Old 09-07-2010, 11:11 AM   #5326
mung
Oddometer: 612
Mt 21 140
I am using the mt 21 140 with no problems. Decent all around tire. Good on the street and good in hard dirt terrain-fair in sand or deep mud. I got 2400 miles on last one. The one I am using now will not go quite as far.
mung is offline   Reply With Quote
Old 09-07-2010, 01:30 PM   #5327
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,833
Originally Posted by tarzan30
Looking for a guru to help with some part issues. Is the front an rear rotors interchangeable? If not can someone help with a rear rotor part source?
Looking to replace my rear rotor it has a wave . The specs say they are both 240mm so i just want to make sure i can use the stock front on the rear if possible.
Thanks in advance!
If you have one lying around let me know too!
I had to replace my rear rotor last year due to wave. The stock replacement was around $100. I found the rear disc for the Transalp would bolt up and was a little heavier than the stock rear rotor. I found one on feebay for $45 shipped. It's been working well for me on the street, 5,000+ miles so far.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 09-07-2010, 08:15 PM   #5328
Akunin
Neo-Vegabond
Akunin's Avatar
Oddometer: 130
Anyone selling their XR650R?
PM if you are considering it! Looking to buy come February! Looking for low hours and like new condition! Hoping to find one that someone just hasn't found the time for.
Akunin is offline   Reply With Quote
Old 09-07-2010, 08:52 PM   #5329
cdogg44
Oddometer: 220
Originally Posted by Burkey
Im running MT21's 90/90 front and a 120 rear. The 130 will easily fit, I'll be trying this one next time
Sean
130/90 and a 90/90 MT21 are on the way. Also some tire irons.
This will be my first tire change EVER. My buddies are begging me to take it to a shop. I've done everything else to the bike so far so how hard could it be, right?
cdogg44 is offline   Reply With Quote
Old 09-08-2010, 12:05 AM   #5330
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Its not hard, just take your time and understand you will probably go through a couple tubes before you figure it out. I've done a bunch now, and its easy enough I find it relaxing actually. I have a beer, and toss a tire on nice and quick.
lstzephyr is offline   Reply With Quote
Old 09-08-2010, 01:47 AM   #5331
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,833
I usually install new tubes when I do my tires. To make it easier, I inflate the new tube just enough to give the tube its shape. With one bead on the rim, I slip the new tube in the tire and then remove the valve core to let the tube deflate. I insert my stem fishing tool through the hole in the rim and thread it into the valve stem, pull the stem into place on the rim and get the rest of the tube onto the rim before installing the second bead. Just take small bites with the tire irons, maybe an inch or so at a time, and use lots of Windex to lube up the process. Once both beads are on and the valve stem is secured in place, air up the tire to set the bead. Once the beads have set, install the valve core and inflate/deflate as necessary.
Have another beer.
-Joe
Old 09-08-2010, 06:21 AM   #5332
modette
RMAR
modette's Avatar
Oddometer: 4,892
And to think back in the day a large flathead screw driver is what I used as a kid...just got to be careful not hard to change a tire/tube at all.
Board of Directors for RMAR: Director of Digital Marketing & Promotions
Our site: Rocky Mountain Adventure Riders
modette is offline   Reply With Quote
Old 09-08-2010, 06:29 AM   #5333
cdogg44
Oddometer: 220
Have another beer.
-Joe
I ordered new tubes as well for my tires. However, is it standard practice to change them if they are working out ok? Also, are the $30 tubes any better than the $12 tubes?
Old 09-08-2010, 06:37 AM   #5334
modette
RMAR
modette's Avatar
Oddometer: 4,892
They are much much heavier rubber...and thus will help you to not get pinch flats. Some people change tubes often, but it seems like a lot of people are CHEAP and wait till it leaks on a trail *shrug* I went with the Tubliss system, so I don't worry now at all. As you can see why a good tube is $30...and me being anal would want to change them every tire change or at least every other tire change so at $30 a piece that adds up quick...the Tubliss system is $85-$89 a wheel....now instead of a tube I just carry a plug kit and a hand pump.
Old 09-08-2010, 06:39 AM   #5335
header
Chris
header's Avatar
Oddometer: 1,746
The only difference in tubes is the thickness. You can get HD (heavy duty) tubes if you are worried about punctures or pinch flats but they are more expensive and heavier.
For whatever its worth, I only change the tubes when I get a hole in them. keeps the cost down.
EDIT: Ha, he beat me to it ^^^
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 09-08-2010, 07:37 AM   #5336
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,240
I'd go with the HD tube. In 2 years, 5 rear tires (XR eats 'em up) with the same HD tube. They are heavy, but it works out cheaper (and easier) in the long run since they don't puncture as often. We ride some pretty rocky stuff that can be hard on a tube.
Of course I'll probably rip the valve stem out next ride since I wrote this
I've heard allot of good things about the tubliss setup.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak screwed with this post 09-08-2010 at 08:43 AM
RideFreak is offline   Reply With Quote
Old 09-08-2010, 07:48 AM   #5337
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 540
I use the tubliss on my Berg,setting the pig up for DP and not sure yet what I'm doing for tires/tubes.I do have spare tubliss setup if I go that route.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 09-08-2010, 08:05 AM   #5338
header
Chris
header's Avatar
Oddometer: 1,746
KTM 530exc
525exc refresh
Old 09-09-2010, 02:27 AM   #5339
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,833
The only problem with leaving the tube in until it fails is it tends to fail at the worst possible time, like going down the highway. I've had the valve stem rip from a tube under "spirited" acceleration on a DR350 w/out rim locks. For HD tubes, two or three tire changes to a tube should be okay. For the thin standard duty tubes, I would not use one for more than two tires. The last rear tube I put in was one of the $30 HD tubes, which is a little extra piece of mind for the 35 mile slab run. I don't want sudden tube failure at 75 MPH.
-Joe
Old 09-09-2010, 08:08 AM   #5340
dieselcruiserhead
Oddometer: 1,462
Originally Posted by xcflyn
Got one for sale on sleezebay. diversion 165 (cheap tig) works perfectly if you want a tig. Thought id throw that out there for ya.
Good to know, I checked it out. Definitely reasonable but still farther down the list of things to get. I would also like to be able to do 1/4" potentially but that may be asking a lot for too much extra $$$.
dieselcruiserhead is offline   Reply With Quote
Times are GMT -7.   It's 03:37 AM.
