Old 03-31-2013, 12:12 PM   #16651
1bigrn
Oddometer: 200
warp 9 radiators
Originally Posted by sintax View Post
those look like the same ones that are all over ebay.
I know there are a few diff guys running them. They sure are priced well. I'm currently debating picking up a set vs fluidyne
Most of the reviews about the fleabay ones are positive. Most negatives are the holes don't line up. I would hope Warp took care of this issue if they put their name on it!
1bigrn is offline   Reply With Quote
Old 03-31-2013, 04:36 PM   #16652
mitchn06
mitchn06's Avatar
Oddometer: 541
i think you should do it, be OUR Big Red Guinea Pig
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 03-31-2013, 04:50 PM   #16653
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,314
Originally Posted by TJE View Post
Hi Lads! I just installed a set of new clutch plates (metal + friction plates, except for the inner smaller friction disc, which I had somehow missed) and now when I go hard, the engine revs, but the bike doesn't accelerate. Any idea why the clutch is slipping now? Is this normal until it's worn in or something? I've only gone about 20km on the new clutch so far.
Any help would be greatly appreciated, as I'm a bit new to this beast :)
Did you pull everything out of the clutch assembly , including the skinny clutch plate the judder spring and the flat spring seat?. How did you assemble it.
You should have had a flat spring seat 1st, then the judder spring. The judder spring is the one on an angle. It should be touching the spring seat on the bottom and leaning out toward you at the top, then you install the skinny clutch plate, then a steel. The steels have 2 different sides, one a flat square egde type, the other side will have like a radius edge. These can go either way, but install them all the same way. I soak my clutch plates in oil before installing.
So after you put the skinny plate in, then a steel, then a normal clutch plate, steel , clutch plate , steel etc etc. You should have 6 normal plates , 6 steels, 1 skinney plate ,1 judder spring and 1 flat spring seat.
poppy is offline   Reply With Quote
Old 04-01-2013, 07:08 AM   #16654
crypto666
Oddometer: 1,277
Originally Posted by babuja View Post
hy guys,
i've been using a electrical fan and installed a oil temperature dipstick.
Can you guys tell what's the normal oil temperature in your xr?
Tnks
150-210 f
crypto666 is offline   Reply With Quote
Old 04-01-2013, 07:09 AM   #16655
crypto666
Oddometer: 1,277
Originally Posted by jm-2008 View Post
Looks like some wear/clearance issues on the case saver.
Is this normal with a 15T as marked or are there other geometry/suspension considerations with the MOTARD wheels
My dirt only bike does the same. Its just slack.
Old 04-01-2013, 07:11 AM   #16656
babuja
babuja's Avatar
Oddometer: 353
Originally Posted by crypto666 View Post
150-210 f
Okapa, tnks...that's the temperature my bike is running ;)
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 04-01-2013, 09:32 AM   #16657
cognugget
cognugget's Avatar
Oddometer: 243
Plated XR650R
cognugget is offline   Reply With Quote
Old 04-01-2013, 11:49 AM   #16658
ADVSearcher
ADVSearcher's Avatar
Oddometer: 196
Ye, more Piggy pictures
From today, out and searching for the spring, snow free in the open but still winter in the woods ... Found enough gravel in order to satisfy myself for a couple days.
ADVSearcher is online now   Reply With Quote
Old 04-01-2013, 01:41 PM   #16659
tennessee thumper
now in Mt. View, AR
tennessee thumper's Avatar
Oddometer: 737
Go Pro fish eye!
Let's see some pigs catching air![/QUOTE]
The L can get it done too.
tennessee thumper is offline   Reply With Quote
Old 04-01-2013, 01:50 PM   #16660
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 944
All this air , are the suspensions that good, stock??
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 04-01-2013, 02:38 PM   #16661
tennessee thumper
now in Mt. View, AR
Oddometer: 737
No problems with mine for 2 years I've had it. It's not motocross good but it gets the job done.
Old 04-01-2013, 02:49 PM   #16662
babuja
babuja's Avatar
Oddometer: 353
Frame part...what is this?!
hy guys,
just found this image in the net. Could found what this part is? Some kind of oil filter?
Cheers guys
Babuja
________
KTM 950 ADV
Old 04-01-2013, 02:54 PM   #16663
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,421
oil return line ..what eva ya want to call it
Sean-0 is offline   Reply With Quote
Old 04-01-2013, 03:10 PM   #16664
babuja
babuja's Avatar
Oddometer: 353
ok ok..I get it. There's any kind of oil filter in there for retain particules?
Cheers guys
Babuja
________
KTM 950 ADV
Old 04-01-2013, 03:42 PM   #16665
ADVSearcher
Oddometer: 196
... any kind of oil filter in there for retain particules?
This is according to the book ...
By the way, what on earth have happened to your engine ?
Times are GMT -7.   It's 06:51 AM.
