Old 04-26-2013, 11:16 AM   #16921
cognugget
cognugget's Avatar
Oddometer: 243
Looking for a crf front fender for the 01 BRP. Honda has a had a few different colors of red on the crfs. an 02-03 (don't want, ugly fender) a 04 red, and a newer red, which matches best, which brand matches best?
Plated XR650R
cognugget is offline   Reply With Quote
Old 04-26-2013, 12:23 PM   #16922
crypto666
Oddometer: 1,383
I think my 250x is an 2006, and it don't match for shit.
crypto666 is offline   Reply With Quote
Old 04-26-2013, 01:23 PM   #16923
PeteN95
PeteN95's Avatar
Oddometer: 2,852
Originally Posted by jules083 View Post
Sounds expensive.
Seriously though, a rekluse isn't in the budget right now unfortunately.
Way cheaper than a 6sp gearbox, but I hear you. If you ever get a chance to try one, you should. It is the best thing I've ever bought for a bike. I haven't ridden a dirt bike without one for 10 years now.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 04-26-2013, 01:42 PM   #16924
broettge
broettge's Avatar
Oddometer: 18
Originally Posted by PeteN95 View Post
The Rekluse auto clutch is like the cheapest 6pd you can buy! Even with 15/45 gearing, I was riding tight, steep single track yesterday with no issues at all.
I put one in my BRP last summer too. I agree it is great for the single track, but I was thinking of taking it out because I don't really care for it on the highway.
It seams like i could get it adjust well for the slow tight stuff or for highway driving but had to keep adjusting depending on the riding. Then again, maybe I should replace the rest of my clutch and try the Rekluse with a fresh setup instead of an abused and worn clutch. Then maybe it will work well in all conditions without constant adjusting.
Brent
broettge is offline   Reply With Quote
Old 04-26-2013, 05:42 PM   #16925
tractor4play
Oddometer: 112
axle
Originally Posted by Adamco2 View Post
"i am having issues getting my hands on a front wheel spindle."
If it is an axle that you are looking for, seems the same as spindle, I have one or two laying around. I'll look into what it would cost send it to you in Ireland if you like.
By the way the CR/CRF axle is a different axle. I never found one that would work in it's place.
Adam
any luck with front axle?
tractor4play is offline   Reply With Quote
Old 04-26-2013, 06:52 PM   #16926
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 704
Originally Posted by Jayrod1318 View Post
I nearly bought another 606, It came down to price.... I needed some other stuff. (I told the wifey the tire would be 100 bucks)
If this tire doesn't deliver, I'll do my best to wear it out and buy a D606. It worked really well on just about everything, although once it got worn down past halfway it really showed, wheelie attempts result in spinning out on dirt. Not enough Knob.
WE can't have that!
I have been using the AC10 $74 for years now it lasts like the 606 but works better for me and is DOT. longer lasting look to d908$204 on sale, tkc 80 $100+, Heidenau K60 Scout $190 they all last but it costs. B
BigNastybrp is offline   Reply With Quote
Old 04-26-2013, 08:16 PM   #16927
jules083
jules083's Avatar
Oddometer: 4,043
I've seen where a lot of people have said that. I still ride like I'm on a 2 stroke sometimes, I don't know if I'd like a rekluse. There's really no need to ride the pig like that, but if I see the right turn I still pin it and feather the clutch a bit.
Something about feeling a bike turn like that still gets me excited, even if I have to let off as soon as I go straight. It's like seeing a jump and having to hit it, even though there's a turn right past it that you'll be braking for. Hard to resist.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 04-27-2013, 07:22 AM   #16928
Woundflatout
Woundflatout's Avatar
Oddometer: 500
Perhaps someone could help me. I'm pretty new to the BRP and am having a carb issue. I have a Mikuni TM40 fitted and the bike starts easy enough. It will fire up but as soon as its warm, it begins to flame out. It randomly stalls. It pops and stutters before doing so and sometimes it can be prevented by getting on the gas. After the bike has been running for more than say 10-15 minutes, this condition goes away. Throttle response is sharp and there are no flat spots so it seems like the jetting is spot on. I've also adjusted the idle up with no resolve. Odd, no?
Thanks for any insight.
Cheers,
Jason
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout screwed with this post 04-27-2013 at 07:32 AM
Woundflatout is offline   Reply With Quote
Old 04-27-2013, 09:53 AM   #16929
martin.kryjom
Oddometer: 50
Big Bore HRC problem
HI
I have 628 big bore done by XR only.
I finally put all stuff together and it works wit minor issues like not smooth throtlle on 2nd gear when stady and so on.
Main inssue i have is thet even when outside is not too hot ( 19 C) it get hot very fast after 20 min of fast ride, up to 120 C.
Is this normal for big bore?
I have oil coller not instaled yet, i will do it this weekend, but anyway im wondering if is normal??
martin.kryjom is offline   Reply With Quote
Old 04-27-2013, 10:09 AM   #16930
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,031
Are you talking about the L model? This is the R thread and we use radiators, not oil coolers.
Old 04-27-2013, 10:10 AM   #16931
Dread Pendragon
throttle to the donk
Dread Pendragon's Avatar
Oddometer: 2,547
I took my 2000 XRR out for a brief ride the other day and the steering resisted turning.
*sigh*
Guess it's time to switch out the steering stem bearings. I might as well switch out the fork seals and fork oil while I have the forks off. Good times.
"Never get excited in a rally, its a race, but its never a race at that exact moment" -Quinn Cody
Dread Pendragon is offline   Reply With Quote
Old 04-27-2013, 10:29 AM   #16932
LVCJT
LVCJT's Avatar
Oddometer: 248
[QUOTE=martin.kryjom;21280097]HI
Maybe a xr600? Why would I pay for a big bore kit to lose cc's?
Sent from my MB855 using Tapatalk 2
LVCJT is offline   Reply With Quote
Old 04-27-2013, 10:34 AM   #16933
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,031
[QUOTE=DesertDwlr;21280237]
HI
doh!
Old 04-27-2013, 12:20 PM   #16934
Shibby!
Oddometer: 1,665
HI
You jetting is now lean.
Surging with steady throttle is one of the signs. Running hot is another. More displacement, more HP, more fuel required. Try RAISING your needle a clip and do tests to check pilot and main.
120C is hot. Really hot. If you haven't already, install a fan but please don't use the fan to keep temps down. A properly jetting bike shouldn't overheat under normal riding, however adding power (more heat) causes the cooling system to now be undersized, or at least taxed more.
I would refrain from riding the bike till you work out the jetting issue. As an incentive, more fuel = more power! (provided you can get the air in there as well)
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-27-2013, 01:47 PM   #16935
PeteN95
PeteN95's Avatar
Oddometer: 2,852
Not sure what you mean? On the highway the clutch should be locked up? The only time the Rekluse slips is when the rpm drops near idle. What model Rekluse are you using, EXP or Z-start? Are you using a clutch lever? If the plates are warped at all, it will cause excess drag and not work properly.
SVN/XRR/XC-W
Times are GMT -7.   It's 02:37 AM.
