Old 08-01-2013, 10:45 PM   #17716
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
My 2 XR's don't shake, not even a quiver between 1-95 mph. Check the items in the post above.
Sent from my DROID RAZR HD using Tapatalk 2
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 08-01-2013, 11:12 PM   #17717
Gunga Galunga
Gunga Galunga's Avatar
Oddometer: 227
Originally Posted by Stonethrowa View Post
Has anyone had neoprene fork guards on there XR if so any issues
If not which size worked best ,Thanks for any help in advance.
As to the last post will be watching closely as mine makes rattly noise when cold but not with clutch pulled in then get better as it warms up,
Hope its nothing serious
I just got some but haven't put them on yet as I want to service the forks at the same time. I hear you need to keep the forks clean under the guards to avoid abrasion.
TannerC
On the clutch noise, I assume the fibers were presoaked in oil? Sorry, I don't know about the movement.
Originally Posted by PeteN95 View Post
I miss my WR500, it was a handful, but a lot of fun. And it could do almost anything, I even road raced it! Here it is in flat track mode.
Pete and 95, awesome! I completely rebuilt it, sold it to a friend, and was lucky enough to buy it back, albeit not in the same condition, Next project!
2001 Honda XR650R (Plated)
1992 Yamaha WR500ZD
Gunga Galunga is offline   Reply With Quote
Old 08-02-2013, 12:15 AM   #17718
OR Trail
looks for unlocked gates
OR Trail's Avatar
Oddometer: 357
Originally Posted by Twatwaffle View Post
I guess I should elaborate...no headshake on pavement or nicely packed dirt roads, but when there's loose stuff forming grooves from 4 wheel traffic it can get pretty bad. I'll definitely start playing with the suspension a bit and see if I can work it out.
Any recommendations on bar bends? I see a lot of people going with CR High, but not much detail regarding these rider's height.
Also check if your forks are slid down in the triple clamps, which steepens the head angle (twitchier). If the front is sprung too soft vs the rear it can have the same effect. Too tight a (hand) grip on the bars can amplify the effects in loose stuff too.
I like to find a comfortable bar then move it around with (Rox) risers. Try a few on other people's bikes, or buy used to resell if/when you guess wrong. I'm super tall so no help there for your size. Risers are something to think about with top vs under mount dampers.
OR Trail is offline   Reply With Quote
Old 08-02-2013, 07:46 AM   #17719
mitchn06
mitchn06's Avatar
Oddometer: 554
Originally Posted by tannerc View Post
I swapped out my clutch for aftermarket steels and fibers. A while late I started to get the clutch noise/howl at idle that disappears when you pull in the clutch. The pressure plate bearing appears to be fine, the steels and fibers still appear new. I cant figure out what would be causing the noise. Also I was playing with the basket and noticed a little play/wiggle/wobble to it is this normal?
what year is your bike Tanner? if its one of the first two years it could be the older style clutch bushing?
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 08-02-2013, 08:41 AM   #17720
tannerc
Pig Pilot
tannerc's Avatar
Oddometer: 299
Originally Posted by Gunga Galunga View Post
TannerC
Yeah everything was soaked in new oil, about a week before I could get around to installing it.
Originally Posted by mitchn06 View Post
what year is your bike tanner? If its one of the first two years it could be the older style clutch bushing?
2003
tannerc is offline   Reply With Quote
Old 08-02-2013, 08:51 AM   #17721
mitchn06
mitchn06's Avatar
Oddometer: 554
http://www.partzilla.com/parts/searc...TCH/parts.html
if you look at this diagram, it looks like the only thing that would allow the basket to wiggle like that would be the clutch bushing.
Old 08-02-2013, 08:57 AM   #17722
tannerc
Pig Pilot
tannerc's Avatar
Oddometer: 299
Thats what I thought, bad bushing. I ran into a post some where that said there is supposed to be a bit of play in the basket.
I figured I would check here before unstaking and ordering a bushing.
Old 08-02-2013, 09:20 AM   #17723
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,659
The howl is because the inner and outer basket fingers are hammered...like done, junk. See all those neat little indentations where the clutch fingers engage the basket fingers? Yeah, they're not supposed to be there.
Get a Hinson outer basket and a new Honda inner hub. If money is tight you can file/sand the ridges out and get some more life out of it.
The in/out basket play is normal, but a new bushing won't hurt.
Old 08-02-2013, 09:23 AM   #17724
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
I don't think so, hunch it's the bush if not the internal rubber cushions (cush).
I'd check the bush first, and a new one won't hurt anyway. If it's the cush blocks then bad news...
But wait until Larryboy chimes in, I know he's swapped his basket for a Hinson already.
As a totally unrelated remark, Thanks2Those who help me, either here or via PM. Much appreciated, it shows this forum is attended by a breed of very international pals indeed
BuRPsa is offline   Reply With Quote
Old 08-02-2013, 09:28 AM   #17725
BuRPsa
BuRPsa's Avatar
Oddometer: 548
..... and within seconds a plethora of posts fly in so my previous post looks dated by default.
Thanks LB for not disappointing
Old 08-02-2013, 09:31 AM   #17726
mitchn06
mitchn06's Avatar
Oddometer: 554
mine is all torn down now, but i had slight indentations on my basket, never howled though, and i'm pretty sure its stock plates.
Old 08-02-2013, 09:35 AM   #17727
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,659
I'd run that one awhile yet. First symptoms will be a strange delay to clutch engagement, like the cable is getting frayed and hanging. As it gets worse, it'll chirp and howl as you roll away in first.
The one in the video a page back is super bad, I'd replace the hub and outer basket on that one.
Old 08-02-2013, 10:57 AM   #17728
tannerc
Pig Pilot
tannerc's Avatar
Oddometer: 299
Thanks for the help
New basket lock nut and bushing on the way. Going to take some measurements and try smoothing out the basket in the video see if it will get me through the rest of the season. Going to end up ordering a hinson I guess.
Old 08-02-2013, 08:25 PM   #17729
Stonethrowa
Hack
Stonethrowa's Avatar
Oddometer: 37
Tanked
I am sure its been asked before but here I go
Clarke 4.3 vs IMS 4.6
I have the Clarke in red (going natural now) and I don't think the fitment was that good So is it worth the extra bucks and getting IMS
Stonethrowa is offline   Reply With Quote
Old 08-02-2013, 08:38 PM   #17730
LVCJT
LVCJT's Avatar
Oddometer: 235
Got a question for the experts. I'm checking the valves on my neighbors 01 pig and the valves are super tight. Would this contribute to excessive oil consumption? All of the valves are tight.
Sent from the depths of my pockets
LVCJT is online now   Reply With Quote
Times are GMT -7.   It's 08:41 AM.
