Old 05-16-2014, 06:28 PM   #21031
FlyingWman
FlyingWman's Avatar
Oddometer: 250
Originally Posted by Travis1010 View Post
Ok have a problem...I've driven about a hundred miles since I checked the oil and it's already not registering on the dipstick...no smoke at all and the spark plug is nice and clean and a light brown. I don't see any real leaks anywhere. Where is it going? I've never seen an engine use this much oil and not smoke...I even looked behind me while going down the road getting on and off the gas and nothing??? Help!!
Make sure your air filter is clean and crankcase vent hose is clear. Check countersprocket seal.
___________________
2000 XR650R
1982 GS750TZ
FlyingWman is offline   Reply With Quote
Old 05-16-2014, 07:28 PM   #21032
Travis1010
Oddometer: 22
When I got it oil was at about half and I added some and was perfect. I've only ridden 100 miles since...I don't see any leaks behind the countershaft at all and my chain would probably be covered...no oil coming from anywhere. Not even a hint of white smoke only a little bit of black if I rev it real quick...doesn't make since.
Travis1010 is offline   Reply With Quote
Old 05-16-2014, 07:37 PM   #21033
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
Check level after warmed up for 15 min or at end of day
Sent from my DROID RAZR HD using Tapatalk
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 05-16-2014, 07:39 PM   #21034
FlyingWman
FlyingWman's Avatar
Oddometer: 250
If you are trully unsure of what your oil level is and are concerned about buring it, drop your oil right now and measure how much comes out. Oil is cheap compared to a rebuild . You may be over or under, but ensure your oil check routine is correct before adding any more. If I ever have a hint of doubt I drop it all, why be worried when you can reset it to where you know it should be in a matter of minutes? Just installed an oil sight line for this reason, piece of mind can be worth alot
___________________
2000 XR650R
1982 GS750TZ
Old 05-16-2014, 07:58 PM   #21035
Travis1010
Oddometer: 22
I plan on dropping the oil tomorrow...due for an oil change anyway...I'll probably pull the valve cover also to check for rocker wear as don't know history from previous owner. Hopefully they look good...and haven't ran low on oil. If it is truly burning oil I'll guess I'll have to pull the head and check for wear on cylinder and if it looks good out some new rings and valve seals in.
Old 05-16-2014, 08:03 PM   #21036
FlyingWman
FlyingWman's Avatar
Oddometer: 250
Valve clearance and camchain tenioner too?
___________________
2000 XR650R
1982 GS750TZ
Old 05-16-2014, 08:07 PM   #21037
seasider
Just a rider
seasider's Avatar
Oddometer: 388
Quick question...
Some how I endended up with too many bikes in my shed.....love my 2000 xrr and kdx 220 for what they are individually and have longer street/gravel covered with another bike.
So the question here is what if any could replace the xrr to take the place of both for the average dual sport and occasional single track weekend or baja style trip?
I have subscribed tothis thread for 2.5 years and its an education at the least. Now wanting to simplify a bit...can I do betteer than the xrr as a single track/adv bike?
Note.....no interest in the latest bikes and associated cost. I had a crfx 450 which was great but bitten by the xr bug traded it for the 650. Is there anything a 49 year old dude should consider in the place of the two mentioned?
Lost time is never found
seasider is offline   Reply With Quote
Old 05-17-2014, 12:21 AM   #21038
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,428
I have a FCR 39 MX off a Yz426. Thinking about slapping it on the pig. There might be a possibility that it could be too small, but would it offer any better response over the stock carb?
Should I perhaps have it bored out?
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 05-17-2014, 07:58 AM   #21039
Keyz
Keyz's Avatar
Oddometer: 52
Question about coolant levels:
Does the reserve feed into the radiator or is it the other way around and how do you gauge the reserve level correctly as the level floats up after engine is running?
Present 2001 Bandit GSF1216N
Past 2000 XR650R 2009 DR650 2006 SV650N
Keyz screwed with this post 05-29-2014 at 10:28 PM
Keyz is offline   Reply With Quote
Old 05-17-2014, 09:16 AM   #21040
pigjockey
Hognuts
pigjockey's Avatar
Location: wisconsin A half dozen miles from ROAD AMERICA
Oddometer: 617
Maybe its burping out an air bubble out of your radiators. prob the non filler one. Just a thought though.
pigjockey is offline   Reply With Quote
Old 05-17-2014, 10:20 AM   #21041
Travis1010
Oddometer: 22
Drained the oil and got a little over 1.5 qts. Probably around 1.6-1.7 but I spilled some so not sure. The rockers looked great how much does this thing hold? Plus there were no metal flakes or dust in the oil or on filter! Gonna monitor the oil level really close over the next 100 miles to see how much it's burning.
Old 05-17-2014, 11:52 AM   #21042
FlyingWman
FlyingWman's Avatar
Oddometer: 250
1.6-1.8 US qts.
___________________
2000 XR650R
1982 GS750TZ
Old 05-17-2014, 12:02 PM   #21043
Travis1010
Oddometer: 22
That doesn't make since cause I warmed it up and ride it for like 5-10 min and still didn't read...
Old 05-17-2014, 12:41 PM   #21044
FlyingWman
FlyingWman's Avatar
Oddometer: 250
Manual states 1.6 at oil change and 1.7 with filter. Their are free downloads of the manual online. Put in 1.7 Go for a nice ride, more than 10 minutes, turn off and check 15 seconds later.
Manual
___________________
2000 XR650R
1982 GS750TZ
Old 05-17-2014, 03:50 PM   #21045
Indiana Bones
Ride or Die
Indiana Bones's Avatar
Oddometer: 1,170
Question: What are your "normal" idle speeds? I'm sitting around 1800.
Sent from my Torque using Tapatalk
Sunday ADV...that's my church.
Indiana Bones is offline   Reply With Quote
Times are GMT -7.   It's 03:48 PM.
