Old 02-06-2011, 09:24 PM   #7306
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,403
Yeah, I don't think many people would classify this as a race engine. Know it wasn't designed for the type of highway miles I've been racking up lately, but can't see how that's really much different than WFO through the desert for miles on end. Seems like these should be easy miles. Going to test as suggested to see if it might be the rings or the seals. Thanks.
jesusgatos is offline   Reply With Quote
Old 02-07-2011, 12:23 AM   #7307
af300e
Oddometer: 283
Originally Posted by harcus View Post
Actually there are 2 paths to oil consumption:
- Piston rings as noted
- valve seals
3 ways. Those two as mentioned plus oil mist from crankcase breather going into the airbox, then through the carby and on to the chamber.
af300e is offline   Reply With Quote
Old 02-07-2011, 12:27 AM   #7308
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
Thought about the crankcase vent, but just cleaned my air filter (and pulled out the backfire screen - clean) and thought it'd be obvious if that had anything to do with it.
Old 02-07-2011, 03:20 AM   #7309
rocketmanphil
rocketmanphil's Avatar
Oddometer: 187
Question template
hi all !
slight dis mount
can someone post a template for venting the Left side cover ?
thank you in advance
rocketmanphil is offline   Reply With Quote
Old 02-07-2011, 04:12 AM   #7310
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,477
Originally Posted by rocketmanphil View Post
hi all !
slight dis mount
IBA #11735 . 1968-present
Blakebird is online now   Reply With Quote
Old 02-07-2011, 04:15 AM   #7311
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Originally Posted by jesusgatos View Post
Really? Nothing else could account for that? Hmmm, guess a leakdown test would tell me what kind of condition my rings are in, right? What kind of results should I expect/hope for?
as everyone said, there are many ways of burning/loosing oil other than it going by the rings - it can get blown out the crankcase vent (which ordinarily is routed to the airbox), it can get too hot and evaporate (not uncommon on air cooled XR's that are ridden in anger), it can go past the valve stem seals, it can enter the combustion chamber through a bad head gasket (or cracked head etc), on CRF's the motor oil can leak into the gearbox - anyway, all this to say that there's no reason to jump straight to the rings.
I've never spent long periods on the freeway with my XR, but it didn't use a noticeable amount of oil in Vegas to Reno and I ran it quite hard for those 534 miles.
Rings and valve stem seals are probably the least likely culprets - they wouldn't really be any worse at freeway speeds than any other time. One quick and dirty check for these is to run it up to speed then chop the throttle and let it engine brake for a bit then roll the throttle back on and look for smoke. When an engine is braking it makes a huge amount of vacuum inside and will suck in extra oil if seals or rings are bad. When you open the oil it all gets burnt and you'll see a puff of blue smoke if they are particularly bad.
The crank case breather setup is where I'd look first. I haven't messed with it on the XR though so can't offer any specific advice there.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot screwed with this post 02-07-2011 at 04:22 AM
BikePilot is offline   Reply With Quote
Old 02-07-2011, 05:25 AM   #7312
pixelcodex
Oddometer: 70
Originally Posted by Shibby! View Post
Coyote bag.
It is quite large. I had to put my MSR tent and shoes in the dry bag though.
I wish I could pack lighter, but I can't leave the camping gear at home. I'm not one for sleeping in my riding gear under the stars.
I hear you about packing lighter... can't do it myself. The Coyote looks the right size. I had asked them about the big basin and they told me it would be well... too big for our bikes. Do you have the subframe reinforcement, or it does ok with this setup without one?
pixelcodex is offline   Reply With Quote
Old 02-07-2011, 05:30 AM   #7313
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,477
I used the Dirtbagz (and their duffel) on my XR628, worked well carrying my backpacker-sized tent and bag for a week's camping in Baja.
I still have the Dirtbagz, but due to concerns about the XR650R's subframe in rough conditions and hard, fast riding.... I chose the Giant Loop Coyote.
It puts the weight right where you want it.
Old 02-07-2011, 08:50 AM   #7314
Shibby!
Oddometer: 1,665
I do not have a reinforced subframe, but as mentioned the bag doesn't sit that far back. Much less then a rack would. I stand 99% of the time when the going gets rough so I hope that puts less stress on the subframe.
The bags have not been weighed however they are quite heavy, but not rediculously heavy. I would estimate 40-50lbs? I hope I have no issues. I know it's an issue with aluminum subframes.
I would still like to argue the engine is still a race, or high performance engine. It was a robust design for robust racing, but it's not made to do miles. If it were you'd have an engine much like the XR, DR, DRZ, and KLR, etc. It's a robust high performance engine and through good engineering and robust design capable of doing higher milleage, but at the same time not designed for it.
And yes, few other options for oil burning. All of those (except crank case mist) are signs this engine isn't designed for high milleage use, even though it will with proper maintenance and the odd issue arrising. Treat it well and it will last a long while, just don't expect to have no issues along the way.
A perfect comparison are street bikes. Performance designed, but with good designs capable of much higher mileage then most think. I've seen lots of extremely well running sport bikes in the 60,000-100,000+ km's. Those same engines designed to rev to 15,000+ RPM and produce amazing HP/displacement ratios.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! screwed with this post 02-07-2011 at 08:56 AM
Shibby! is offline   Reply With Quote
Old 02-07-2011, 10:01 AM   #7315
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
How is the 650R engine any different than a DRZ engine? Obviously 250cc's...
But seriously, what makes you think this is such a high performance engine? I'd say all signs point to it being more similar to the older air-cooled XR engines than then newer CRF's (which is what I'd call a race engine).
Old 02-07-2011, 10:16 AM   #7316
BikePilot
BikePilot's Avatar
Oddometer: 11,251
From a technical standpoint the DRZ engine is more likely to qualify as the nebulous "race" engine with its shim-under-bucket valve train and all that. Anyway, it doesn't really matter.
I am also curious about the 16T sprocket - any issues with fitment and is there a case saver available that fits?
Old 02-07-2011, 10:26 AM   #7317
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
No fitment issues, except I had to clearance a 15T XR's Only case saver.
Old 02-07-2011, 10:51 AM   #7318
Shibby!
Oddometer: 1,665
Different opinions I guess. I don't think this is being productive to the XRR thread so I'd rather let it go.
Old 02-07-2011, 11:11 AM   #7319
jesusgatos
jesusgatos's Avatar
Oddometer: 2,403
I wasn't trying to be argumentative. Honest question, and I think it's as relevant as anything else that's been discussed in this thread. There are many accounts of 650R's going 20,000+ miles without any major service/overhauls. Whether you call it a race engine or not, seems to have proven itself to be pretty darn reliable. No big deal if I have to live with it burning a little bit of oil, but would rather address it if it's anything I can fix.
Old 02-07-2011, 11:30 AM   #7320
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,833
Mine "uses" a littl oil too when I ride the highway, which is most of the time. As a result, I usually run a 15/44 gear combitation. Typically, I may need to add 8 oz. once I have exceded 500 miles after an oil change. I just am in the habit of checking the oil when I return home after each ride. It does not seem as bad at lower speeds, say 60 MPH and does not smoke, so the consumption is relatively slight. Even the full-blown race XRR's needed to add oil during the Baja 1000. It is in the nature of the beast. FWIW, I am the third owner of this bike and have added over 7,000 miles so far on the stock top end.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Times are GMT -7.   It's 02:55 PM.
