Old 12-14-2013, 11:15 AM   #18841
cognugget
cognugget's Avatar
Oddometer: 243
Check the plug. Are you getting fuel?
Sent from my SCH-I545 using Tapatalk
Plated XR650R
cognugget is offline   Reply With Quote
Old 12-14-2013, 11:28 AM   #18842
jules083
jules083's Avatar
Oddometer: 3,894
I'm going to go get fresh gas, as soon as I get back I'll pull the tank and check the plug. I doubt it's either, but worth a shot. Gas is starting to smell a bit funny I guess, but it does this every winter so I'm not thinking it's gas or spark plug related.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 12-14-2013, 11:30 AM   #18843
cognugget
cognugget's Avatar
Oddometer: 243
Check for clogged pilot jet
Plated XR650R
Old 12-14-2013, 11:37 AM   #18844
mdlak
Oddometer: 201
Is this a normal casting mark on my XRR engine case or some kind of repair? Located on right side near rear brake arm. Anyone have similar markings in the same area?
mdlak is offline   Reply With Quote
Old 12-14-2013, 11:41 AM   #18845
jules083
jules083's Avatar
Oddometer: 3,894
Game off for now. See the green stuff? I don't think that's supposed to be there. Looks like a good time to change coolant. Lol.
Old 12-14-2013, 11:46 AM   #18846
OR Trail
looks for unlocked gates
OR Trail's Avatar
Oddometer: 359
Interesting - mine is identical. I took the cover off and it looked a bit stressed on the inside so I gave it a coat of JB Weld on the outside and called it good. I thought it was from something hitting it but I'm interested to hear if this is common.
OR Trail is offline   Reply With Quote
Old 12-14-2013, 12:05 PM   #18847
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,125
It looks like a casting mark to me, it appears a thin layer flaked off, probably when it was removed from the mold. I doubt a welder could perform a repair that looked that good and usually when a case is repaired there will be a bead and heat marks or evidence that the weld was ground down.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 12-14-2013, 12:29 PM   #18848
slogger
Oddometer: 672
I've seen this on my last 3 XR's. Normal.
slogger is offline   Reply With Quote
Old 12-14-2013, 01:47 PM   #18849
mdlak
Oddometer: 201
Casting marks/lines seem to be normal. Went to see a friend with a 2002 XR650R and his bike has the same marks. Thank you!
Old 12-14-2013, 02:16 PM   #18850
jules083
jules083's Avatar
Oddometer: 3,894
Looks good to me, right? Seems a touch rich, but nothing extreme and surely nothing that would keep it from starting in the cold.
Old 12-14-2013, 02:30 PM   #18851
Lostsaffa
Half Man Half BRP
Lostsaffa's Avatar
Oddometer: 655
Not wanting to sound patronising but what is your kick/decomp routine?
Blog: XR650R.Blogspot.com
FB Page: https://www.facebook.com/BajaXR650R
Lostsaffa is offline   Reply With Quote
Old 12-14-2013, 02:35 PM   #18852
jules083
jules083's Avatar
Oddometer: 3,894
Don't worry about that, call me an idiot if you see fit.
1. Push kicker slowly until hard spot
2. Pull compression release, push kicker about 1". Usually 'clicks' at that point, but has a slightly different feel either way. Hard to explain
3. Release compression release
4. Stand up and give a full kick through
Is that right? Maybe it's just me?
Old 12-14-2013, 02:38 PM   #18853
jules083
jules083's Avatar
Oddometer: 3,894
For a compression test I just put the tester on and kick like neck right? Make sure I hit the compression stroke?
I can't get it to go above 90...
Old 12-14-2013, 02:41 PM   #18854
cognugget
cognugget's Avatar
Oddometer: 243
I have a video with an explanation in the description. http://youtu.be/aceUvQY3tIc
Plated XR650R
Old 12-14-2013, 02:53 PM   #18855
jules083
jules083's Avatar
Oddometer: 3,894
That's my exact method, except I give it a bit more ass on the final kick. I believe I saw your video a few years ago when I first got the bike. Whatever my join date here is, got the xr a few days later. Not a coincidence. Lol.
Times are GMT -7.   It's 11:33 PM.
