Old 10-02-2013, 04:09 PM   #18271
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
I checked the swingarm space on my 2 bikes and they have a very small gap, almost snug.
Sent from my DROID RAZR HD using Tapatalk 2
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 10-02-2013, 04:14 PM   #18272
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,294
When snug, mine has the space equivalent to one of the smaller L-shaped allen wrenches I have (2.5-4 mm, can't remember for sure). I use these to measure the gap to make sure it's centered in the frame.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 10-02-2013, 04:17 PM   #18273
brayjay
Oddometer: 226
Hmmm any idea what has gone wrong? Doesn't make sense. I wonder if I could wreck anything by riding it this way. Since im not missing any parts, the only other thing I can think of is the frame sprung back a bit.
brayjay is offline   Reply With Quote
Old 10-03-2013, 04:18 AM   #18274
jm-2008
jm-2008's Avatar
Oddometer: 507
Vapour power
[QUOTE=stevh0;22461829]Busy installing a trailtech vapor on my XRR. Any idea where I can get live power from?
Think the Vapor is happy with either AC or DC
If the SA XR's are like the Oz versions you can pick up DC if that's your preference from the DC supply that runs the indicators
Pm me an email and I will send you some pics of my setup
Regards
JM-2008
jm-2008 is offline   Reply With Quote
Old 10-03-2013, 01:19 PM   #18275
medisyn
Oddometer: 149
Speaking of the trailtech vapor, what is a good way to mount it? I have had mine sitting in the garage unused for a while.
medisyn is offline   Reply With Quote
Old 10-03-2013, 02:39 PM   #18276
SwellsRides
SwellsRides's Avatar
Oddometer: 161
Vapor
I just used straight flat Aluminum stock about 4" long right off the bar clamp and it works great, and looks clean.
Swells
2000 XR650R SM
1996 VFR750
XR400 SM (Sold in Thailand)
Royal Enfield Bullet (Sold in Sri Lanka)
"When in Doubt, Punch it out!"
SwellsRides is offline   Reply With Quote
Old 10-07-2013, 10:31 AM   #18277
bigkuri
bigkuri's Avatar
Oddometer: 730
Found something to plug this hole:
With this:
Getting closer....
---------- Current Bike: 2006 Honda XR650R ------------
bigkuri is offline   Reply With Quote
Old 10-07-2013, 07:24 PM   #18278
Bench Racer
Oddometer: 82
Sup with the mileage?
My BRP gets horrible mileage for some reason. On a ride with another BRP, at fill up I took one more gallon than the other bike. We started at the same place full of gas and rode the same speed. How is this possible? I think the float must be out of wack. Could the carb some how be dumping gas straight into the motor and not burning it off? It seems like fuel is being wasted by something from the floats. Last ride out, the float was sticking and pissed the whole time bringing this bad mileage and float situation to mind.
Since then, I cleaned the carb and adjusted the float to 16/17mm like the manual says. Will this help? The original reading was 19mm.
I know the XRR doesn't get great mileage but mine is horrible.
Help please.
Bench Racer is offline   Reply With Quote
Old 10-07-2013, 09:17 PM   #18279
jm-2008
jm-2008's Avatar
Oddometer: 507
Mileage and float levels
[QUOTE=Bench Racer;22502880]My BRP gets horrible mileage for some reason. On a ride with another BRP, at fill up I took one more gallon than the other bike. We started at the same place full of gas and rode the same speed. How is this possible? I think the float must be out of wack. Could the carb some how be dumping gas straight into the motor and not burning it off? It seems like fuel is being wasted by something from the floats. Last ride out, the float was sticking and pissed the whole time bringing this bad mileage and float situation to mind.
Help please
BR,
If its the stocker I'd go back to 19mm
16/17 seems too high and it will likely leak out the overflow when on the side stand.
Certain my stock carb was set to 19 and it ran just fine, search the thread for info as it has come up a number of times.
Think OEM spec is 18 but at that level mine would leak out when on the side stand, 19 fixed the problem.
Of course riding style, gearing, altitude (especially if the bike is lying horizontal) will all affect mileage but it should not vary that much on a stock carby - pumpers are another story!
JM-2008
Old 10-07-2013, 09:27 PM   #18280
bamfslap
Oddometer: 205
fall is the best time for riding
bamfslap is offline   Reply With Quote
Old 10-07-2013, 11:41 PM   #18281
Bench Racer
Oddometer: 82
BR,
JM-2008[/QUOTE]
I found that 16/17 does make it leak on the side stand. Dang it. So I'm going to adjust it until it stops leaking. Thanks for the help.
Old 10-08-2013, 01:07 AM   #18282
bigkuri
bigkuri's Avatar
Oddometer: 730
Great photo, love it :)
Old 10-08-2013, 09:10 AM   #18283
BronkoRob
Oddometer: 60
all you former KTM owners out there....got some questions
I have big plans for next year. multiday, multi state, long distance trips coming up. right now i dual sport on an 07 KTM 450XC, which is fine for less than day trips. has a lot of work into it its setup nice and does what i ask of it. I am worried that long distance on slap, with me being 200lbs, with gear, and with extra fuel will result in a quick end to the motor, the sub frame, etc.
anyone jump the KTM ship and go to the XRR? I have read numerous posts on multiday, cross country, 1000 miles freeway stretches, all asphalt trips on the XRR. I cringe when i think about that on my KTM. I'm 30, only had a few bikes with the button, so im not too proud to kick.
keep in mind my KTM is a short stroke motor, the SX motor, with a hybrid 6 speed with close ratio 5 and 6. The power is all up high, its a race bike. it can be lugged. but i worry about getting into slower technical sections, with a loaded up bike and riding the clutch all the time to move the bike and the extra weight. so the bike revs great, but for long adventure riding, id much rather have more torque way low where it would be more usable.
I have been offered a trade off craigslist, for a plated 02, all setup, and turns out i know the guy. respect his build, and have no fear in it being a good condition bike.
Other than the no e start, being a bit heavier....which i would prefer for the longer rides on the road....what else would i be giving up?
i have heard the XRR suspension, once setup can be great! and im not that fast or hard on it to probably know. i know im not using the KTM to its potential.
from the looks of all these loaded up XRRs it looks to have a much stronger subframe as well.
who out there has swapped over from orange to red and has some feedback.
No Pads, No Helmet.....Just Balls!
BronkoRob is offline   Reply With Quote
Old 10-08-2013, 09:56 AM   #18284
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 536
I prefer my XR when I expect any lengthy seat time,both my dirt bikes are registered.Prior to the Berg ,I had a 525exc.IMHO the Honda is the better bike for dual purpose.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 10-08-2013, 10:04 AM   #18285
mitchn06
mitchn06's Avatar
Oddometer: 553
Anybody have a spare or unused 10-11kg rear spring they are willing to part with? Thanks.
Sent from my iPhone using Tapatalk - now Free
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Times are GMT -7.   It's 05:01 PM.
