Old 08-18-2010, 08:28 AM   #5116
zaptoad
just a guy
zaptoad's Avatar
Oddometer: 301
an eye to the weary
talking about reflectors, license plate lights, etc, etc......
http://usridernews.com/2010/08/12/nh...y-checkpoints/
With an Idaho registration, the XRR's have "not necessarily street legal" printed right on them in bold letters. This always makes me nervous about getting stopped any time, any state, so I ride very carefully on the street. I have been modifing my bike to look more like a real street bike all the time so as not to raise suspicion. I am even planning on converting to a low front fender(UFO Superbiker in black) this winter. However, with bull stops just targeting bikes, we don't have a chance.
zaptoad is offline   Reply With Quote
Old 08-18-2010, 09:17 AM   #5117
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,863
Originally Posted by baja_brewer
Thanks! I've seen that, I'm just trying to wrap my head around it....
Looks like I'd go:
Main jet- 175
Needle clip- 3 down from top
Pilot- 68s or 70
I imagine I'll be better once I get some hands on time working on the bike!
175 is too rich at sea level unless you have the airbox cover opened up.
I'm at sea level.
Main-165
53E needle-clip 2 down from the top
Pilot-68s
Closed airbox
larryboy is online now   Reply With Quote
Old 08-18-2010, 10:02 AM   #5118
baja_brewer
baja_brewer's Avatar
Oddometer: 23
I'm at sea level.
Main-165
Pilot-68s
Closed airbox
Thus why I'm asking, thanks for the help! I've yet to pick up a new one, but I've been told they're cheap, so I can always mess around with it once it gets colder out.
baja_brewer is offline   Reply With Quote
Old 08-18-2010, 11:45 AM   #5119
cdogg44
Oddometer: 209
Originally Posted by windquest
Welcome! If the bike is uncorked the following will apply:
Main jet- 170, 172, 175 (this should cover you from 80-60 farenheit)
Needle clip- 3 down from top (this is with a B53E needle)
Pilot- 68s
What main jet would you recommend for me?
I have a 68s, 53E needle at 3rd clip, stock Honda air filter and cover, drilled stock exhaust, XR's Only smog block off kit.
Ambient temps here are 90-100+ and I'm at 450-500'.
I've got a 175 in it right now but think I'm running a bit rich. Am I correct in thinking that I need a bigger main jet the cooler the ambient temp is? Does humidity play any factor in jetting?
cdogg44 is offline   Reply With Quote
Old 08-18-2010, 12:57 PM   #5120
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
I'm at sea level.
Main-165
Pilot-68s
Closed airbox
I'm at 1000 ft
Main-178
Needle is at 1st clip
pilot-68s
Open airbox, white brothers pipe
All these bikes are different really, the jetting just gets you close. So might as well throw as many working setups as possible out there.
You mention 53E needle, are there a lot of needle available? I didn't know that was something I could swap for tuning. Can anyone explain the effect of the needle change to me?
With carbs you are adjusting the main jet to air density. Altitude, temperature, humidity(I think), all affect it. So if its way hot out lower your jet, if its cold put a bigger jet in, if you go up in altitude smaller jet, down in altitude bigger jet. For example, I was running a 155 main at 8k feet and 85 degrees or so, I ran a 185 main at 1k ft and 85, and now run a 178 at 1k ft and 100 degrees. Does that make sense?
lstzephyr screwed with this post 08-18-2010 at 01:03 PM
lstzephyr is offline   Reply With Quote
Old 08-18-2010, 10:41 PM   #5121
Daveoz31
Daveoz31's Avatar
Oddometer: 69
Hey Guys I have a few problems with my pig..
One. it has a nasty Wobble through the front end around 100 klms I have checked and changed a lot of things on the bike like tyres and pressures checked swing arm bearings steering and no play anywhere the steering is very light... anyone out there with similar probs or remedies?
Two. Is there a tank bag that suits the bigger tank I have fitted?
[FONT='Fixedsys','serif']Just waiting for the next opportunity to get out of this office and go for a ride.
[/FONT]
Daveoz31 is offline   Reply With Quote
Old 08-18-2010, 11:19 PM   #5122
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,863
Originally Posted by lstzephyr
I'm at 1000 ft
Main-178
pilot-68s
The key on your jetting is the open box, close that and it'll be way to rich.
