Old 11-27-2008, 11:02 AM   #31
Stevevh
Kudu Driver
Stevevh's Avatar
Oddometer: 283
Originally Posted by XR650Rking
Let us know what your brother plans on doing to his XRR? Maybe we can pass on some other ideas?
Ok, here is the start of the new farkles. Man have I spent a lot on this beautiful piggie.
Not finished yet but pics soon.
Kenaroo Dakar fairing (still coming)
Zeta billet clutch perch with hot start/decomp
Zeta brake and clutch pivot levers (kickass!!!!!)
Kellerman LED bllinkers!!(Serious $$$$ but bright!!)
Cycra solutions mount with black handguards!
Rox risers
BRP Tripple clamp
Edelbrock carb!
Trying to get a descent billet aluminum handlebar switch custom made with descent water proof switches for D/S bikes. (anyone else interested?)
TT GPS ultra shock mount.
Zumo GPS.
Finally put the SS braided brake lines on front and rear.
KTM radiator fan mod. Looks factory!!!
Radiator guards.
Putting the big Acerbis back on upgraded the petcocks to the clark billet ones.....very nice.
Upgraded fuel hoses with inline filters.
Thats all I can think of for now. I will add more info plus pics in the near future. Stay tuned!!
Steve
Stevevh is offline   Reply With Quote
Old 11-27-2008, 11:06 AM   #32
FOCKER
Northwest Adventure Rider
FOCKER's Avatar
Oddometer: 154
Originally Posted by Hodakaguy
Graet Idea.
Inmate Focker also started a XR650R forum in hopes of sharing the same info. Here's a link to the Xr forum: http://hondaxr650r.forummotion.com/
Not a substitute for ADVrider but still a great place to share info.
Hodakaguy
The invitation still stands...
FOCKER is offline   Reply With Quote
Old 11-27-2008, 01:06 PM   #33
pavemike
I fall down alot
pavemike's Avatar
Oddometer: 336
Tell us about it? why was it in storage? what was done before storage? What is required now, stock carb or edelbrock?
Your buddy is in for a surprise! I've never raced one...but I've ridden the DRZ400...and I wasn't too impressed in comparison!
Got military orders to England in '02. Bike ran great when I put it into storage. Flash forward to '07, back in the good 'ole USA, got the bike out of storage and let it sit in my garage until about a month ago. Started with the basic maint, 2 new tires (old ones dry rotted), chain/sproket change (stayed with stock gearing), replaced brake pads/brake fluid, flush fill radiator, check valve clearance (still perfect) and a fresh oil change and filter change. Got around to giving the carb a good cleaning and re-jet since I'm now in Albuquerque NM (5300ft). Realized that I didnt get all the fuel out of the carb last time I shut her down before storage . I stripped the carb down and cleaned for about 2 hours, then tried to re-jet. Then I relized that last time I re-jetted, I must have stripped out a few of the screws. After fighting with the screws for awhile I finally said F-it. Now i've always had problems with the stock carb, could never it get it jetted correctly. I was tired of kicking the thing 10+ times to start and having it flood on me when I tipped over. So I bit the bullet and ordered an Edelbrock last week. Should be here on Monday, so hopefully I will be giving the BRP her first good ride since '02.
pavemike is offline   Reply With Quote
Old 11-27-2008, 07:02 PM   #34
DOSCERVASAS
neck
DOSCERVASAS's Avatar
Oddometer: 220
Springs
Those that have swapped your springs...what wt rating spring are you using for your size? I'm 180 on a heavy day but thats without gear... but looking at the chart that bruce put together...http://borynack.com/XR650R/Cycle/suspension.htm (middle of page)...should I stick with stock because I usually use the bike for play riding and commuting...rarely with overnight gear which would put me into the 200lb range?
Just planning what I need to rebuild and set up my suspension.
JT
I went to racetech.com, and they have a calculator that will ask you three or four question, weight, riding stile, and some other shit. It told me, 240lb fat ass, 49 front and 12 rear. I called a couple of places and they told me the same thing.
