Old 03-23-2013, 10:36 PM   #16576
Dread Pendragon
throttle to the donk
Dread Pendragon's Avatar
Oddometer: 2,520
While I was riding this week my clutch lever suddenly became very hard to pull and would stick a moment after releasing. It turned out that the bottom of the clutch perch had cracked loose.
Now I need to decide if I should replace it with a stock clutch perch, or if I should try some fancy-dancy aftermarket perch. Has anyone replaced their stock clutch perch before?
"Never get excited in a rally, its a race, but its never a race at that exact moment" -Quinn Cody
Dread Pendragon is offline   Reply With Quote
Old 03-23-2013, 10:37 PM   #16577
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 818
I remember a lot of interest when I took this tank off the bike. Finally listing it in the classifieds.
Acerbis 6 gal
http://www.advrider.com/forums/showthread.php?t=873121
2000 XR250R - Tagged
1998 XR400R - To be tagged
2003 XR650R - Sold 2006 Ducati Monster -Sold
'Cause I like to party - Story of 2 XR650s conquering Florida
http://www.advrider.com/forums/showthread.php?t=754094
SpeedoJosh is offline   Reply With Quote
Old 03-23-2013, 11:33 PM   #16578
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
want to get a new front fender ? crf what yr model fits or looks the best .. i want black
any idea's
Sean-0 is offline   Reply With Quote
Old 03-23-2013, 11:36 PM   #16579
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 636
If you want real fancy, then the works Connection Perch range is pretty much as good as you get. Bearings in the lever pivot, nylon slip spacers to reduce risk of snapping in a crash and on the fly clutch adjustment dial. Just make sure you get the right one that has the decomp lever integrated. XRs only has the correct one for the XRR.
Hope this helps!
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 03-24-2013, 07:09 PM   #16580
mitchn06
mitchn06's Avatar
Oddometer: 551
it pains me to see the 650r thread buried 3 pages back so i'll post, here is a current picture of my bike being rebuilt and cleaned up!
chain wore into swing arm
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-24-2013, 09:42 PM   #16581
mitchn06
mitchn06's Avatar
Oddometer: 551
question for anybody that has had their swingarm off: when i pulled the swingarm bolt out, the swingarm was free to move about, i was under the impression that the "special tool" was required to remove the special castle bolts what are some thoughts on this??
Old 03-24-2013, 09:54 PM   #16582
bamfslap
Oddometer: 205
You got the swing arm bolt off or need the tools? You can make your own tools with some sockets and a grinder/dremmel.
http://www.xr650r.us/preload/
Easy as pie.
bamfslap is offline   Reply With Quote
Old 03-24-2013, 10:45 PM   #16583
atravlr
atravlr's Avatar
Oddometer: 202
Bike lift?
Michn06
I Like your garage set up, any more pics of your bike work stand?
atravlr is offline   Reply With Quote
Old 03-25-2013, 05:47 AM   #16584
slickwill
Exhiled
Oddometer: 209
It will come out without the special tools. You need them to put it alll back together correctly.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 03-25-2013, 05:50 AM   #16585
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Originally Posted by atravlr View Post
Michn06
+1
Also, looking at your chain's eating marks in the swinger, you're not related to oztrayan Sean-O aren't you?
Pulling the mickey here
BuRPsa is offline   Reply With Quote
Old 03-25-2013, 06:13 AM   #16586
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,257
The internal castle nut holds the swing arm, the external castle nut locks the internal one. This should hold the swingarm in place without the bolt being inserted.
This is my swingarm, looks similar to both yours and Sean-O's. They are easily repaired.
poppy is offline   Reply With Quote
Old 03-25-2013, 07:33 AM   #16587
mattc
mattc's Avatar
Oddometer: 432
In case anyone is looking into getting into some SM wheels, here:
http://www.advrider.com/forums/showthread.php?t=873324
Thanks.
mattc is offline   Reply With Quote
Old 03-25-2013, 08:28 AM   #16588
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Guys,
got a Q: anyone knows of or has SW for drawing wiring diagrams?
Free intuitive stuff if at all possible please, and the use of colours would help a lot. I'm only looking for a picture, not simulations or why.
Anyone?
Old 03-25-2013, 10:29 AM   #16589
mitchn06
mitchn06's Avatar
Oddometer: 551
Easy as pie.
The swingarm bolt came out, and the swingarm dropped down, i was expecting to have to back out the castle bolts with the homemade tools.
Michn06
Thank you, spent many hours over at Garage Journal gathering ideas and ambition. I do not have any more pics, but if you would like, i can get some.
Originally Posted by BuRPsa View Post
+1
haha no, but we must have the same gearing and chain slack.
Old 03-25-2013, 10:31 AM   #16590
mitchn06
mitchn06's Avatar
Oddometer: 551
did you just have a shop fill in the grooves then grind it all down again? thanks
Times are GMT -7.   It's 07:17 PM.
