Old 04-14-2014, 01:26 PM   #20536
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
Originally Posted by pwrtrippin View Post
So basically I use my Piggy for all types of riding from fast 2tracks to slow single track and everything in between. Last weekend was the second time I experienced my gas boiling and flooding me out with to much pressure to the carb. Anyone else experience this and what did you do to fix it? I'm thinking about ceramic coating and maybe heat wrapping the exhaust, then maybe heat shielding on the bottom of the tank since it seems to be the exhaust side that boils.
I've had the fuel boil and it's a little unnerving, you're thinkin, if this thing blows there goes my sex life
Shielding is good, fan is better if you can work it out with the electrics, it'll run all the time in those conditions though. I've never been a fan of wrap on a dirtbike for rust reasons but I hear it helps. Are you running a check valve or straight hose. Many of the caps have a check valve installed inside of the cap, toss it and the stubby little check valves. Run the plain old hose into your steering stem and the pressure issues will go away.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 04-14-2014, 02:26 PM   #20537
pwrtrippin
Oddometer: 437
I do like the idea Freak. I have had one day where it was boiling hard enough to pressurize even without the check valve. I thought of rust too but that was why I was thinking of ceramic coating first. Gas burns like hell when applied in liberal doses to your crotch. Had lots of slow going Friday on Golden Spike trail in Moab.
Me for a Politically Correct free America.
There is nothing manly about tassels.
pwrtrippin is offline   Reply With Quote
Old 04-14-2014, 02:58 PM   #20538
Keyz
Keyz's Avatar
Oddometer: 52
Blue hills west maryland
Present 2001 Bandit GSF1216N
Past 2000 XR650R 2009 DR650 2006 SV650N
Keyz is offline   Reply With Quote
Old 04-14-2014, 03:15 PM   #20539
crypto666
Oddometer: 1,276
Originally Posted by El Caballo Loco View Post
Thanks, I really appreciate your info. Is there a preferred XR650R head guru/machinist that can do a resleeve as well?
Don't resleeve, there is no sleeve oem. You want it replated. It is the better option.
crypto666 is offline   Reply With Quote
Old 04-14-2014, 03:18 PM   #20540
crypto666
Oddometer: 1,276
Originally Posted by DocAxeYarYar View Post
I know this sounds silly, but did you remove the small drain bolt that is just under the front down tube? There are two drain bolts, the larger one on the engine and the small one on the frame down tube.
The oil should drain instantly....otherwise you may have a gopher or tribble living in there....
A long time depending on temperature and pump wear.
Old 04-14-2014, 04:24 PM   #20541
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
That's one for your KTM
Chris
Old 04-14-2014, 07:17 PM   #20542
brayjay
Oddometer: 227
Advice
So I installed my head and instead of applying oil to the inside of the nuts as stated in the manual I used my finger and just smeared small amounts on the threads of the studs. Torqued down the head bolts to proper torque and all was fine. Then I noticed a little bit of oil squished out of the base gasket and head gasket after it was torqued. No doubt the oil ran down the studs and made its way there. Will this destroy the base and head gasket? Should I tear it down and use new gaskets?
brayjay is offline   Reply With Quote
Old 04-14-2014, 07:27 PM   #20543
zoro
Oddometer: 365
Don't worry bout that, all good
zoro is offline   Reply With Quote
Old 04-14-2014, 07:39 PM   #20544
brayjay
Oddometer: 227
I hope your right, The one side of the base gasket is wet. What a dumb thing to do!!
Old 04-14-2014, 08:27 PM   #20545
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
I often smear grease on paper gaskets and wipe them off good, they swell a little and next time it'll come off easier. Hasn't caused issues yet, I wouldn't worry about it.
Chris
Old 04-14-2014, 08:32 PM   #20546
brayjay
Oddometer: 227
Thank you both for your replies, stress now gone.
Old 04-14-2014, 09:18 PM   #20547
zoro
Oddometer: 365
I would consider a re-torque of the bolts once you've heat cycled the engine a few times.
This requires backing off the nut and running back to torque again, not just putting the tension wrench on it and checking its still tight- bad practice.
Old 04-14-2014, 09:55 PM   #20548
brayjay
Oddometer: 227
I was wondering about re torqueing and will. Another question. I have not installed the camshaft, top cover, or right crankcase cover yet and it seems to have hardly any compression. I can turn it over with 2 fingers darn near. New piston and rings. Should it not make compression even with no cam or top cover on yet?
Old 04-14-2014, 10:04 PM   #20549
zoro
Oddometer: 365
Was the head done up also? Re-valves and seats etc?
Is the spark plug in the hole?
Assuming all is good up top, just keep putting it all together.
Once run in, try and turn it by hand..
Old 04-14-2014, 10:19 PM   #20550
jm-2008
jm-2008's Avatar
Oddometer: 512
[QUOTE=brayjay;23936616]I was wondering about re torqueing and will. Another question. I have not installed the camshaft, top cover, or right crankcase cover yet and it seems to have hardly any compression. I can turn it over with 2 fingers darn near. New piston and rings. Should it not make compression even with no cam or top cover on yet
brayjay
Assuming the head is fitted with no spark plug and no cam it will be easy to turn over.
If the head is on and torqued down with spark plug installed you will not be able to turn it over with two fingers.
With cam and rockers in place you will need significantly more effort turning it over (even without the plug installed) as you will be compressing the valve springs.
Hope this helps.
JM-2008
jm-2008 is offline   Reply With Quote
Times are GMT -7.   It's 12:35 AM.
