Old 02-23-2011, 12:57 PM   #7516
Coastie3202
King of the Mountain
Coastie3202's Avatar
Oddometer: 861
Stock Exhaust
When I had my XR400 I took a wire brush and took all of the black paint off the can. Looked good, and held up good. I live in the desert, so rust is not an issue.
Anyone done that to their stock BRP exhaust can?
I want to live in a world where common sense and courtesy trump entitlement...a world where chickens can cross the road without having their motivation questioned.
Coastie3202 is offline   Reply With Quote
Old 02-23-2011, 01:38 PM   #7517
jm-2008
jm-2008's Avatar
Oddometer: 513
[QUOTE=5hortbus;15259714]Appreciate the help JM.
Was psyched to get it back together, and needless to say, that was a roadblock to the process.
I have also completed the Borynack "cuz I'm in here" carb mods of plugging the Air Jet Cutoff Valve, and removing the choke flap.
Put a solid flap on my original carb for peace of mind, some owners lean the bike on its side to prime it via carby flooding a little, this may help with starting.
Is there anything I need to be worried about moving forward?
I'm at about 700'
-68s Pilot
-175 Main
-B53e needle (3rd Clip position)
Should be in the ballpark, mine ran well with similar settings up to and around 3000feet (stock air box cover-no holes and stock pipe - uncorked)
-From what the PO told me, I have a Big Gun header and Pipe.
The big gun header will likely have some effect but as to how much and where in the rev/throttle range I cannot say, other inmates may be able to assist.
Other uncorking has been completed. The airbox is still in its original form.
Previously, the bike bogged on accel
Not unusual for a thumper with non pumper carby, the reasons are well documented here however this usually happens if/when the throttle is snapped open from (or near) the idle position if when trying to loft the front end over logs etc.
That said it depends on how and what conditions you ride, as an older (fossil age) rider my riding is not quite so frenetic and the stock carby worked well enough for most of my riding (have since fitted a TM40 for a little more zest) and it was very reliable. and had a stumble a few seconds into WOT.
WOT stumble sounds like a jetting size issue, if you need some guidance on set up I will try and source some instructions for you.
I have read carb tuning threads ad nauseum, but this is my first time tinkering with what may as well be the human brain to me. So if there's anything glaring, let me know.
Oh, one other thing: The pilot screw spring, o-ring, and washer wouldn't come out of the carb when I disassembled. Reason for concern? The screw came out, but everything else stayed put. If the spring and O-ring stayed put and no air leaks past I probably would not be too concerned.
jm-2008 is online now   Reply With Quote
Old 02-23-2011, 04:14 PM   #7518
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,356
It always feels good to help someone else spend money...very nice bike.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 02-23-2011, 05:11 PM   #7519
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,405
Originally Posted by backdoc View Post
...Pro Factory Hoses in hand, and new thermostat for trail tech will be here monday...
When you install the new hoses and temp sensor, try this: instead of cutting your hoses to install the temp sensor housing inline, drill and tap a 1/8" NPT hole (double-check to make sure that's the right size) in the flat boss on the side of the factory thermostat housing. Makes for a much cleaner installation.
jesusgatos is offline   Reply With Quote
Old 02-23-2011, 08:58 PM   #7520
TourPros
Local wherever I go
TourPros's Avatar
Oddometer: 2,045
Question
Anyone here know how much exhaust tape it takes to wrap the pipe? I want o order it but not sure how much so before I go out there with strips of something and mock it up I figured chances are high that someone here would know the answer.
Hell I've been thrown into better places and got friends I ain't even used yet.
Hug those you love often And turn life up !!!
I really like what your are trying to do. I'm just not sure about how you are trying to do it. It's been a pressure working with you and the pleasure was all yours. If you need me I'll call ya..
TourPros is offline   Reply With Quote
Old 02-23-2011, 09:12 PM   #7521
jesusgatos
jesusgatos's Avatar
Oddometer: 2,405
Not what you're asking, but I would avoid using insulating tape on your exhaust if at all possible. The water and muck soaks into it and then the heat = bad news. Ruined a custom-made pipe like that pretty quickly.
Old 02-23-2011, 09:13 PM   #7522
Garthe
Garthe's Avatar
Oddometer: 4,356
Don't do it...
2007 XR650R
2001 Montessa 315R
Old 02-23-2011, 09:48 PM   #7523
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
love the elephant ears. Sucks bout the motor. My buddy's all ways rag on me for using em but my hands are toasty.
[/QUOTE]
Capt. Egregious is offline   Reply With Quote
Old 02-23-2011, 09:53 PM   #7524
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
I used about two packs of the 20 foot lengths, but had about 10 feet left over.
