Old 04-23-2010, 09:12 AM   #3991
Nasty1
Nasty1's Avatar
Oddometer: 64
Originally Posted by Ironwood
Has anybody installed this lowering link and tested the handling of the bike? It does sound interesting.
Joe
Has anybody lowered one at all by any means and could give me some feed back Or am I the only hobbit with a BRP ??
Adie
2009 Triumph Bonneville/Scrambler hybrid! Under Construction
Nasty1 is offline   Reply With Quote
Old 04-23-2010, 12:22 PM   #3992
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,357
Adie
If it works and you shave some foam out of the seat...... Good Luck.
joenuclear is online now   Reply With Quote
Old 04-23-2010, 01:35 PM   #3993
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,198
Adie
I installed the Kouba lowering link, it lowers the seat about 1~1.5 inches depending on how you set your sag up. I'm 5'10" with a 30" inseam, I didn't have issues with the XR's seat height on easy trails but when we ride the mountains it became a PITA when stopping on uneven ground.
If you're short like me and there's a 6" dip in the trail where you want to put your foot, the bike is leaned pretty far over before your foot even touches. Add a good bit of fuel up high and it's tough to stop the bike from going on it's side. I envy you 6' + guys
The LL helps but it's still a problem sometimes. The forks require adjustment (slid up 1" in the triple clamps) to maintain the bike's handling and the sag becomes very important. If both aren't setup correctly the XR doesn't want to turn, similar to the handling when the rear wheel is too far back. All lowering links are a compromise, you'll loose ground clearance and the bike's handling will suffer some. Despite that, it works for me, I'd rather give up a little in that area then to deal with the bike's seat height on uneven trails. The reduced ground clearance hasn't been an issue and we ride on some fairly steep rocky steps. I scrape it ocassionally but that's about it. I don't take the pig over huge jumps where every bit of travel is essential so the travel hasn't been an issue, I will say that if you're using all of your travel now you'll have the wheels kissing the fenders some.
Do I like the lowering link? Not really but if I want to ride the XRR on tough uneven stuff I need the lower seat height.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 04-24-2010, 07:57 AM   #3994
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,198
Everyone must be out riding
Just to remind you why we like the BRP.
Chris
Old 04-24-2010, 10:10 AM   #3995
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Originally Posted by Dave37
My bike is making noise again. Loud. I don't have time to go into detail right now but it ruined my day when I started it up to go to work and heard that! I just don't get it. I checked the oil afterwards and couldn't see any on the dipstick again, and it's not leaking! I've only put about 500 miles on it since I put the stage 1 hot cam in, and I changed the oil then! WTF. Going to check the valves tomorrow.
Bad day.
Check that you haven't got oil in the coolant system, otherwise it could be burning or getting blown out the crankcase vent. good luck!
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 04-24-2010, 12:30 PM   #3996
Nasty1
Nasty1's Avatar
Oddometer: 64
Originally Posted by RideFreak
The LL helps but it's still a problem sometimes. The forks require adjustment (slid up 1" in the triple clamps) to maintain the bike's handling and the sag becomes very important. If both aren't setup correctly the XR doesn't want to turn, similar to the handling when the rear wheel is too far back..
So what sag do you find works best with the lowering link??
Adie
Old 04-24-2010, 01:23 PM   #3997
Kiko
Kiko's Avatar
Oddometer: 1,838
I tried lowering links first (1.75") on a KLX400R, but the handling of the bike was terrible. Took them off and had a Race-tech shop install a spacer in the rear shock. An 11mm spacer will give you about an 1" drop in the rear, the ratio of the spacer thickness to the drop is about 1:4.
Maybe the more moderate lowering links like a .75" or 1.25" will satisfy you, but personally I would not waste my money.
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 04-24-2010, 01:33 PM   #3998
Nasty1
Nasty1's Avatar
Oddometer: 64
So, was the spacer in the shock better. Did it handle then?
Adie
Old 04-24-2010, 07:41 PM   #3999
Ironwood
Friday Harbor, WA
Oddometer: 755
DogLegPegs
After reading the StegPegz thread this morning I blew nearly the whole day making a set for my XRR. Here are the pics and a link to the other thread. I mentioned in that thread that if there was enough interest I would run a batch. The description is on the other thread.
http://www.advrider.com/forums/showthread.php?t=572723
[IMG]Left Side DofLeg[/IMG]
[IMG]Right Side DogLeg[/IMG]
Ironwood is offline   Reply With Quote
Old 04-25-2010, 08:23 AM   #4000
Clo-z-nuff
Oddometer: 51
"Dual Sport" switch is fried any recommendations
I've got what I believe is an older Baja Designs kit on my 2000 XRR and the headlight portion of the switch is fried. What would you recommend as a replacement. Is there a "plug and play" replacement? I'm attaching a pic but don't know how it will turn out...sorry if it's crappy. The switch has a slider for light off/on/low/high a separate horn button, separate turn signal button and kill switch. The new Baja Design switches seem to be different.
Clo-z-nuff is offline   Reply With Quote
Old 04-25-2010, 08:24 AM   #4001
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,604
Just order the new switch from BD. It'll work.
2k4 Wee-Strom, black, farkled, smells like bacon.
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
brad21 is offline   Reply With Quote
Old 04-25-2010, 10:12 AM   #4002
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I just spotted this on craigs list, thought it was pretty ingenious.
http://denver.craigslist.org/mcy/1706355694.html
Old 04-25-2010, 10:30 AM   #4003
Ironwood
Friday Harbor, WA
Oddometer: 755
I saw that too. Takes the XRR to a whole new level. J
Joe
Old 04-25-2010, 11:53 AM   #4004
header
Chris
header's Avatar
Oddometer: 1,746
Joe
Deffinatly a new level, dont know if its a higher level or lower level
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 04-25-2010, 12:14 PM   #4005
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
I'm going to build a small Burley-type two wheeled trailer so I can haul my dogs around...
jesusgatos is offline   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
