04-07-2011, 05:47 PM
#8071 |
Oddometer: 929
Yeah I know, this is why I'm asking... I've good things about the IMS and nice and low and I like 7 gallons... Just getting second opinions. I know about the vaccuum pump and hear it works well. Just any other concerns especially versus the acerbis would be great...
andreshoumatoff.smugmug.com Grand Staircase Escalante (& Utah General) Road Reports Make it happen (all 7 parts) |
04-07-2011, 05:48 PM
#8072 |
Oddometer: 402
2008 950 SE-R 2000 XR650R 2001 CR250R 1983 ATC200E |
04-07-2011, 07:37 PM
#8073 |
Oddometer: 94
04-07-2011, 09:19 PM
#8074 |
Oddometer: 143
after seeing HRC all the time I thought I'd go check out the site and have a look around.......has anyone ever noticed the last name of the President of HRC?
04-07-2011, 10:24 PM
#8075 | |
Got me a Big Red Pig
Oddometer: 81
Feeling your pain !!
A few questions for all the guys who have had their axles out... 1) Can I assume the bearings (or spacers) are seized to the axle ? 2) Is beating it out of there going to damage the frame/swingarm ? Does the RH side of the axle thread into anything, like the spacers ? ![]() ![]() Thanks ! Rup
XR650R Dual (almost) Roadstar 1700 Midnight Cdn We're gonna need a bigger boat . . . . . . . |
04-08-2011, 09:09 AM
#8076 |
RMAR
Oddometer: 3,080
Wow that might explain the weak subframes...LOL *because bikes like the Suzuki Hayabusa had subframe failures*
Member of AMA, COHVCO, and RMAR On the Board of Directors for RMAR: Director of Promotions Our site: Rocky Mountain Adventure Riders modette screwed with this post 04-08-2011 at 06:29 PM |
04-08-2011, 09:14 AM
#8077 | |
Oddometer: 154
2) The axle bolt does not thread to anything. Just remove the nut on the left side and it is "supposed to" slide right out. I don't think you can damage anything by beating it out. Just don't miss with the hammer. |
04-08-2011, 09:18 AM
#8078 |
Oddometer: 154
Swingarm bolt
Here is another option on removing swingarm bolts. This is what motivated me to install new swingarm and lingage bearings recently http://www.advrider.com/forums/showthread.php?t=532835
04-08-2011, 11:03 AM
#8079 |
Oddometer: 64
oingo boingo
hey you guys!
I've been thinking about changing the fork oil from 5 to 2.5 to help keep the front planted through rock gardens and generally smooth out the rough stuff. My question is do you need to change the shock oil to the same weight? My concern is that the back end would start kicking up/out with the front softened up. Cheers & Thanks! |
04-08-2011, 03:33 PM
#8080 |
Oddometer: 80
headlight question
So I am going to be running my bike with out a headlight and just a number plate will it hurt the stator to do this or anything else on the bike for that matter.
Thanks |
04-08-2011, 04:06 PM
#8081 |
ROCKS ARE YOUR FRIENDS...
Oddometer: 4,115
no
04-08-2011, 04:38 PM
#8082 | |
Road Hog
Oddometer: 2,892
it is like whale snot and you may have rust on the fork springs. 2.5wt oil is ok to use. The rear kicks anyways. The biggest help is to use fork and shock springs of your weight. |
04-08-2011, 07:27 PM
#8083 | |
Oddometer: 81
I'm headed to the Honda shop first thing tomorrow to make sure they can get me the parts (I suspect I'll replace everything but the swingarm itself at this point) and then it's whacking time. I'll keep you all posted on how it goes. Really don't want to have to cut the swingarm in half . . . . . .
04-08-2011, 07:31 PM
#8084 |
Oddometer: 81
Footpeg Bolts
I'm going to try and track down some high-grade replacement bolts for the RH footpeg on my '03 650R. Anyone else in western Canada need some ? I suspect I'll have to buy a minimum qty so I may have some to sell.
PM me if you're interested. I'll call my supplier next week and see what they can do.
04-08-2011, 08:24 PM
#8085 | |
Kicker Brother
Oddometer: 3,072
http://cgi.ebay.com.au/LOOK-XR650r-X...item41584b4701 |
