Old 01-31-2011, 06:15 AM   #7261
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Coming out of gear has nothing whatsoever to do with your clutch.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-31-2011, 07:07 AM   #7262
cdogg44
Oddometer: 209
Clutch bushing?
cdogg44 is offline   Reply With Quote
Old 01-31-2011, 07:23 AM   #7263
BHW
BHW's Avatar
Oddometer: 4,125
Originally Posted by Blakebird View Post
what's your chain look like?
Chain and sprockets are fine.
A couple of times, as I was letting out the clutch to take off from a stop, there was a loud noise and the bike would lurch forward.
At least three times, the bike would jump from 1st to neutral as I was taking off.
I've never had ANY bike do this before.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 01-31-2011, 07:44 AM   #7264
jm-2008
jm-2008's Avatar
Oddometer: 507
BHW - Jumping out of gear
Circa 2000 vintage XRR's had the clutch bush issue (lack of oil feed holes leading to poor lubrication) however a siezing clutch bush would lunge forward when stationary/in gear/clutch in with motor running and not necessarily jump out of gear.
Usual cause for a bike jumping out of gear will be bent or worn (rarely worn usually bent) shift fork/s.
This can be attributed (more often than not) to falling on the gear lever side generally when under power.
Bent forks do not enable full engagement of the drive dogs and subsequently the gears will jump out of engagement when under load/power.
On inspection the forks may not appear to be visually significantly bent but will have wear on opposing edges of the pads on the fork where it inserts into the gears.
Another item to check is the detent location on the shift drum, a broken spring here will also lead to the above.
Note: it's been my experience that if/when a bike is jumping out of gear the shift fork will be damaged in some way and will most likely need replacement.
Hope this helps.
JM
jm-2008 is offline   Reply With Quote
Old 01-31-2011, 08:03 AM   #7265
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Also, if its been popping out of gear much at all the gear dogs themselves will be trashed (even if the cause was originally something else).
Old 01-31-2011, 08:08 AM   #7266
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,996
I was thinking adjustment more than condition.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 01-31-2011, 08:43 AM   #7267
jm-2008
jm-2008's Avatar
Oddometer: 507
[QUOTE=BikePilot;15073071]Also, if its been popping out of gear much at all the gear dogs themselves will be trashed (even if the cause was originally something else).
+1
Quite rightly so.
If it has only just started the damage may possibly be minimal.
Can be remedied with highspeed grinder and dovetail shaped stone if they aren't too far gone.
Old 01-31-2011, 11:15 AM   #7268
dieselcruiserhead
Oddometer: 1,419
Hi all,
I have a XR650R that is Dual Sported / long distance setup so it's getting a little fat at about an additional 40lbs I figure with a 5 gallon tank.
I'm also 6'5 and weigh about 225, we'll say an additional 20 lbs with riding gear and I'll go from carry no weight to upto an additional 30-40 lbs at time.
I'm about to order some Eibach springs for both the forks as well as the shock. Do you have any recommendations on spring rates?
thanks,
Andre
andreshoumatoff.smugmug.com
Grand Staircase Escalante Road Reports
Cycles South Vintage Moto Trek Movie - check out all 7 parts
dieselcruiserhead is offline   Reply With Quote
Old 01-31-2011, 11:16 AM   #7269
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I don't know, but you could try the race tech spring rate calculator - I've found it to generally be pretty good.
Old 01-31-2011, 11:48 AM   #7270
dieselcruiserhead
Oddometer: 1,419
Can you guys give me recommendations on which fork and shock springs I should get?
Bike is a little fat with Dual Sport / street legal / long distance mods. About +40 lbs I figure.
I'm 6'5 and 225, probably add another 20 lbs in rider's gear.
And then the bike will be anywhere from + 0 to 40 lbs for fully loaded...
Definitely curious on your opinions...
thanks,
andre
Old 01-31-2011, 12:18 PM   #7271
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Originally Posted by BikePilot View Post
jesusgatos, I've ridden a WR450F with arched pegs like that. Felt weird for about 5 minutes, then I got used to them and quite liked them. Very comfortable and made it easier to move my toe up and down a little for shifting or moving my body forward and back on the bike. Same basic result as pivot pegs, but with way less complication.
Has anyone managed to move the pegs substantially rearward? I find that at speed when standing I have to hold on tight with my arms to keep from being blown off the back even if I have my head over the front fender. This got really tiring in V2R last year. I think with the pegs further rearward and maybe a touch higher it'd work out better.
That's exactly what I was shooting for - wanted to mimic the feel of the pivot-pegs, while eliminating all the moving parts. Thanks for posting. Appreciate the feedback.
I've seen a couple of 650R's that were converted to flatrackers move the left footpeg back, so that the footpeg mount was moved back and tied into the kickstand mount. Not sure what you'd be able to do about the right footpegs though. I really like the footpeg position on my 650R, but have been thinking it might be kinda cool to move the footpegs back on my trailbike, to make it feel a little bit more like a trials bike (that bike also uses XR pegs). If this is something you really want to do, I could probably put together some CAD file if you want to get some custom pegs made. Got any buddies that work at a machine-shop?
jesusgatos is offline   Reply With Quote
Old 01-31-2011, 12:50 PM   #7272
chrish4ku
chrish4ku's Avatar
Oddometer: 795
XR650R Aux Power Setup
Wanting to tap anyone who has added any aux power to their XR. I have a small AA battery pack under the seat that recharges via the system, but it's not 12V. Runs my GPS off a 12V cig lighter adapter.
Wondering if there is a kit, or a better more professional way to have some battery juice.
Any photos or details would be much appreciated
Current Dash Setup.
From XR650R
From XR650R
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 01-31-2011, 12:53 PM   #7273
jesusgatos
jesusgatos's Avatar
Oddometer: 2,384
There are a few good threads on here about the 650R's electrical system, and installing high-output stators, dualsport kits, accessories, etc. Quick search will turn them up...
Old 01-31-2011, 09:10 PM   #7274
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,973
links...........?
I'm in the same boat and this thread alone is...........HUMONGOUS.........jus' like me.....
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 01-31-2011, 09:21 PM   #7275
jesusgatos
jesusgatos's Avatar
Oddometer: 2,384
Originally Posted by Infidel View Post
links...........?
Come awn man, don't be so lazy. Just type two words into the search box: 'xr650r' and 'electrical'
But here's one to get you started.
Times are GMT -7.   It's 12:04 AM.
