Old 11-19-2013, 07:51 PM   #18586
brayjay
Oddometer: 230
Same here. Got two 650r's and both clutches look like that, maybe not quite as grooved though.
brayjay is offline   Reply With Quote
Old 11-19-2013, 09:29 PM   #18587
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
Originally Posted by PineyMountainRacing View Post
Yep, my spacers from W9 weren't marked, but the PDF file had them mislabeled. But, I woke up last nite thinking that the length of the spacer changes the relationship between the sprocket and the swinger, as well as the alignment with the counter sprocket. It doesn't affect the relationship of the sprocket to the rim.
You guys that are running Warps, did you have to change the offset of your wheels to fit them? The inmate that sold me these said he had them on an XR-R and that they were built by the factory for that bike. But he could have been blowing smoke... If you get a chance get me the distance (clearance) from the sprocket to the swinger when the wheel is installed, por favor! I bet I just need to move the rim over on the hub, just wanna see what others have before I start fooking with it.
Swing arm to sprocket clearance is roughly 7mm. I did measure swing arm to rim also, this # will change with axle position but gives ya the idea. 37mm on chain side and 30mm on rotor side. Mine is roughly 7mm offset. The wheels have not been messed with since purchased new(checked tension that's it).
Capt. Egregious is offline   Reply With Quote
Old 11-20-2013, 02:53 AM   #18588
babuja
babuja's Avatar
Oddometer: 353
Hey guys, just dismount water pump for full flush...
Do you recommend further maintenance? Cheers
Sent from my HTC One using Tapatalk
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 11-20-2013, 04:45 AM   #18589
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Originally Posted by OBD View Post
Nooooo he means turn each nipple on one side an equal 180 (half turn)
Do this for the entire circumference
Then take up the 1/2 turn 'slack' you've created on the opposite side.
Thank you OBD, you clearly do have a healty brain LOL
Piney, 180 deg's gave you 0.5mm? Then you'll have to turn them a lot more next time, but to get to 7mm offset I'd do it in phases in any case.
Babuja mate,
did you take the thermostat out before flushing?
Looks to me it flows a bit freely, but then again this might just be the pic.
And yes, you do need a thermostat
BuRPsa is offline   Reply With Quote
Old 11-20-2013, 06:39 AM   #18590
crypto666
Oddometer: 1,343
The W9 PDF file says to offset the rim 1mm off the rotor, but without a diagram I don't understand what that means (which side of the rotor are they measuring from?).
I would bet they mean off the inside of the rotor (spoke side), this would be the same point of measurement shown in the Honda manual.
crypto666 is offline   Reply With Quote
Old 11-20-2013, 08:13 AM   #18591
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 169
Originally Posted by ride4fun562 View Post
Is this wearing on the Clutch center and clutch press normal? For some reason im gonna guess no.
That wear is from centrifugal force. Clutch basket spinning, forces the spring outward.
Its normal to have that wear
If you clutch is working good ignore it
Stiffer springs will somewhat reduce the amount of wear you are indicating.
FlyGuy is online now   Reply With Quote
Old 11-20-2013, 11:29 AM   #18592
babuja
babuja's Avatar
Oddometer: 353
Originally Posted by BuRPsa View Post
Babuja mate,
Nope, didn't take thermostat out...just removed anti freezing liquid from all system, washed radiator with water to remove some "sand"...and flushed system from water pump (as pic shows).
How do you do a full cooling system flush mate?
Hmm..why is that?
Your sure i need one in Angola? :)
Hey man,
Looking to hear some news from you and how your going around your BRP ��
Cheers
Cheers guys
Babuja
________
KTM 950 ADV
babuja screwed with this post 11-21-2013 at 12:54 AM
Old 11-21-2013, 01:12 AM   #18593
BuRPsa
BuRPsa's Avatar
Oddometer: 548
You did, just empty the coolant tank also - and refill too (ahem )
Hmm..why is that?
Warming-up (this is when an engine wears most!) goes a LOT quicker, and it ensures the temp will never drop below the set value.
Same as here, definitely.
December should bring me time, hence some work done. Hopefully a machinist-friend of mine can do some turning work then too.
Old 11-21-2013, 02:56 AM   #18594
babuja
babuja's Avatar
Oddometer: 353
Cheers guys
Babuja
________
KTM 950 ADV
Old 11-21-2013, 03:13 PM   #18595
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,399
Respect ...
For you guys that have mastered wheel building. I'm not worthy !
What does it say the normal offset should be? I still have my original wheel and rotor, so I can measure that and see what I started from.
Babuja mate,
I "eye-balled it" and it looked like I needed to shift the rim towards the rotor at least 5 mm so I figured I'd go 7 mm to be safe. I've got it almost 7 now, but I've run out of threads on the rotor side, like the spokes are too long for that amount of adjustment. And I can't finish truing it towards the 7, so I guess I'll need to move it back and look for a total offset of 6mm, that will take some pressure off the rotor side spokes. The rim having a bent spot didn't help any, so much for "no damage, like new" but I've about got it worked out.
If the 6mm isn't enough, then I'll need different spokes, at least on the rotor side. On the sprocket side I'm seeing 2-3 threads now, they may need to be a little longer.
PineyMountainRacing is online now   Reply With Quote
Old 11-21-2013, 05:46 PM   #18596
crypto666
Oddometer: 1,343
19mm according to the manual using oem rim from the INSIDE of the rotor to the outside of the rim. You are going to need to use a bit of math to convert it for your wider rim.
Old 11-22-2013, 05:06 AM   #18597
mitchn06
mitchn06's Avatar
Oddometer: 542
What do you guys think of the guy on eBay selling the Service Manual in CD form? I mean I doubt he is selling any, but come on, really?
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is online now   Reply With Quote
Old 11-22-2013, 06:13 AM   #18598
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Yip, by the sounds of it you'll need different spokes, I actually thought you might. You're offsetting (off-middle) quite a bit, and it may be that your wider rim also has the spoke-holes offset more ('wider', further apart axially) than the std rim has.
Ask a wheelbuilder/company what you will need, but measure (accurately, use a vernier) the lengths you currently have/need first. Know that the hub needs certain angles of the spoke heads, but these they probably know - that is if it's the std hub?
Old 11-22-2013, 07:23 AM   #18599
crypto666
Oddometer: 1,343
There is a sucker born every minute.
Old 11-22-2013, 08:14 AM   #18600
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 702
This sucker is heading for a Barstow to ride to las Vegas. Go ride boys !
BigNastybrp is offline   Reply With Quote
Times are GMT -7.   It's 11:41 AM.
