Old 02-05-2011, 05:24 AM   #7291
epix1718
epix1718's Avatar
Oddometer: 730
edit: wrong thread.
epix1718 is offline   Reply With Quote
Old 02-06-2011, 11:51 AM   #7292
Shibby!
Oddometer: 1,665
Since I'm whoring it up a bit. Figured I'd post it here too!
It's finally done!
Baja bound next Monday!
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 02-06-2011, 03:17 PM   #7293
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,403
That's done? What all do you have going on up there in that dash area?
jesusgatos is offline   Reply With Quote
Old 02-06-2011, 03:21 PM   #7294
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
BURNING OIL on fwy
So I've heard that it's normal/common for these bikes to burn some oil when running them at freeway speeds for extended periods of time - wondering why, and if there's anything I can do about that. Got a pretty fresh engine, stock except for carb and exhaust, and I'm riding 75-150 miles at 60-80mph at a time. Street wheelset is geared for it (16/46), so I'm not revving the piss out of it. But it's consuming enough oil that I'm a little bit concerned about it.
Old 02-06-2011, 03:51 PM   #7295
Shibby!
Oddometer: 1,665
It's not permanent but will be kept that way for the trip. It was a test config that's going to remain.
12v marine plug, HID ballasts for headlight, heated grips, relay for headlight, and everything else. I did the dual sport kit myself. Stuff is both zip tied and held in place by sticky sided velcro.
Elastic bands will be used for tools later, and serve as a reminder that my air filter is in a zip lock bag inside the airbox and not to start it. Petcock also has duct tape on it to serve the same purpose.
Only one way for engines to burn oil. It's getting past your piston rings. Either you rings/piston are wearing, or it's normal consumption with minor film along the cylinder walls getting past the rings.
Although these engines are designed for desert racing, they are race engines. They aren't made for continuous highway commutes. They can handle it because of a well designed engine, but it's not designed to last 80,000 K without problems. We're just lucky they stand up to this abuse.
Shibby! screwed with this post 02-06-2011 at 04:00 PM
Old 02-06-2011, 04:02 PM   #7296
pixelcodex
Oddometer: 70
12v marine plug, HID ballasts for headlight, heated grips, and everything else. I did the dual sport kit myself. Stuff is both zip tied and held in place by sticky sided velcro.
Is that a great basin or coyote bag? Seems big on the XRR.
pixelcodex is offline   Reply With Quote
Old 02-06-2011, 04:19 PM   #7297
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
Really? Nothing else could account for that? Hmmm, guess a leakdown test would tell me what kind of condition my rings are in, right? What kind of results should I expect/hope for?
Old 02-06-2011, 05:19 PM   #7298
harcus
harcus's Avatar
Oddometer: 1,333
Originally Posted by chrish4ku View Post
Wanting to tap anyone who has added any aux power to their XR. I have a small AA battery pack under the seat that recharges via the system, but it's not 12V. Runs my GPS off a 12V cig lighter adapter.
Wondering if there is a kit, or a better more professional way to have some battery juice.
Any photos or details would be much appreciated
Since you seem to be looking for options, here is my approach. Some may consider it extreme but so far it has worked quite well...
I installed a YTZ14SBS-AGM battery in a custom box mounted to the front of the skid plate....
I used this battery to replace the whimpy battery that was speced with the Baja Designs electric start kit....
This is charged with a Ricky Stator 200+ watt full DC system.
I use this to power ..
- heated grips - switch on panel
- GPS - connect with double bullet connector
- electric tire pump as required - normal auto socket
- Aux LED lights - switch on panel
Here is the panel...
And the LED aux lights...
So, it just depends on how far you want to go...
Want Creative Adventure Products? - See Globetrottin.com
Current rides - '14 KTM 1190 R Adv <2k, '07 990Adv 39k, '12 500EXC 7k, '09 GasGas 300 Raga
harcus is offline   Reply With Quote
Old 02-06-2011, 05:25 PM   #7299
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
Damn, that battery mount looks like it's begging to be destroyed.
Old 02-06-2011, 05:34 PM   #7300
harcus
harcus's Avatar
Oddometer: 1,333
Actually there are 2 paths to oil consumption:
- Piston rings as noted
- valve seals
Yes, a leak down test can differentiate between the the 2 possible causes.
Measure your compression using a compression tester (Harbor Freight?). You should see at least 70 - 80 psi kicking it. Pull the tester from the spark plug hole, squirt in some motor oil, spin the crank a fer times to distribute it, reinstall the tester. If the pressure goes up, the rings are leaking. The oil temporarily seals the rings.
Part of the reason with race type engines using more oil is the piston configuration. To keep performance up, they need minimum friction. To get this they use short skirted pistons with thin rings. A certion amount of oil blow by is desireable to lube the cylinder wall & decrease fiction further.
Unfortunately, this is not so desirable for sustained hyway operation or long term engine life. Contradictory demands.
All that said, the XR does an amazing job of bridging the two worlds. And oil is cheap! Put a sight tube on the bike, watch it, keep it full & RIDE!
Old 02-06-2011, 05:41 PM   #7301
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
Thanks, that's helpful.
Old 02-06-2011, 06:17 PM   #7302
Shibby!
Oddometer: 1,665
Coyote bag.
It is quite large. I had to put my MSR tent and shoes in the dry bag though.
I wish I could pack lighter, but I can't leave the camping gear at home. I'm not one for sleeping in my riding gear under the stars.
Old 02-06-2011, 08:41 PM   #7303
BHW
BHW's Avatar
Oddometer: 4,141
Yep. I'd tear that off on the first ride.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 02-06-2011, 08:58 PM   #7304
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,477
would not last long on the rocky desert terrain we ride.
btw - the XR650R was raced, and quite successfully....but it is not a "race engine", especially compared to it's Baja successor, the CRF450.
The XR never spec'd top end teardowns and rebuilds at 20 or 30 hour intervals, and doesn't have a slipper skirt piston, etc.
It's a very robust, and very overbuilt engine, designed and built to last.
If you're burning oil at low rpms....( is there really room for a 16t in there?!), then your valve guide seals are the first place I'd look....not the rings.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 02-06-2011, 09:20 PM   #7305
header
Chris
header's Avatar
Oddometer: 1,746
Originally Posted by Blakebird View Post
btw - the XR650R was raced, and quite successfully....but it is not a "race engine", It's a very robust, and very overbuilt engine, designed and built to last.
Because (an educated guess here) it was never intended to race the 1000 in its stock configuration but rather the HRC specs. Even then it will still last but for the rest of us who don't need that much power it will go well beyond "long lasting".
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Times are GMT -7.   It's 11:54 PM.
