Old 12-19-2013, 10:56 PM   #18931
jm-2008
jm-2008's Avatar
Oddometer: 512
[QUOTE=Johann XR650R;23024295][QUOTE=mitchn06;22675718]I remember one time after I had the carb completely apart and struggled hardcore to start it. Ended up being idle screw being turned out way too far, even thigh it seemed right. Started at half throttle, the. I knew it was way off. That's all I got for you.
Good day Mitch.
I got the pig started! yeaha. but she then idles for a short while then dies. Could it be that the float level is off? its really freaky. Today i changed back to stock tank. then tried it again. Same story. started on second kick, idles for a about 1min then died. Now i cannot get her started! aarrrggghhh not sure what else to check.
is she maybe running too lean and this then heats her up? not sure 1min would not overheat her....
Mine will run for quite some time with the taps turned off - certainly more than a minute
Put a rag under the carby, take the float bowl cap off (inspect for foreign matter while it's off) and turn on the taps fuel should flow out freely.
If not find out why
If it does its doubtfull a float level issue
JM-2008
jm-2008 is offline   Reply With Quote
Old 12-20-2013, 12:17 AM   #18932
creedyflyr
creedyflyr's Avatar
Oddometer: 234
Rod's Pig
creedyflyr is offline   Reply With Quote
Old 12-20-2013, 01:38 AM   #18933
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=jm-2008;23029513][QUOTE=Johann XR650R;23024295]
Good day Mitch.
If not find out why
JM-2008
Cool thanx JM
I took carb off again today, checked for obvious airbox boot leaks. cleaned out all breather pipes, cleaned out jets and float needle seat.
I just had lunch, will start her afterwards, it feels like school final exams waiting for report card hoping that you passed. the proof will be a happy leg. i.e. she starts easily.
PS re-checked valve clearances again. was in spec.
Thank you all for advice will let you know shortly ( JM and Mitch) and the rest.
Johann
Johann XR650R is offline   Reply With Quote
Old 12-20-2013, 01:44 AM   #18934
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=creedyflyr;23029633]
Good job.
Well done she looks impressive!
Old 12-20-2013, 01:53 AM   #18935
Johann XR650R
Older, slower wiser
Oddometer: 22
Originally Posted by 1bigrn View Post
When I stand up for extended periods I find I have to bend over too far. As a result, Im looking at adding some hi-rise bars to my XR such as ATV bars with a 4.5" rise and perhaps a handlebar riser.
How high can I go before the cables need replacing?
Whats the highest other people are running?
I use Rox raisers the ones that pivot. If you just use std raisers it cramps the cockpit as the bars moves closer to you. you need something that will raise it and move it away from you.
rox-speed-fx-pivoting-handlebar-risers ( need to turn throttle so that the cables enter at the bottum instead of the top, to ensure stock cables reach.
See if can get the dealer to give you a trail run before buying it.
johann
Old 12-20-2013, 02:33 AM   #18936
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=Johann XR650R;23029741][QUOTE=jm-2008;23029513]
Originally Posted by Johann XR650R View Post
Cool thanx JM
Johann
YOOOYAAA! it worked she starts!
not sure what it was. it may have been the idle screw set to low. or it may have been a clogged breather hose! she runs! seemingly with no hick-ups! and restarts!
I cannot remember when i prayed so much for something to work!
Thank you all for advice!
Hope you all have a good week-end and post many riding pics. and trip reports on monday!
Johann XR650R! WOT!
Old 12-20-2013, 04:35 AM   #18937
mitchn06
mitchn06's Avatar
Oddometer: 547
[QUOTE=Johann XR650R;23029842][QUOTE=Johann XR650R;23029741]
Johann XR650R! WOT!
Awesome. I knew you'd get it! Now get out there and ride!!
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 12-20-2013, 06:29 AM   #18938
Bench Racer
Oddometer: 88
Originally Posted by cognugget View Post
I have gotten as much as 44 all street mpg.. and as low as 12mpg in the dunes
I run under 2000ft elevation.
175 main
68s pilot
Upgraded needle on 3rd clip
44mpg street
No bog
Sent from my SCH-I545 using Tapatalk
I would drilling holes in the side panel help? I really don't want to but if helps then I'll do it.
Bench Racer is offline   Reply With Quote
Old 12-20-2013, 06:33 AM   #18939
cognugget
cognugget's Avatar
Oddometer: 243
I don't believe that it's beneficial on a stock motor.
Plated XR650R
cognugget is offline   Reply With Quote
Old 12-20-2013, 06:34 AM   #18940
cognugget
cognugget's Avatar
Oddometer: 243
Both my truck wipers broke this morning had to take the xr.
Plated XR650R
Old 12-20-2013, 07:31 AM   #18941
crypto666
Oddometer: 1,276
Is that the police coming to take you away in the white van? I would assume so, because obviously you are nuts.
I did that once, rode to work in 20 degree weather. I was so cold and f'ed up by the time I got to work I was worthless the rest of the day.
crypto666 is offline   Reply With Quote
Old 12-20-2013, 07:34 AM   #18942
crypto666
Oddometer: 1,276
I think at 1.5" you will run out of cable, but that is basically just a guess.
I have mine bumped up a bit with risers and bigh bend bars. After some rerouting, I only needed longer throttle cables. The Motion Pro replacement cables are longer than stock and work.
Old 12-20-2013, 07:53 AM   #18943
cognugget
cognugget's Avatar
Oddometer: 243
That's one of the vans at work. I work at Sherwin Williams
Plated XR650R
Old 12-20-2013, 09:13 AM   #18944
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 536
I had to reroute the compression release after mounting risers,it was shutting the engine off.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 12-20-2013, 09:28 AM   #18945
crypto666
Oddometer: 1,276
Me too, I was a bit puzzled at first when the bike kept dying when making sharp left turns.
Times are GMT -7.   It's 01:10 PM.
