Old 09-24-2013, 11:33 AM   #18211
TunaGod06
Oddometer: 3
Good Afternoon,
I'm needing a valve job performed on my XR650R. I've purchased the Kibble White valves, seals, springs, and guides. If the existing valve guides are within spec, can I get by without having to replace them, or do Kibble White valves require the Kibble White valve guides?
TunaGod06 is offline   Reply With Quote
Old 09-24-2013, 11:41 AM   #18212
KustomizingKid
Oddometer: 678
Originally Posted by mitchn06 View Post
got done reading your thread about what bike to get and your Black Hills loop RR. fun stuff, you have brass for riding across SD in November. The winds between Sioux Falls and Wall put so many big rigs in the ditch each year its not even funny. all they get are crosswinds. I found it kind of funny that you chose the XRR after all of the debate.
What do you plan on using for luggage for the XRR as it has an aluminum subframe?
I tell you what man after all the debate I realized a few things. I rode that shit can KLR all over this summer and took it down trails it shouldn't be. It sucked and its boring and anemic. Then I rode a DR350 and a WR250R... Way better, but no power, yawn. Then I though about Euro bikes, but alas, I am too poor.
Then a light shone in the distance, the almighty BRP. Found a killer deal here on ADV, bought it in KY, rode 700 miles home. Here is the real kicker, I had never even ridden or sat on an XR before I bought it
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 09-24-2013, 11:42 AM   #18213
KustomizingKid
Oddometer: 678
I plan on a Giant Loop and either reinforcing the subframe, or building a new chromoly one if I find the time. Not that worried either way.
2000 Xr650r!
Old 09-25-2013, 03:30 PM   #18214
ride4fun562
ride4fun562's Avatar
Oddometer: 207
Wicked
Just finished.my top end rebuild with hotcams stage 1, holy moly, and i thought the thing had power before. Lol i must not of had any compression before.
ride4fun562 screwed with this post 09-25-2013 at 03:46 PM
ride4fun562 is offline   Reply With Quote
Old 09-25-2013, 03:49 PM   #18215
TunaGod06
Oddometer: 3
Other than the cam, did you go with stock hardware for your rebuild?
Old 09-25-2013, 04:11 PM   #18216
ride4fun562
Oddometer: 207
Went with kibblewhite and wiseco stuff, everything stock sizes
ride4fun562 screwed with this post 09-25-2013 at 04:53 PM
Old 09-26-2013, 09:25 AM   #18217
ride4fun562
Oddometer: 207
Good Afternoon,
I would do it since you have them anyways, i just got mine done, cut and grind seats install everything including guides for 125, it only took the guy a day and it came out beautiful
Old 09-27-2013, 03:22 AM   #18218
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,469
how much would one pay for such an item
plug n play steel subframe, solid ends as per stock subframe
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 09-27-2013, 07:23 AM   #18219
KustomizingKid
Oddometer: 678
So I need new chain/sprockets before I head south. I plan to use Dirt Tricks sprockets. So how should I gear it? I want to carry 14&15 teeth fronts and change between the two. 15 for on road and 14 for off road. So what rear? 46,47,48?
2000 Xr650r!
KustomizingKid screwed with this post 09-27-2013 at 07:54 AM
Old 09-27-2013, 07:30 AM   #18220
bigkuri
bigkuri's Avatar
Oddometer: 730
Originally Posted by KustomizingKid View Post
So I need new chain/sprockets before I head south. I plan to use Dort Tricks sprockets. So how should I gear it? I want to carry 14&15 teeth fronts and change between the two. 15 for on road and 14 for off road. So what rear? 46,47,48?
If any help I've just bought 15/45 and will take along a 14 to gear it down slightly. It's for a trip to Morocco where it will be about 30% road, 70% offroad.
---------- Current Bike: 2006 Honda XR650R ------------
bigkuri is offline   Reply With Quote
Old 09-27-2013, 07:31 AM   #18221
mitchn06
mitchn06's Avatar
Oddometer: 554
Finally somebody else is gonna make a steel subframe! the only other one sells for $340, so i'd spend $150 on one. i'm sure the other brand ones would sell more if they were not so dang expensive. i know some peeps would drop that kind of money like nothing, but i would say most of us XRR owners would not.
damn, why do you have to be in Australia?
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 09-27-2013, 07:32 AM   #18222
bigkuri
bigkuri's Avatar
Oddometer: 730
My bike re-build/prep continues, with bits of bling starting to arrive!
Custom HyperPro shock; 2cm more travel, springs for 130kg laden weight, valved to suit.
Old 09-27-2013, 07:37 AM   #18223
woodsxr
Oddometer: 188
Pretty much the same boat 340.00 is a little high for me but $150-$200 is more in my range
woodsxr is offline   Reply With Quote
Old 09-27-2013, 08:25 AM   #18224
KustomizingKid
Oddometer: 678
How is the 15/45? What is 120 kph like? That is the normal cruising speed on the interstate for me.
2000 Xr650r!
Old 09-27-2013, 08:26 AM   #18225
red_rooster
Oddometer: 5
I was thinking $200 also..If it had a fenderloop to help support the fender and some soft luggage strap loops I might pay $300....
red_rooster is offline   Reply With Quote
Times are GMT -7.   It's 11:20 AM.