I've been taping the airbox for riding down here at sea level and it's just a tick lean with the 165 main. I don't ride the 'R much down here and 10,000 feet is within a couple hours. It's nice to be able to pull the tape around 4500 feet and be good to go up to 12,500 feet, it was even a one kick to get going over 12k.
Different needles have different tapers to them. I've got three different ones and for performance the 53e works the best, I could probably pick up some mpg's with the stock needle.
I think the 53E needle was devoloped by HRC for Baja, others here know more about that stuff than I do.
Old 08-19-2010, 01:25 AM   #5123
KASUYAHO
Road Hog
Oddometer: 3,641
170 main jet is what i would go.
We use the needle to fine tune the air fuel mixture,
raise clip, lowers the needle, makes it leaner.
Lower clip, raises the needle, make it richer.
Yeh bigger main jet is needed as the air gets cooler, cooler air is more dense, more oxygen in the air.
Yeh humidity does play a part in jet sizes, more humidity a smaller jet is needed.
More moisture in the air, less oxygen, smaller jet.
What i do is soak the carby over night in solvent,
unleaed fuel forms a film of gum inside the carby.
Note: take out the aircutoff diaphram as solvent swells this diaphram.
KASUYAHO is offline   Reply With Quote
Old 08-19-2010, 04:30 PM   #5124
BigToad
The Bone Destroyer
BigToad's Avatar
Oddometer: 196
Did you balance the front tire when replacing the tires? I had a similar problem that was eliminated by balancing. Also check the spokes and the rim to see if its true....
good luck!
R1200 GSA
XR650R dualsport/Rally Trainer
We should come home from adventures, and perils, and discoveries every day with new experience and character
BigToad is offline   Reply With Quote
Old 08-19-2010, 05:19 PM   #5125
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,129
I'm running a 165, open airbox, and HRC tip, it's a little lean at 5500' and worked nicely up to 13,600', slightly rich up that high but it's not like I could haul ass over some of those peaks
I've noticed the way you service the air filter and the oil you use makes a noticeable difference. The no toil stuff is thinner and gives me a slightly leaner mix while the Bellray is thicker and the motor runs a little richer. Also an extended ride (2~3 days) on the same filter will start to pull some of the oil out of the filter causing it to lean out a bit. I don't have an issue with it getting clogged up with dust, it's just the opposite.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 08-19-2010, 06:17 PM   #5126
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,256
RF...what kind/brand of air filter are you using on the BRP?
Has anyone had problems with the BRP allowing fine dirt into the air box no matter how well you service and seal the air filter element? I've tried three different brands of filters and greased the edges, serviced the hell out of the filters and still seem to have a fine, fine layer of dust on the inside of the air box each time the filter is removed. Prematurely wearing the intake valves too. WTF!
NMTrailboss screwed with this post 08-19-2010 at 07:38 PM
NMTrailboss is offline   Reply With Quote
Old 08-19-2010, 08:13 PM   #5127
AKASY
Noob
Oddometer: 2,168
Air Filter
Me three--same issue, dumped the K&N and I'm now back to the original filiter. I think it has to do with the side panel being opened up--if I can ever find an unmolested one I will get it and see how that works.
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Old 08-19-2010, 08:52 PM   #5128
badcooky
I see dumb people!
badcooky's Avatar
Oddometer: 1,129
I use a Twin Air filter doods.
The mighty XR650R.
The old trail bike that all modern trail bikes are judged by.
It's funny cause it's true!.
badcooky is offline   Reply With Quote
Old 08-19-2010, 09:10 PM   #5129
mung
Oddometer: 606
Airbox
The r has a very poor seal no matter what you do. I coat the entire inside of the airbox with a thin layer of grease so that the dust that does get by has a very good chance of sticking to the grease on its way through. Then about once a year clean it all out and apply a new layer of grease.
mung is offline   Reply With Quote
Old 08-19-2010, 09:16 PM   #5130
NMTrailboss
Team Dead End
Oddometer: 6,256
I've tried the stock filter, K&N, and a Uni and had the same problem with all of them. I'm beginning to believe fine dirt is getting into the airbox somewhere besides the filter itself.
Times are GMT -7.   It's 09:37 PM.
