oddometer: 243
yeah, not going to happen... I'm 165lbs.... :) my key is to not load the bike down with crap you don't really need.
Plated XR650R
Times are GMT -7.   It's 12:07 PM.
