Old 01-07-2014, 10:10 AM   #19156
grego
Oddometer: 10
Originally Posted by RideFreak View Post
Grego, you got the hot start button, I think that would really help get the XR running after a fall.
yeah... not sure if the hot start and choke knobs are accessible with the tank on (got a clarke 4.3g fitted now but looking at getting a 7g IMS for long trips).
might have to convert them to cable operated.
i originally bought the 39FCR to use on my '81 XR500R. unfortunately it doesn't fit due to clearance issues between the throttle assembly and the frame.
i'll give it a bash on the XRR, as is, and see how it goes.
the guy who will be setting the bike up has dyno'd another XR650R with similar mods and a 41FCR... it will be interesting to compare results.
grego is offline   Reply With Quote
Old 01-07-2014, 11:51 AM   #19157
walkergreenlabel
Oddometer: 202
swingarm tool details
Originally Posted by mitchn06 View Post
Anybody see that swingarm tool that just sold on eBay for $66? Yikes!! Somebody didn't do their research!
anyone got details on making a set of tools? what size sockets do you need to use? i did a search but havent found the details yet...
thanks
walkergreenlabel is offline   Reply With Quote
Old 01-07-2014, 01:37 PM   #19158
mitchn06
mitchn06's Avatar
Oddometer: 554
13/16 inner and 1-1/8 outer there is a right up if you google "borynack xr650r" or something like that.
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 01-07-2014, 04:09 PM   #19159
LVCJT
LVCJT's Avatar
Oddometer: 235
Here is a link to the tools on Pig Pen http://www.xr650r.us/preload/
Sent from the depths of my pockets
LVCJT is offline   Reply With Quote
Old 01-08-2014, 09:02 AM   #19160
walkergreenlabel
Oddometer: 202
Thumb
thanks guys!!
Old 01-08-2014, 09:08 AM   #19161
mitchn06
mitchn06's Avatar
Oddometer: 554
I was way off! Haha. And I just made the tools two weeks ago too. I'm a dork.
Old 01-09-2014, 09:09 AM   #19162
mitchn06
mitchn06's Avatar
Oddometer: 554
There is an 11kg rear spring on eBay. Just a heads up!
Old 01-09-2014, 01:28 PM   #19163
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 476
The XR's only have found few HRC high compression pistons , they are pricey but very rare , so if you want one dont miss your chance .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 01-09-2014, 03:32 PM   #19164
snoslydr
woodsweapon
snoslydr's Avatar
Oddometer: 66
Anyone confirm FCR39 fits with acerbis 6.3 tank with no heat molding??
snoslydr is offline   Reply With Quote
Old 01-10-2014, 07:55 AM   #19165
dohcfox
meh
dohcfox's Avatar
Oddometer: 144
Good morning everyone...
So per my posts a couple of weeks ago, some of you might recall that my XRR had lost compression and that it was suspected that perhaps the auto decomp mechanism might have become stuck. It turns out that, because of really cold weather here in Washington state, my XRR's coolant temps were not getting up high enough to allow certain moving parts to get up to optimal operating temperatures. This caused oil to get past the piston and in to the combustion chamber, thus gumming up rings and valve seats. After a tear down and thorough cleaning, new gaskets, rings and fluids, she is running better than ever. To remedy the coolant issue, per another inmate's suggestion, I blocked off 75% of the radiators surfaces with a couple of pieces of cardboard. Morning temps on my commute in to work have been much better. Whereas before my temps were in the 110-120 (!) range, now I am running in the 160 to 170 range at 50MPH, and higher with traffic lights/stop and go stuff. So don't be a dumbass like me and not believe what your Trailtech temp sensor tells you, heh heh
All of that said, what temp range should my coolant be at, optimally? The 160s to 170s sure are a huge improvement, but should they be any higher, say, 180s?
During the tear down I did verify that my thermostat is working properly...
Thanks everyone!
JT
Ser decente no cuesta un culo y queda uno putamente bien!
dohcfox is offline   Reply With Quote
Old 01-10-2014, 08:50 AM   #19166
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,294
Thanks everyone!
JT
I recall my thermostat opening around 180 or so, so I am going with that as what Honda thinks the ideal running temperature for the motor.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is online now   Reply With Quote
Old 01-10-2014, 08:56 AM   #19167
mitchn06
mitchn06's Avatar
Oddometer: 554
As per the manual the stock thermostat will begin to open between 176-183.
Old 01-10-2014, 10:00 AM   #19168
dohcfox
meh
dohcfox's Avatar
Oddometer: 144
Thanks guys! I will make larger block off thingies to cover more radiator.
Old 01-10-2014, 12:18 PM   #19169
jm-2008
jm-2008's Avatar
Oddometer: 507
[QUOTE=dohcfox;23185302]Thanks guys! I will make larger block off thingies to cover more radiator.[/
Must be COLD your way
JM-2008
jm-2008 is offline   Reply With Quote
Old 01-10-2014, 01:05 PM   #19170
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
CR/F conversion tripleclamps are finished... finally. We just need to install a set to verify fitment. We're down in Morgan Hill, CA. Anybody in the south bay have an XR650R that we could borrow for an afternoon? Will hook you up with a $100 discount if you want to buy a pair of tripleclamps. Product and pricing info will be up on our website soon, but most of them are already sold. There will probably be a few sets left over, but not sure how many until we talk to everyone on the list.
jesusgatos screwed with this post 01-13-2014 at 12:56 AM
jesusgatos is offline   Reply With Quote
Times are GMT -7.   It's 09:18 PM.