Lots of people will tell you not to do it, I have done it twice now and love it. No more burnt pants, and it keeps everything cool(er) but I live in the desert.
Originally Posted by gvthnks View Post
hope I didn't miss it, but do you have pics of this? Thanks
For the guy who asked about the sight tube this is the best picture I have of it. I love it, I check my oil constantly now, sometimes while I'm running down the road.
And just for the hell of it I will share a couple pictures I haven't shared yet.
lstzephyr is offline   Reply With Quote
Old 02-23-2011, 10:44 PM   #7525
Beserker
Red Rider
Beserker's Avatar
Oddometer: 94
Ceramic coat it...works well, quite cheap and lasts forever.
Black on inside, "Shine" on outside..brings the temps way down, huge advantage as the headers wraps the radiators, and with Ceramic coating, the temps come down drastically.
Riding and stopping, I can actually grab my headers with bare hand within minutes.
What mine looks like after 15 000km...the obvious other advantages is that it never looks rusted.
Beserker is offline   Reply With Quote
Old 02-24-2011, 02:35 AM   #7526
KASUYAHO
Road Hog
Oddometer: 3,740
Originally Posted by the_hulkamaniac View Post
Big Dead Piggy.
That a bit of bad luck there mate.
Broke right at the head of the valve?
The exhaust valve on the BRP is a 2 piece valve and welded half up the stem.
The bottom half is non magnetic / stainless, the top half is magnetic.
Stainless is brittle so if the valve is bent from hitting the piston it should be changed out,
other material valves can be straightened which i would not do anyway.
The main reason why valves break off under the head of the valve is from valve float.
Valve float over a period of time, the valve hammers the valve seat too,
and sometimes valve resession happens from this too.
And valve clearences will be noticed to increase.
If it was i would would be checking the valve spring pressures too.
KASUYAHO screwed with this post 02-25-2011 at 10:15 PM
KASUYAHO is offline   Reply With Quote
Old 02-24-2011, 06:46 PM   #7527
RedBirdStation
RedBirdStation's Avatar
Oddometer: 537
Well, I finally got the re-build complete on my piggy. After 2 1/2 months of it sitting quietly in the garage, it fired up after 3 good kicks. The sound of music to my ears. I still have a few extra things to get it completely done, ie. gold anodized Unabiker radiator shrouds will be here thursday, blue Pro Factory Hoses in hand, and new thermostat for trail tech will be here monday. I finally have some finished pics to post.
Me and my new re-born baby
Wow..
Complete different animal from what I knew it as.
Good Job
2007 KLR 650
2009 XR650L
Some people try to turn back their odometers.
Not me! I want people to know "why" I look this way.
I've traveled a long way and some of the roads weren't paved.
RedBirdStation is offline   Reply With Quote
Old 02-24-2011, 09:43 PM   #7528
kt1fab
Oddometer: 80
State patrol
Originally Posted by Blakebird View Post
In Colorado you want it to state "for off road use only", and you write it on bills of sale for dirtbikes you're going to dualsport. That shows that it's a previously untitled bike, so there's no need to do a title search for any previous titles.
The MSO (mfr's statement of origin) is not required in CO, a bill of sale works.
I'm taking this down to the Colorado State Patrol tomorrow for it's certified VIN verification, compliance inspection, and off to DMV for plates after I call my insurance agent.
I bought this from Michelangelo in early December. Replaced a pranged radiator, shagged chain and sprockets...had local suspension guru Neil Hores revalve and respring both ends.
Bought a PMB rack from an inmate, put on new ProTapers with Cycra CRM handguards....
Added a 250w Baja Designs rewind & one of their d/s kits.
An Eastern Beaver "3 Circuit Solution" (simple fuseblock) has it's 40a relay triggered by the 5w running light in the headlight shell. Turn the d/s kit on, that running light comes on and the fuseblock has power.
Right now that's just GPS, Vapor lighting, and a pair of Symtec grip heaters.
An Osram 80w-85 H4 bulb is in the mail...
Looking at going for my inspection in CAstle Rock is there anything that I need to know that caught you buy surprise.....
kt1fab is offline   Reply With Quote
Old 02-24-2011, 09:49 PM   #7529
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,507
The big surprise was that they didn't need me to unload the bike from the hitch carrier and start it, or even turn on the d/s kit to show anything worked.
The trooper did a quick visual inspection and that, as they say....was that.
I did call ahead and make an appointment, got there about 20 minutes early and they were able to get me done in short order.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 02-24-2011, 10:09 PM   #7530
kt1fab
Oddometer: 80
thanks
Did you go to Castle Rock or one by Parker. The guy in Castle Rock has been out for a while heart-attach might need to loook at going to another state patrol office.
Times are GMT -7.   It's 02:26 AM.
