Old 02-22-2011, 04:29 AM   #7501
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 536
Originally Posted by Garthe View Post
I got a complete kit I'm not using...$40.00 and it yours...shipping included. pm me your address...
if Header is all set Garthe,I'd be interested in that.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 02-22-2011, 08:41 AM   #7502
the_hulkamaniac
the_hulkamaniac's Avatar
Oddometer: 79
Originally Posted by jesusgatos View Post
Ah, sorry to hear/see that. Any idea what happened? Besides the obvious...
Not really, valves were adjusted around x-mas, fluids were fresh and full. It wasn't very cold out. -5C / 23F. Light snow in the past few days so I was pushing quite hard, it wouldn't wind out 5th so I was running in 4th really hard. So I might have just over reved it for to long with to much load. With this monster on the back end:
http://www.advrider.com/forums/showp...postcount=6935
So I might be giving up on the "terrorflex". Lucky for me i still have the oem motor, so I can run it until a rebuild the monster.
Anyone hear how cyclewiz is coming with his setup? I think the crank is good, but I need a big piston, cam, top end, valves....
the_hulkamaniac is offline   Reply With Quote
Old 02-22-2011, 08:54 AM   #7503
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,784
Was the valve head missing when you disassembled the motor? Something metal was hitting the top of the piston and the head. Just guessing, but I think when whatever let go at high rpm, it cocked the piston sideways, cracking the cylinder. I hate to say it, but I'd bet you're looking at a crank and rod plus a new top end at the least. That kind of load hitting the rod surely damaged the lower rotating assembly.
My wife did that one years ago with a 454 Chevy. The #3 exhaust valve dropped the head into the cylinder. Since steel doesn't compress well, the connecting rod took on an "s" shape before punching a hole in the side of the block. The damage in your pictures looks very similar.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 02-22-2011, 09:01 AM   #7504
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,364
Sorry...sold.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 02-22-2011, 10:45 PM   #7505
the_hulkamaniac
Oddometer: 79
-Joe
I think I fished out all the parts, they were sitting on top of the piston. The piston had no problem going up and down in the bore once free. One of my neighbors used to build motors and crank he's going to give mine a once over looks straight feels tight. Time will tell. There is a bunch of room for a broken valve to bounce around with the high peak in the cylinder head.
My old 450s, and I blew up a few would grenade much worse then this.
Old 02-22-2011, 11:00 PM   #7506
5hortbus
Oddometer: 114
Needle Jet install question
Prior to reading the "make note of how your needle jet is oriented when you pull it out, it'll save you jetting headaches later" advice, I pulled it and cleaned it.
The XRR manual says to reinstall it with the smaller diameter into the carb body.
Do they mean inner or outer diameter?
-The outer diameter difference is 0.2mm,
Inner is a 1.0mm difference.
Of course the smaller inner diameter is on the larger outer diameter side.
Which way should this go back in??
Chicagoland Dual-Sport Riders
5hortbus is offline   Reply With Quote
Old 02-22-2011, 11:18 PM   #7507
Garthe
Garthe's Avatar
Oddometer: 4,364
2007 XR650R
2001 Montessa 315R
Old 02-23-2011, 12:57 AM   #7508
jm-2008
jm-2008's Avatar
Oddometer: 507
[QUOTE=5hortbus;15257623]Prior to reading the "make note of how your needle jet is oriented when you pull it out, it'll save you jetting headaches later" advice, I pulled it and cleaned it.
The end with a smaller outer diameter goes in first.
jm-2008 is offline   Reply With Quote
Old 02-23-2011, 01:21 AM   #7509
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,784
Does anyone know if a XR400 rear wheel can be fitted to the XR650R? I know the CRF450X can be done with a different bearing set and a little shaving of the axle spacers. I'm looking for a spare rear but even used is damn expensive. I even looked into the Warp 9's, but the reviews were mixed. Didn't seem all that good for the money.
-Joe
Old 02-23-2011, 04:13 AM   #7510
gvthnks
gvthnks's Avatar
Oddometer: 536
Originally Posted by larryboy View Post
Why don't you put in a sight tube? I'd forget to check the oil all the time until I put in a sight tube, can even be checked at idle now.
hope I didn't miss it, but do you have pics of this? Thanks
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is offline   Reply With Quote
Old 02-23-2011, 06:20 AM   #7511
BikePilot
BikePilot's Avatar
Oddometer: 11,251
the_hulkamaniac, did it have any aftermarket engine parts or internal motor work? XR400R CDI? Its rather odd for it to eat an exahust valve (unless its too tight, in which case it'll get way hot and die early) as the intake is so much bigger it'd usually break off first.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 02-23-2011, 09:20 AM   #7512
5hortbus
Oddometer: 114
Thanks- Now Playing Carb XRR russsian roulette
Appreciate the help JM.
Was psyched to get it back together, and needless to say, that was a roadblock to the process.
I have also completed the Borynack "cuz I'm in here" carb mods of plugging the Air Jet Cutoff Valve, and removing the choke flap.
Is there anything I need to be worried about moving forward?
I'm at about 700'
-68s Pilot
-175 Main
-B53e needle (3rd Clip position)
-From what the PO told me, I have a Big Gun header and Pipe. Other uncorking has been completed. The airbox is still in its original form.
Previously, the bike bogged on accel and had a stumble a few seconds into WOT.
I have read carb tuning threads ad nauseum, but this is my first time tinkering with what may as well be the human brain to me. So if there's anything glaring, let me know.
Oh, one other thing: The pilot screw spring, o-ring, and washer wouldn't come out of the carb when I disassembled. Reason for concern? The screw came out, but everything else stayed put.
Old 02-23-2011, 11:46 AM   #7513
BHW
BHW's Avatar
Oddometer: 4,125
-Joe
I'm quite happy with my Warp 9.
A lot of the complaints, came from people who threw them on and did not follow the instructions to check and tighten the spokes, etc for the first few rides.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 02-23-2011, 11:54 AM   #7514
backdoc
bone cracker
backdoc's Avatar
Oddometer: 93
Well, I finally got the re-build complete on my piggy. After 2 1/2 months of it sitting quietly in the garage, it fired up after 3 good kicks. The sound of music to my ears. I still have a few extra things to get it completely done, ie. gold anodized Unabiker radiator shrouds will be here thursday, blue Pro Factory Hoses in hand, and new thermostat for trail tech will be here monday. I finally have some finished pics to post.
Me and my new re-born baby
new rear end with plates and blinkers installed
my 5 year old sons favorite toy's. got it running this weekend with new carb and gas tank
Thanks Garthe for putting the new front rotor in my head
I love the blue daystar 69's on the front.
So now its time to get a few rides in to make sure that everything is nice and tight. I must say thanks to the collective for answering all my questions and helping out. I'll post a few pics with new radiator equipment when i get it done.
WFO
2003 XR650R
1996 GSX-R-750 (bent in half by truck)
1984 XR500R (sold)
1986 TRX70 Fourtrax (sons)
backdoc screwed with this post 02-23-2011 at 12:00 PM Reason: duplicate pic
backdoc is offline   Reply With Quote
Old 02-23-2011, 01:55 PM   #7515
Coastie3202
King of the Mountain
Coastie3202's Avatar
Oddometer: 855
Nice work. Now let the fun begin.
I want to live in a world where common sense and courtesy trump entitlement...a world where chickens can cross the road without having their motivation questioned.
Coastie3202 is offline   Reply With Quote
Times are GMT -7.   It's 01:33 AM.
