Old 05-13-2014, 08:50 AM   #21001
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,055
If you ride enough you will find out how it feels to have ice cold rain water dump down your crotch!
Sent from my DROID RAZR HD using Tapatalk
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 05-13-2014, 10:15 AM   #21002
El Caballo Loco
Pants-free living!
El Caballo Loco's Avatar
Oddometer: 447
Originally Posted by MCVL View Post
I would only consider a new triple if it's from a crf with forks
Not sure what it will give me though, more often seals replacement for sure
Just a theory and one that comes from a lot of different trains of thought but it may give you not as nice of a ride or, depending on how/what you ride, a cracked or broken frame.
Not that there's any evidence out there to say one way or the other. Just a theory.
El Caballo Loco is offline   Reply With Quote
Old 05-13-2014, 10:37 AM   #21003
crypto666
Oddometer: 1,231
Originally Posted by babuja View Post
I'm installed a aftermarket skidplate.
It's working great, very resistant but hard to aplly/remove.
Everytime i do a oil change or for proper cleaning/whashing it has to be removed.
Last time i've damage rear nuts so maybe i'll install a time-sert to solve the problem.
My question is, can this be done? Because nuts are on engine case and could make a hole to long and punch it.
Tnks guys
Not sure what you are saying. Are you saying you are going to repair the threads with a timesert and then use longer bolts?
It is a pain, I have the same skid. But, like everything else, it gets better with practice. My bolts are about 1" long. Sometimes, when I am in a hurry I will change the oil with the plate on, and then just use air filter or chain cleaner to cleanup.
However, you need to be removing your plate frequently anyhow to get rid of the weeds seeds, sticks and rocks that collect there.
crypto666 is offline   Reply With Quote
Old 05-13-2014, 10:41 AM   #21004
crypto666
Oddometer: 1,231
If you are within a few miles of home, I found that the cold crotch can be warmed again. Just make sure your paints aren't tucked in to your boots so that the self-produced warming fluid can drain.
Old 05-13-2014, 11:37 AM   #21005
S-TrackJunkie
Shut up and dance!
S-TrackJunkie's Avatar
Oddometer: 557
Valves nice and quiet now....pulling the mag cover made it much easier! DOH! I have 1 week to get this fawker back together....it's go time!!
S-TrackJunkie is offline   Reply With Quote
Old 05-13-2014, 11:46 AM   #21006
S-TrackJunkie
Shut up and dance!
Oddometer: 557
Originally Posted by Travis1010 View Post
Im looking to get some risers to move my bars forwards and up as im 6 3" and is just to short. I dont do to much hard riding so was looking at the ROX Risers? What is that triple clamp that people keep talking about? Ive looked but cant find it.
I am 6'5", and use these:
http://www.rswracing.com/xr650r.htm
I got the 3" risers, and have them in the full forward position. It is the first time in 12 years of ownership that I can stand up, and not have to bend over to keep the bars in hand. It made lofting/lightening the front over obstacles much easier, not that it was too hard, but it made it considerably easier. I feel a lot more comfortable on the bike now, because it actually fits me! Mounted very easy, and they are well made, especially for the price. HTH!!
Old 05-13-2014, 11:48 AM   #21007
crypto666
Oddometer: 1,231
I should have told you sooner, but there is an old mechanic trick to quieting valves; pack the head with saw dust. It makes it really quiet, for a while, long enough for the seller to leave town.
Glad you are getting your fawker squared away.
Old 05-13-2014, 12:00 PM   #21008
S-TrackJunkie
Shut up and dance!
Oddometer: 557
Works better than you think...
Old 05-13-2014, 12:35 PM   #21009
babuja
babuja's Avatar
Oddometer: 353
Correct...but i'm afraid to drill to long and
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 05-13-2014, 01:37 PM   #21010
ADVSearcher
ADVSearcher's Avatar
Oddometer: 131
Originally Posted by shimazaki View Post
Do you need to install steel rear subframe and rear foot pegs for using the giant loop?
Depends ... we are going light to not interfere the bike handling to much.
I'm 85kg with gear and the pig is rated for 90kg total load so ... Have the Coyote just were the saddle ends, half on & half off & will only bring sleeping bag, a couple t-shirts, underware & socks, a thicker sweater, shorts & longpants, shoes, tools for a tire repair, extra gloves & goggles ... that's it, will mainly live in my KLIM suit . Will not overload it by much.
We will eat were we can find food & and pop out to the civilization for a nap in hostels ... so you don't need so much for a week's drive ... the Baltic aren't a desert were you have to bring everything
Have a Beemer F800GS also, on that I can stuff the Coyote full.
Rear footpegs not neccessary, tigh the lower straps to were the sub attaches to the frame or directly to the frame ... to make it easier I attached loops like below to the subframe bolts.
ADVSearcher screwed with this post 05-13-2014 at 01:47 PM
ADVSearcher is offline   Reply With Quote
Old 05-13-2014, 05:20 PM   #21011
Keyz
Keyz's Avatar
Oddometer: 52
Hey guys - looking for a Garmin 60csx touratech/RAM mount. Anyone? PM me
Present 2001 GSF1200N
Past 2000 XR650R 2009 DR650 2006 SV650N
Keyz is offline   Reply With Quote
Old 05-14-2014, 07:22 AM   #21012
S-TrackJunkie
Shut up and dance!
Oddometer: 557
My Piggy is alive with pleasure!!
I have a minor dishing issue with the freshly re-spoked front wheel that is getting looked at today, and put the bash plate back on, but otherwise, Houston, we are go for throttle up!
Old 05-14-2014, 08:18 AM   #21013
crypto666
Oddometer: 1,231
Your plate isn't bolted to the engine case is it? It should clamp to the frame, right?
So you could drill out the clamp with it completely removed from the bike, perhaps in a vice of some sort. Or am I missing something?
I found the trick is to not disturb the clamps once you unbolt it. Most of them will stay put and aligned for putting the plate back on. The bugger is always the front bolts for me.
Also, I thread each bolt on by hand and get them all started with a couple threads before I start tightening any of them.
I hope that helps. Another option is to buy a replacement clamp to replace the stripped one.
Old 05-14-2014, 08:19 AM   #21014
crypto666
Oddometer: 1,231
Give us a report on how the MT43 holds up. That is a MT43 pro-trials on the rear isn't it?
Old 05-14-2014, 09:01 AM   #21015
S-TrackJunkie
Shut up and dance!
Oddometer: 557
No, it's a Dunlop 803, and they hold up ok. I got this one free, so I couldn't pass it up! I want to try the Pirelli DOT version. It's supposed to hold up a ton better, with a very slight loss of traction.
Times are GMT -7.   It's 04:14 PM.
