Old 03-16-2013, 10:02 PM   #16486
dohcfox
meh
dohcfox's Avatar
Oddometer: 145
With the Acerbis, I use a 1/4" long extension with wobbly end and a 6 point socket. The tank goes on really easy that way! If your socket wobbles too much, making it difficult to get the bolt in to the hole, wrap some electrician's tape around the end of the extension and the beginning of the socket. That'll make it easier to 'aim' the bolt into its hole. Good luck!
Originally Posted by BigToad View Post
I have big hands so mounting the 6.3 Acerbis is a pain in the ass! Is the IMS 7 easier to take on and off? Anyone with experience mounting both?
Ser decente no cuesta un culo y queda uno putamente bien!
dohcfox is offline   Reply With Quote
Old 03-16-2013, 10:18 PM   #16487
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,296
And having the bolts with the flanged heads makes it easier to "push" the bolt with the socket into the frame holes as you apply torque.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 03-17-2013, 12:02 AM   #16488
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,416
ok so i searched this thread .....cant find it ...some1 did a mod to there petcock and added some tube to the filter and then added weight to the other end and place the heavy end in the front low part of a acbis tank ...i cant remember if he was using a pumper carb or the stocker
any1 remember this or know where it is ?
Sean-0 is online now   Reply With Quote
Old 03-17-2013, 08:15 AM   #16489
hontri
Global Bummer!
hontri's Avatar
Oddometer: 303
Here :Scroll down http://advrider.com/forums/showthrea...09774&page=913
hontri is offline   Reply With Quote
Old 03-18-2013, 12:14 AM   #16490
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,416
Thanks Hontri ... i must have missed that page damm it ......
Old 03-18-2013, 05:44 AM   #16491
ADVSearcher
ADVSearcher's Avatar
Oddometer: 192
Way to many forum pages without a BRP pic ...
Spring on it's way, the enduro studs went off yesterday soon the muddier season starts
ADVSearcher is online now   Reply With Quote
Old 03-18-2013, 08:03 AM   #16492
crypto666
Oddometer: 1,276
Originally Posted by mitchn06 View Post
what parts on the oil pump should be replaced when rebuilding it, both inner and outer parts of both rotors along with the oil seal? or more?
I would think that if you are replacing the oil pump, you should be replacing everything else also.
BTW, there are testing ports and a way to test the oil pressure.
crypto666 is offline   Reply With Quote
Old 03-18-2013, 08:49 AM   #16493
mitchn06
mitchn06's Avatar
Oddometer: 547
what exactly do you mean by "everything else also?" is there a procedure in the FSM for testing oil pressure?? i guess i may have missed it. as far as i know, there is nothing wrong with teh pump, its just 13 years old and i lack of oil is what started this mess, i don't want to rebuild this bike, then burn it up right away.
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-18-2013, 12:27 PM   #16494
crypto666
Oddometer: 1,276
Oh, I had forgot you already did replace everything else already.
Actually, I went home last week and checked my pump since it is one of the few original parts in my motor, and it still has lots of life in it.
I know I saw a test procedure somewhere, it used the ports where the external oil lines tie in to the case. Seems like it required two gauges. If it isn't in the xrr manual, it may be i honda's general service manual. I can look tonight when I go home.
I am not sure if the cover (pump housing) actaully has any wear points on it, and I think all the wear would be between the rotors and the part they interface with. If not, its a cheap fix/insurance. Otherwise the cover adds $170 to the job.
Old 03-18-2013, 08:56 PM   #16495
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
As one side of the pump housing it's a wear point, depending on how much crap went through the pump it may be grooved. At $170 I'd def explore some cheaper alternatives if that the case, a good machinist might be able to surface it (I cant remember if it has an oring groove in it)
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-18-2013, 10:24 PM   #16496
KonaTheHusky
KonaTheHusky's Avatar
Oddometer: 70
Originally Posted by PineyMountainRacing View Post
I believe a 120/80-18 is an 18" tire (fits an 18" rim) that is 120 mm (about 4.7 inches) wide. The 80 is the aspect ratio which means the height (how tall it is) = 80% of 120 mm = 96 mm (about 3.8 inches).
The 110 / 100 is 110 mm wide (about 4.3 inches) and 100 % of 110 tall = 110 mm tall ( about 4.3 inches ). So its 4.3 inches wide by 4.3 inches tall. So a xxx / 100 tire will be the same width as height. The 110/100 will actually be taller than the 120/80. 100% of 110 mm is bigger than 80% of 120 mm.
Some tires are just classified by 1 number, and that implies the aspect ratio is 100%. Like a 4.50 X 18; it's an 18 inch tire that is 4.5 inches wide and 4.5 inches tall.
I'm currently running a 140/80-18 on the rear, but its a Pirelli Scorpion, MT90 - more or a dual sport tire. I think the last knobby I ran was a 120/80. Pretty sure a 140/80 knobby would not have enough clearance, it would be too tight with the knobs. It's all kinda confusing until you start mounting lots of tires and see them side by side. Plus you gotta convert the metric to inches, unless you're on the other side of the pond.
I know I'm digging up an old piece of this thread, but how'd you like the Pirelli MT90s? Howd the 140/80 sizing in the back work out? I've read some really solid reviews, accompanied by some odd, very poor reviews on the MT90s. I'm gunna be taking my BRP on a long trip (1-3 months) that will start out as mostly hwy (75hwy/25offroad) then will likely transition to mostly offroad. I have some Maxxis Deserts on it now that I might just strap to the back for the first part of the trip until I need them. Looking for a recommendation on a good DS tire that handles well on wet pavement (rains are coming).
Thanks.
KonaTheHusky is offline   Reply With Quote
Old 03-18-2013, 10:43 PM   #16497
mdlak
Oddometer: 201
Chain recommendations
Starting to think about sprockets/chain for my XRR. Think I have it down to Sunstar steel 15/48 sprockets but not sure on the chain. Either DID or RK 520 o-ring seem to be the most popular. Any suggestions on exact chain and where to buy?
mdlak is offline   Reply With Quote
Old 03-19-2013, 03:51 AM   #16498
galland1
galland1's Avatar
Oddometer: 112
I use the RK XSO 110L OEMCYCLE $68 cheap but good.
galland1 is offline   Reply With Quote
Old 03-19-2013, 08:48 AM   #16499
cognugget
cognugget's Avatar
Oddometer: 243
I was just on a quick dual sport ride between Port Orchard and Belfair, and found a huge network of trails off the main road. The one thing that kept crossing my mind was that I'm probably going to run right into a meth lab
Plated XR650R
cognugget is offline   Reply With Quote
Old 03-19-2013, 09:53 AM   #16500
crypto666
Oddometer: 1,276
After breaking a chain and rebuilding the engine I use:
DID 520ZVM2 X-Ring 520x110
Do not use Primary Drive anything.
Times are GMT -7.   It's 04:18 AM.
