Old 08-11-2013, 12:59 PM   #17806
bigkuri
bigkuri's Avatar
Oddometer: 730
Originally Posted by WunderfulLusterful View Post
Also, another quick way to inspect things is to pull the oil filter and look between the pleats. If there are chunks or alot of metal debris there is some internal damage. The oil that is in the bike will tell you the whole story of what is going on.
Thanks! Great idea :)
---------- Current Bike: 2006 Honda XR650R ------------
bigkuri is offline   Reply With Quote
Old 08-11-2013, 01:02 PM   #17807
WunderfulLusterful
Oddometer: 24
Originally Posted by bigkuri View Post
Thanks! But not in England! Cheaper here to buy new :( We just don't have the shop mechanics you guys have :(
I gave lifted many heads, just a bit bummed as just bought the damned thing....
Opps, I didn't notice you were in England.
WunderfulLusterful is offline   Reply With Quote
Old 08-11-2013, 03:02 PM   #17808
sunnybandit
sunnybandit's Avatar
Oddometer: 54
XR650R Thread!
In idahoe and my exhaust (muffler ) on my big gun system is fucked. Anybody out here got a shop or a spare sparky/muffler that may fit on the headers? Thanks!!!
Edit: twin falls area ,
MSE mobile
sunnybandit is offline   Reply With Quote
Old 08-11-2013, 03:58 PM   #17809
Klacasse
BRP Junkie
Klacasse's Avatar
Oddometer: 18
just a question for all the BRP experts on here.
I have a 2005 xrr and it seems to have a bit of a stumble at low throttle (cruising and not using much throttle), It also has quite a bit of popping on deceleration. Could this be running a bit lean?
I just got the bike about a month ago and haven't torn into it to much yet, (having too much fun riding it!) but it has been uncorked (hrc tip and air box mods) and all the smog stuff has be removed. The p.o said there was some "go fast" parts in the engine but didn't know what had been done. Is it normal to get popping with this exhaust set-up,
Any ideas on the stumble would be helpful its getting kinda annoying (throws you forward a bit kinda like you just closed off the throttle completely.) Only happens at 1/4 throttle or less
thanks again
Kris
Klacasse is offline   Reply With Quote
Old 08-11-2013, 11:03 PM   #17810
PeteN95
PeteN95's Avatar
Oddometer: 2,679
Originally Posted by BuRPsa View Post
Pete, let me get this correct:
- this fits into the clutch if you (I would think) take a few plates out and put this in?
- when done this will 'auto-operate' the clutch PLUS still leaves the normal manual operation present?
Correct, just remove 2-3 plates and install the Rekluse unit.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is online now   Reply With Quote
Old 08-12-2013, 01:49 AM   #17811
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
Can anybody comment on the maxxis it front tire on the brp? I want to take the mitas xt644 off and put that on my adventure instead.
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 08-12-2013, 02:18 AM   #17812
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Which tires? Desert IT rear tire is awesome! Front... not my favorite.
jesusgatos is online now   Reply With Quote
Old 08-12-2013, 11:42 AM   #17813
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Jesus, that's what I read so bought one. It chuncked knobs in one day riding, and after 3 of those it still is usable... but it's also my last, won't consider it again. Maybe good in soft stuff, but show it harder stuff and it greets farewell on sight.
Thanks, and we know you are a diehard supporter of these auto clutches. Is this what you've got or got the full kit (name escapes me), rear brake instead of clutch etc?
BuRPsa is offline   Reply With Quote
Old 08-12-2013, 12:07 PM   #17814
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
I have the rear too, but Im sure my BRP will destroy it. Might run it for fun though.
Right now im happy with my C02. Its been really impressive.
Might run the E09 Dakar (excuse my 950) next time
but for now, this is pretty good.
06 950S
Yamaha YZ250WR
Old 08-12-2013, 12:58 PM   #17815
Shibby!
Oddometer: 1,657
Something was wrong with that tire.
I've thrashed these Desert IT's in every rideable situation and they hold up better than most that provide that level of traction, rideability, and stability.
Maybe there's a chance you guys get a diff rubber compound.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 08-13-2013, 07:07 AM   #17816
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Ya Shibs, my thought also. Mind, all Maxxis's are imported, no idea where from. Was hard to get sortof too, and was not on the product list for starters. Oh well, the joys of living Dark Under I suppose
Old 08-13-2013, 07:41 AM   #17817
Shibby!
Oddometer: 1,657
We get the same shaft here.
Old 08-13-2013, 10:12 AM   #17818
walkergreenlabel
Oddometer: 200
rekluse
Yes, you replace 2 or 3 steels and friction plates with this plate. From what I read, the clutch lever will still disengage the clutch but obviously it will not engage it. They say that the disengagement "area" is always in a different spot depending on engine rpm. I have been looking locally for a Rekluse-equipped bike to test out before I drop the coin on one. Reviews on the EXP have all been very positive.
Where are you?
I picked one up this year. I had a little trouble getting it dialed in. I think I didnt let it break in long enough and had to adjust it a few times but it is working nicely now. stock clutch function when you want and auto clutch when you need it.
walkergreenlabel is offline   Reply With Quote
Old 08-13-2013, 12:24 PM   #17819
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,347
here's a short vid of me and my boy on our 3 week ride
Sean-0 is offline   Reply With Quote
Old 08-13-2013, 12:25 PM   #17820
sintax
Oddometer: 495
I'm with shibby on this one.
I run that Maxxis Desert IT on my KX500 desert bike because of its wear results . It does not chunk, and wears like iron. My riding style with the KX500 is totally different than my XR too, its all wheel spin all the time. If its gonna chunk on any bike, its gonna be on a KX500.
sintax is offline   Reply With Quote
Times are GMT -7.   It's 03:08 PM.
