Old 05-10-2013, 07:10 AM   #16996
crypto666
Oddometer: 1,351
Originally Posted by Shibby! View Post
This causes heat to radiate off the thing. It gets SUPER hot.
Why haven't you wrapped it yet? You will love it, and if you wrap it back past the shock, the shock will love it too. I think exhuast wrap does more for shock heating than going to a cr500 shock.
crypto666 is offline   Reply With Quote
Old 05-10-2013, 10:58 AM   #16997
sintax
Oddometer: 495
Originally Posted by ride4fun562 View Post
Does anyone live near Southern California , Long Beach more specifically. I want to compare my piggy to someone else's and I don't know anyone who has one. It would be awesome to go on a little ride and compare if you have it plated, gas would be on me, send a PM.
I'm in Riverside, but Slogger is actually in LB. Maybe hit him up.
Mines currently torn down for TAT prep, but his should be up.
sintax is offline   Reply With Quote
Old 05-10-2013, 11:56 AM   #16998
Shibby!
Oddometer: 1,660
I'm lazy... =)
I was in autovalue in the states. I should have asked if they had fiberglass wrap. Probably 1/3 the cost we pay here..
The other downside is we have very muddy conditions. I've heard of people who wrap them seal with them silicon spray to prevent moisture absortion which leads to rust, etc.
I'll probably do it here before riding it too much. I'm sure both my legs and shock would LOVE it. I can imagine that shock gets damn hot. I know my gas starts boiling if really chuggin along. The tank sure fits well now though!
Adding it to my list of things to do here now...
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 05-10-2013, 02:05 PM   #16999
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,318
I had the stock header with the FMF exhaust. I cracked the stock header (crashed it) and so I bought the aftermarket FMF header. I did have to rejet a bit richer, so there was a power gain, but it's not a huge difference.
JW
Originally Posted by Dual Badger View Post
I have a new to me 2002 xr650r that has a fmf pipe with the stock headers.
Will a fmf powerbomb header system make a big difference?
The bike runs great at this time !!! Thanks
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 05-10-2013, 02:08 PM   #17000
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,318
Thanks. I'm going mostly by throttle position. i've always worked undre the impression little to no opening was the pilot jet, mid throttle opening is the needle and near WOT is main jet size. Since WOT was fine, I was just adjusting the needle.
What puzzles me, is how off the jetting guide is for me. Maybe the FMF kit doesn't use the B53E needle or something, but I had to go 2 needle positions up and several main jet sizes smaller than what's recommended by the jetting guide for my temp/altitude. But oh well, it's running good now! I'm keep playing around with main jets and report back.
Originally Posted by BuRPsa View Post
Jesse,
if an engine 'spudders' then it is running really rich, and the solution is to reduce a jet, not merely dropping the needle. It may feel fine now but I bet it still runs rich, your exhaust telling telltales.
I'd put in (with clean filter, set valves etc) the 68S, set the needle to 'mid' and drop the main size-by-size until you feel it is too small - then use the averaged size with your current one which should put you in the ballpark. Only then finetune the needle.
Of course this is a rough way of jetting, the best is to hook up an analyser on a dyno, however it will work.
Old 05-10-2013, 02:51 PM   #17001
PeteN95
PeteN95's Avatar
Oddometer: 2,804
Yes, I've seen a lot of corroded headers after wrap is removed around here! Never heard of silicon spray sealer? Is this some kind of spray RTV?
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 05-11-2013, 07:03 AM   #17002
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,301
Exhaust coatings/coverings
I've wrapped the XR headers in the past, but usually remove it when I'm going to be riding in wet or muddy conditions. It's usually cooler then anyway, so heat isn't so much of an issue. However, my previous exhaust was all stainless steel, so it wasn't much of an issue. My current exhaust is titanium, so again corrosion isn't a problem. I'm currently in the process of wrapping it for the summer.
My 950, on the other hand, has single wall mild steel exhaust (with some type of plating). And that bike gets hot. It's all enclosed so heat doesn't dissipate unless you're in 3rd gear or higher. There are quite a few stories of those pipes rotting away, so I've never wrapped it. Instead, I did ceramic coating inside-and-out. That's some amazing stuff. I don't think it's as good as good exhaust wrap, but it's durable and looks better.
As for silicone spray on the wrap, I'm not sold. That wrap is some pretty porous stuff. I'm sure it would take a lot of coating to really seal it. And no matter what, it won't be perfect. So now you have a mostly-sealed exhaust wrap that will then hold in moisture instead of letting it out.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 05-11-2013, 10:21 AM   #17003
hontri
Global Bummer!
hontri's Avatar
Oddometer: 304
Can't beat riding in the Okanagan B.C. Some single tracking!
Yesterday. Well it is a single track Awesome day May10/13
More single tracking May 11/13. Where else could you go sledding one day and biking the next!!
hontri screwed with this post 05-11-2013 at 10:30 AM
hontri is offline   Reply With Quote
Old 05-11-2013, 06:47 PM   #17004
Shibby!
Oddometer: 1,660
Looks awesome!
I go snowboarding and dirt biking the day after eachother.. Good fun!
Yup, ceramic coating is what I'm thinking. Just need to take the pipe off and get it done. My buddy did it on his /Berg whom are known for shitty problems and he said it helped tremendously.
Old 05-11-2013, 11:26 PM   #17005
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,440
added the fluidyne rads and new Acerbis tank ....feels better than the safari's i have used b4 ..the safri tank wont fit with the new rads so i got the Acerbis
Sean-0 is offline   Reply With Quote
Old 05-12-2013, 07:19 PM   #17006
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
Tejas
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 05-13-2013, 02:35 AM   #17007
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
High idle
I have a question about my BRP. The bike starts and runs great. I has the stock carb that was jetted by the previous owner. When the bike warms up the idle hangs up to high. If I let the clutch out a little to load the engine it will come back down but if I blip the throttle it hangs up again. Any ideas.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 05-13-2013, 06:47 AM   #17008
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Yes: adjust a bit more play into the cables, and/or clean & lube them.
BuRPsa is offline   Reply With Quote
Old 05-13-2013, 07:01 AM   #17009
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,318
Minnesota...
Old 05-13-2013, 07:24 AM   #17010
crypto666
Oddometer: 1,351
Stainless headers?
Times are GMT -7.   It's 05:39 AM.