"Just some ass hole trying to ice skate up hill"
"Another Day, Another poor soul left in my Dust"
DT-100
XR-650R
VTX-1800
DOSCERVASAS is offline   Reply With Quote
Old 11-28-2008, 09:46 AM   #35
kenaroo
I am because i ride
kenaroo's Avatar
Oddometer: 839
Steve
Steve:
Your fairing was shipped on Monday.. so it should be there any day..
on the custom handle bar switches I have found two sources for nice quality billet bar switches. now affordable? depends.. they run around $50 to $100 but are super trick
Pingel handlebar controls: http://www.pingelonline.com/handlebar_controls.htm
Pro Buttons: http://www.mpsracing.com/products/MPS/Probutton.asp
I haven't ordered from these guys yet but I will be soon as I need more switches for all of my electrics
what does your garage look like
http://www.garage-interiors.com
kenaroo is offline   Reply With Quote
Old 11-28-2008, 04:44 PM   #36
Stevevh
Kudu Driver
Stevevh's Avatar
Oddometer: 283
Originally Posted by kenaroo
Steve:
Looked at Pingel switches before but don't like the chrome.
The MPS look nice and if I can't come up with a solution might go with 2 switches. It is a real pity that there is not a super strong waterproof switch out there with 2 toggle switches and a button all housed in one.
Old 12-01-2008, 09:26 AM   #37
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,571
I think I'm the third owner of my '00 BRP. Not sure if the clutch bushing has been replaced. Yesterday while doing some bushwhacking and hammering the clutch the bike started getting a little noisy and stalling on me with the clutch in. I'm also due for an oil change.
Question: is this a bushing symptom or did I just overheat the clutch with old oil?
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
BRC Member #49252 JOIN TODAY! https://www.sharetrails.org/support/join-or-contribute
brad21 is offline   Reply With Quote
Old 12-01-2008, 10:03 AM   #38
JustinT OP
I will ride my whole life
JustinT's Avatar
Oddometer: 949
I haven’t had an issue with the Bushing, I replaced mine with the upgraded OEM part but from what I have heard it doesn’t sound like yours is a FULL BLOWN bushing issue where the bushing seizes on the crank causing you to NOT be able to disengage the clutch? I guess it could be boarderline starting to fail? If you are unsure, its an easy/cheap part and probably wouldn’t hurt just for peace of mind. Doesn’t sound like worn clutch where it slips either so I would check it out and replace it and the staked nut when you have it off. Then you can examine your clutch while its apart.
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 12-01-2008, 11:25 AM   #39
DOSCERVASAS
neck
Oddometer: 220
Help
could some of ya'll look at the KTM 690r vs XR-650R for hard core adventure thread, and help explain why the BRP is proven over and over why it is better
DT-100
XR-650R
VTX-1800
Old 12-01-2008, 01:23 PM   #40
kenaroo
I am because i ride
kenaroo's Avatar
Oddometer: 839
Is it proven or does it just have more history??.. Give the KTM it's time and I'm sure it will prove it's self just fine.. of course I love my XRR
Old 12-01-2008, 01:27 PM   #41
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,107
Sorry, I think I'll stay out of that match. I love my BRP....But those orange machines are Suweeeeet also.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 12-01-2008, 06:24 PM   #42
DOSCERVASAS
neck
Oddometer: 220
Orange Crush
Hodakaguy
have you road one, I am not going to call you a cheater, and how do they ride.
And NO, I am not giving up my BRP
DT-100
XR-650R
VTX-1800
Old 12-01-2008, 06:26 PM   #43
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,107
Nope haven't even rode one yet I really like the looks of the 530...just cant chunk out that kinda cash for a bike. I'll stick with my BRP...It really is a AWSOME ride.
Hodakaguy
Old 12-01-2008, 06:48 PM   #44
DOSCERVASAS
neck
Oddometer: 220
Your Head Light
Hodakaguy
While I got you, is your head light HID or Halogen?
And did you have to rewind your stator?
If so, did you have to up grade any thing else?
sorry for all the questions
DT-100
XR-650R
VTX-1800
Old 12-01-2008, 06:56 PM   #45
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,107
No problem on the questions, thats what the forum is for. The light is the halogen unit. I have a Ricky Stator in the garage for the bike, just haven't installed it yet. Right now it only has the 35w bulb in it, after the Ricky install I'm going to run a 90W or so bulb in it and run the light directly off AC. Right now its all stock except the light unit. Since this light doesn't have a high beam I used the high beam switch to run the KTm radiator fan that I installed.
Hodakaguy
Times are GMT -7.   It's 07:39 PM.
