Old 05-07-2014, 10:04 AM   #20911
mitchn06
mitchn06's Avatar
Oddometer: 554
Brayjay, I keep getting confused on your wording. Is it a scratch or a deposit? You said that it isn't a gouge, but is a scratch? To me those are the same. Were you able to wipe the line clean with brake clean or anything? I have a hard time thinking it was a bent ring. Was the oil scraper ring lined up right? Is it possible the separator ring (the wavy one) got overlapped on install? Or a compression ring got put on upside down? Or top and second ring got swapped? These are just ideas. Something to look at. I'm sure you studies the fsm like I did on re-assembly, but who knows.
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 05-07-2014, 10:58 AM   #20912
brayjay
Oddometer: 226
There is no material removed from the cylinder so it's not a gouge. If i run my fingernail over the scratch thing i can feel a bump so i would say it is a deposit. Regarding the seperator ring , before i installed the rings i tried to make the seperator ring overlap on purpose just to see if it could happen and could not make it overlap. There is just not enough room for it to overlap. Both of the top rings were installed with the marks facing up , smaller ring with the R mark on top and the larger one with the RN mark on second ,both marks facing up. IN mark on piston facing the intake.
brayjay is offline   Reply With Quote
Old 05-07-2014, 12:17 PM   #20913
El Caballo Loco
Pants-free living!
El Caballo Loco's Avatar
Oddometer: 450
Originally Posted by cragdweller View Post
I just meant that the XRR gear ratios are closer together than optimal for a do-it-all bike. It would be nice to have a lower first or a taller fifth, with the other ratios nicely spaced in between. If the TRX 1-4 are lower than the XRR 1-4, that would address the issue. Good luck, keep us posted if you learn anything.
Ah, thanks for clarifying. I didn't know if there was some issue I was unaware of, other than the overall ratios.
El Caballo Loco is offline   Reply With Quote
Old 05-07-2014, 12:18 PM   #20914
El Caballo Loco
Pants-free living!
Oddometer: 450
Four Strokes Works header....any thoughts/reviews/opinions?
Old 05-07-2014, 01:50 PM   #20915
crypto666
Oddometer: 1,264
Is that $150 per header or pair? I went with the XROs, and my only complaint is the ease at which I was able to deform the stainless flanges.
I would assume that either brand will increase top and lose low. I didn't notice a difference.
crypto666 is online now   Reply With Quote
Old 05-07-2014, 02:05 PM   #20916
El Caballo Loco
Pants-free living!
Oddometer: 450
A guy replied to my WTB ad in the big flea market with one. I'm waiting to hear back from him.
I can't find diddly about the dang things.
Old 05-07-2014, 02:09 PM   #20917
XRPOWER
Oddometer: 90
Funn parts!
Here is my lighter flywheel an a kush sprocket,this is gona be a funn to try!http://Photobucket Pictures, Images and Photos
XRPOWER is offline   Reply With Quote
Old 05-07-2014, 02:14 PM   #20918
El Caballo Loco
Pants-free living!
Oddometer: 450
Ahhhhh, good tobacco. I miss you Europe.
Old 05-07-2014, 03:56 PM   #20919
skolios
n00bee
Oddometer: 44
Anybody know if the heidenau k60 scout will mount up and fit in the 140/80-18 size?
I just fit one on mine last weekend. Excel rims on this one, fits nicely through the swingarm.
I'll take a pic in the weekend if you want one.
skolios is offline   Reply With Quote
Old 05-07-2014, 03:56 PM   #20920
mitchn06
mitchn06's Avatar
Oddometer: 554
Ya. That would be great. Thanks
Old 05-07-2014, 06:04 PM   #20921
Kai Ju
Kai Ju's Avatar
Oddometer: 1,836
I believe you mentioned that it started smoking at the end of your ride but there was no loss of power.
Looking at that mark in the barrel I'd be curious to see what shape the expander ring is in for the oil control rails. Almost looks like the expander may have broken at the gap, allowing the ends to overlap which would keep the scrapers from doing their job.
If you can't feel a groove you might not even have to replate the bore, just replace the oil control rings and their expander.
Kai Ju screwed with this post 05-07-2014 at 06:04 PM Reason: ESL
Kai Ju is online now   Reply With Quote
Old 05-07-2014, 07:22 PM   #20922
Keyz
Keyz's Avatar
Oddometer: 52
I agree with this. I rebuilt an xr100 and the cylinder jug looked like it went through hell and back but didn't have any indentations that you could feel, only replaced rings and most of top end (valves were bent somehow), started bike first kick after rebuild and haven't had any issues since.
Present 2001 Bandit GSF1216N
Past 2000 XR650R 2009 DR650 2006 SV650N
Keyz is offline   Reply With Quote
Old 05-07-2014, 08:38 PM   #20923
brayjay
Oddometer: 226
Thanks. I looked real close at the expander ring and can't find anything wrong with it. Gaps are perfect. Does it matter which way the expander ring is installed as in facing up or down? I looked at the top two rings with magnification and the one with the RN markings has some wear at the gaps and on that ring there is a silver coating of some sort all the way around it on the side where it would contact the cylinder , and it is worn off at the gap area down to shiny metal. Gotta be the ring that caused the problem but why? I just took a closer look at the cylinder and the vertical mark runs all the way to the top of the cylinder so it's impossible for it to be caused from the bottom three rings. Has to be from the top two.
brayjay screwed with this post 05-07-2014 at 08:49 PM
Old 05-07-2014, 09:02 PM   #20924
brayjay
Oddometer: 226
This will make things easier to explain. The piston is in the cylinder facing the right way and that is the top of the cylinder. The mark goes right to the top. Where the mark is must be where one of the top rings migrated after it was ran because I had the top one facing the intake and the second one down from the top towards the exhaust but why would that matter? It has to be the ring marked RN. Improper ring end gap?
Old 05-08-2014, 07:26 AM   #20925
zoro
Oddometer: 353
I wonder if its piece of chrome that has dislodged from the top ring and smeared itself down the bore?
Have never seen that on any engine, ever...have now.
Definitely a problem with the top ring looking at the height.
Does anyone know if the rings are chromed?
zoro is offline   Reply With Quote
Times are GMT -7.   It's 07:32 AM.
