Old 02-02-2014, 12:46 PM   #19561
XRPOWER
Oddometer: 92
Side covers paint code!
Is it some one thats now the paint code for the clutsh and stator cover!
XRPOWER is offline   Reply With Quote
Old 02-02-2014, 01:40 PM   #19562
jimmyx
jimmyx's Avatar
Oddometer: 166
KILLER!
Photobucket Pictures, Images and Photos[/QUOTE]
"I'd rather have a bottle in front of me than a frontal lobotomy"
Dorothy Parker
jimmyx is offline   Reply With Quote
Old 02-02-2014, 01:41 PM   #19563
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Originally Posted by Kai Ju View Post
I ride mine exclusively on the street,, and get 42-48 routinely. Mind you, that's commuting on the freeway with the occasional canyon flog. My range on a stock tank is right at about 110-120 miles.
Strange carb indeed when I read about 23 mpg for some of you.
With the stock carb I saw worse mileage than my TRUCK once.
lstzephyr is offline   Reply With Quote
Old 02-02-2014, 01:54 PM   #19564
cognugget
cognugget's Avatar
Oddometer: 243
I get 43mpg on the street
Saw 12mpg at the dunes
Sent from my SCH-I545 using Tapatalk
Plated XR650R
cognugget is offline   Reply With Quote
Old 02-02-2014, 03:07 PM   #19565
npcaldwell
Oddometer: 27
FCR adapter?
Hey guys, I've finally decided to go for a Kehin FCR and have some questions. I've found a 41mm FCR from a 2006 CRF450R and want to put it on my 2003 XR650R and can't really figure out what adapter to buy to make it work.
I've read of guys making them or buying them from places like NOSS, Sudco, Power Barn what do you recommend using for the CRF carb?
I'm also running the HUGE IMS 7 gallon tank, any experience with this tank and the FCR carb would be helpful thanks.
npcaldwell is offline   Reply With Quote
Old 02-03-2014, 06:03 AM   #19566
dsilver1007
dsilver1007's Avatar
Oddometer: 372
Originally Posted by gallinastrips View Post
CR forks on an XR650R any problems with that? looking at buying a used one and wondering if that is a good conversion or something to stay sway from. Thanks
Talk to Mikie1 on ThumperTalk. Apparently he has done both and has some good insight.
If you cant ride it on one, ride it on two
dsilver1007 is offline   Reply With Quote
Old 02-03-2014, 06:26 AM   #19567
KASUYAHO
Road Hog
Oddometer: 3,789
Originally Posted by Sean-0 View Post
stock with a HRC tip
Disagree Sean-0.
I found with a larger dia header it gave the engine more low down torque,
as well as it let it rev higher.
KASUYAHO is offline   Reply With Quote
Old 02-03-2014, 10:36 AM   #19568
dsilver1007
Oddometer: 372
Originally Posted by kasuyaho View Post
disagree sean-0.
+1
Old 02-03-2014, 11:23 AM   #19569
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 634
Originally Posted by KASUYAHO View Post
Disagree Sean-0.
Well i found that with larger diameter headers you will loose some torque in the lower revs and gain some HP in the high revs , also have seen many Dyno run graphs and the OEM stock silencer with HRC tip was the best and smoothest .
And it still only revved till it hit the rev limiter so no difference at all , to hit higher revs you need highrev ECU .
But i might be wrong .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 02-03-2014, 11:44 AM   #19570
EsconDeasy
Ectomorph
EsconDeasy's Avatar
Oddometer: 1,501
ECU?
oh, and you spelled luze wrong
EsconDeasy is offline   Reply With Quote
Old 02-03-2014, 03:12 PM   #19571
PeteN95
PeteN95's Avatar
Oddometer: 2,941
Disagree Sean-0.
+1 I'm running a Leo Vince header with the stock can and HRC tip with a BD quiet insert. The header made more top and I didn't notice any loss down low.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 02-03-2014, 07:28 PM   #19572
pigjockey
Hognuts the T-bagger
pigjockey's Avatar
Location: wisconsin A half dozen miles from ROAD AMERICA
Oddometer: 1,021
New Pig owner in wisconsin
Finally got me a pig yippee! 2001 plated with a eddy carb, light kit, and the big gun exhaust. Also included like new set of ice tires by fournia. let the good times roll.
pigjockey is online now   Reply With Quote
Old 02-03-2014, 11:36 PM   #19573
XRPOWER
Oddometer: 92
And the frame!!!!!!
Old 02-03-2014, 11:40 PM   #19574
cognugget
cognugget's Avatar
Oddometer: 243
And the frame!!!!!!
Polish!
Plated XR650R
Old 02-04-2014, 01:18 AM   #19575
skolios
n00bee
Oddometer: 47
Congrats pigjockey! We want pics!
skolios is offline   Reply With Quote
Times are GMT -7.   It's 12:00 PM.
