Old 10-01-2013, 09:28 PM   #18256
brayjay
Oddometer: 237
xr650r swingarm install help!!
HI, I have just finished greasing my rear shock linkage and swing arm bearings and when I reinstalled the swing arm, its as if the frame has expanded or the swing arm has shrunk!! The dust cap on the right side before I took it apart was tight to the frame,and after reinstall there is now a quarter inch gap between the dust cap and frame. This is with preload nut and pivot bolt torqued to spec. Any one have any thoughts as to why? Any help would be appreciated.
brayjay screwed with this post 10-01-2013 at 10:00 PM
brayjay is offline   Reply With Quote
Old 10-01-2013, 10:12 PM   #18257
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
Did you screw in the hollow bolt before torquing the nut that the swingarm bolt goes through?
Are all the dust caps in place?
Sent from my DROID RAZR HD using Tapatalk 2
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 10-02-2013, 07:38 AM   #18258
brayjay
Oddometer: 237
yes I followed the procedure from the manual. Both dust caps are on swing arm, install swing arm,insert pivot bolt from left side to line it all up, then I screwed in the preload adjuster in until it touched the dust cap and torqued to 9ftlbs. Then torqued lock nut to 45ftbls. pilled out pivot bolt re inserted from right side an torqued to 80ftlbs. The thing that is strange is the preload adjustment nut has to thread through the frame until I can see it come through the frame and then it touches the dust cap so once everything is all tightened up instead of the dust cap up tight against the frame like it was before I took it apart, now there is about a quarter inch gap between cap and the frame. im pretty shure im not missing anything. Someone else on another forum had the exact same problem but out of 20 replies no one had an answer. Ill try and get some pictures up.
Old 10-02-2013, 08:07 AM   #18259
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
I can look at my 2 XRR's and see what the gap is. I don't think it changed much when I put in new bearings and seals this spring in one bike.
Maybe something was out of position before disassembly.
Old 10-02-2013, 08:12 AM   #18260
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,462
Busy installing a trailtech vapor on my XRR. Any idea where I can get live power from?
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 10-02-2013, 08:21 AM   #18261
brayjay
Oddometer: 237
That would be great. Any pics I found on the net showed both dust caps tight to the frame like mine was. I wonder if the frame relaxes after the first time the pivot bolt is removed.
brayjay screwed with this post 10-02-2013 at 10:55 AM
Old 10-02-2013, 11:06 AM   #18262
medisyn
Oddometer: 149
I am going to put my swingarm back on in the next day or two. I will snap a picture if I notice any gap. If it does indeed flex, mine will too because its been sitting with the swingarm off for a week.
medisyn is offline   Reply With Quote
Old 10-02-2013, 11:24 AM   #18263
brayjay
Oddometer: 237
Thanks. If you left click on my user name and then click on find more posts from brayjay, the second one down has a picture of the swingarm, LOL, Im still trying to figure out how to import it to this thread. I was born in the wrong century I guess.
brayjay screwed with this post 10-02-2013 at 11:32 AM
Old 10-02-2013, 12:35 PM   #18264
mitchn06
mitchn06's Avatar
Oddometer: 542
Not trying to be rude, but can you run a line from the battery, I recall this working the best from previous posts.
Sent from my iPhone using Tapatalk - now Free
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 10-02-2013, 01:10 PM   #18265
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,849
Here's Brayjay's 2 pics of the gap in his swingarm reinstall
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is online now   Reply With Quote
Old 10-02-2013, 01:16 PM   #18266
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
All USA models do not have a battery and are AC. If you have a DC system and a cap or a battery system with a switch I would go there.
Old 10-02-2013, 01:46 PM   #18267
brayjay
Oddometer: 237
Thank you.
Old 10-02-2013, 02:19 PM   #18268
mitchn06
mitchn06's Avatar
Oddometer: 542
yes, i did not see that you were from the Africas, you will most likely have a capacitor mounted to somewhere behind the headlight i think. even then, you will only have DC while the bike is running.
Old 10-02-2013, 03:09 PM   #18269
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
I checked the swingarm space on my 2 bikes and they have a very small gap, almost snug.
Old 10-02-2013, 03:14 PM   #18270
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,301
When snug, mine has the space equivalent to one of the smaller L-shaped allen wrenches I have (2.5-4 mm, can't remember for sure). I use these to measure the gap to make sure it's centered in the frame.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Times are GMT -7.   It's 05:47 AM.
