Old 09-14-2011, 02:03 PM   #10156
Shibby!
Oddometer: 1,657
Originally Posted by cdogg44 View Post
Who is running Unabiker radiator guards? Would you have any pics of how they mount? Especially the back right side?
I took my Devol guards off when my bike was running hot and it seemed to help some (although not as much as I'd hoped), and am now contemplating going back with Unabikers because there isn't much too the Devols.
In fact, does anybody make a set of radiator guards that are just the frame around the radiators and not the "screen" in front of them? Just basically crash bars and then I'd run the stock plastic fins in front. I'd hate for a direct drop on a rock to ruin a Fluidyne, but I do think it runs cooler (10-15*) with the stock plastic fins.
I'll see if I can get pics. I have them and love them. The downside for you is they do cover the front of the rads and have braces going across the back and between rad cages.
I can understand in different terrain the frontal protection isn't wanted, but for riding bush it's highly needed. Plus they tend to be a lot stronger then the exterior frames which I tend to stay away from for that very reason. I've seen many of those frame style bend the rads, where I have yet to see a caged, quality, rad guard bend (within reason).
I should have pics at home and will try to upload tonight.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 09-14-2011, 02:20 PM   #10157
jm-2008
jm-2008's Avatar
Oddometer: 512
[QUOTE=Shibby!;16853584]Turns out I *might* have found my issue last night.
I've put some thought into this and had an idea of what might be causing it. Without trying I noticed it might be the case. It has something to do with what you mentioned above.
I was coming home, driving up my driveway and stopping in gear. My driveway has a slight incline so the bike would roll back a bit and stop with engine compression while putting it on it's sidestand.
What I think this is doing is causing my kickback decompression to engage, and with storage the oil is being drained away from the mechanism causing it to "hang" come time to restart.
Well last night, after doing the same thing I pulled in the decomp lever to find it's already fully engaged. Small turn of the motor and it released itself.
I think my issues are with me storing the bike for a few days/weeks, etc with the kickback decomp engaged and as mentioned, causing it to not want to release leaving me with little compression.
I'm fairly confident that if I take note of this I'll likely never have the issue again. Thoughts?
Good to hear you may have found some direction.
Be sure to post an update.
jm-2008 is offline   Reply With Quote
Old 09-14-2011, 05:01 PM   #10158
KASUYAHO
Road Hog
Oddometer: 3,638
What type of oil are you using JM ?
KASUYAHO is offline   Reply With Quote
Old 09-14-2011, 05:11 PM   #10159
Shibby!
Oddometer: 1,657
I don't think it has any relevance so I'll leave the name out of it. It is an oil rated for wet clutch.
I don't know how the kickback mechanism works so whatever is causing it to "stick" or hang could be something completely different then oil. I'll try to look into it but I have a feeling storing the bike this way is the reason it's doing it.
Old 09-15-2011, 01:35 AM   #10160
KASUYAHO
Road Hog
Oddometer: 3,638
The auto-decomp has a one way clutch on the end of the camshaft.
It is called a sprag clutch, the same design as what is in automatic transmissions like the Chrysler Torqueflite.
Basically rollers and waffer springs that relocate the rollers.
What happens if you run an oil that is know not that good of quality of oil the oil breaks down,
or oil changes are not frequent.
Broken down oil if you have seen what it is like it sticky, when it is not hot.
I believe this is what your experiencing with your non compression issue.
Old 09-15-2011, 04:08 AM   #10161
jm-2008
jm-2008's Avatar
Oddometer: 512
Belray Thumper 20/50
jm-2008 screwed with this post 09-15-2011 at 03:00 PM
Old 09-15-2011, 08:35 AM   #10162
Shibby!
Oddometer: 1,657
Using Rotella T. The non-synth version (15-40 i think). Currently has 900km (562miles) on it.
Got out testing the XRR / TM combo last night again. 142.5 pulls noticeably stronger then the 140main. I'll be reverting to and keeping it at 142.5. (3450ft, 16 degrees Celcius, 47% humidity)
I have yet to play with the needle, but it depends how easy my tank is to reinstall if I'm going to play around more with that. It pulls pretty good, but my mind always wonders if it can be better.
I've decided I'll change out the pilot too to the next size larger. I do need some help and feel stupid asking this question, but I'm assuming the 22.5 is RICHER then a 25?
When I had the 20 in I had the A/F screw all the way in, now with the 25 I have the a/f screw almost all the way out (2-7/8)
Being that the screw is on the fuel side it's generally known as a fuel screw vs an airscrew. So just looking for confirmation that a 22.5 (richer then a 25) would likely net me around 1.5 turns out on the fuel screw... I think I'm confusing myself. haha.
With mains isn't the larger number richer? Yet the pilots on the TM's are leaner? Or am I on crack?Maybe it's an air screw and not a fuel screw..
Shibby! screwed with this post 09-15-2011 at 08:46 AM
Old 09-15-2011, 09:13 AM   #10163
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,364
If you don't have one...I might be able to take one. I run the fluidynes and unibiker. The rad guards (and Fliudynes) are a pain in the ass to install. It's nobodys fault, it just is what it is. It's worth the effort...
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 09-15-2011, 10:04 AM   #10164
cdogg44
Oddometer: 209
Would you rate them any better than Devol guards? I'm wanting to mount a fan to my bike, but want to get settled in on my radiator guards before I finally do. However, I will say that my bike didn't get the proper airflow at low speeds to cool itself down in hot weather with the Devol guards, and while not much better, the stock plastic fins did seem to work better. And that has me wondering if the Unabikers are going to be just as restrictive as the Devols seem to be.
cdogg44 is offline   Reply With Quote
Old 09-15-2011, 10:58 AM   #10165
JIPPERR
JIPPERR's Avatar
Oddometer: 67
I think you got that backwards Shibby! Bigger numbers for richer pilot jets on the TM40, unscrewing the mix screw makes it richer. With my open header and pipe i ended up at a 30 pilot jet and 1.1 air jet. Not sure how many turns out (at sea level in 60 degree f temps)
JIPPERR screwed with this post 09-15-2011 at 11:41 AM
JIPPERR is offline   Reply With Quote
Old 09-15-2011, 10:58 AM   #10166
JIPPERR
JIPPERR's Avatar
Oddometer: 67
TM40 tuning guide just in case you don't have it :)
http://www.mikuni.com/pdf/hs40_manual.pdf
Old 09-15-2011, 11:43 AM   #10167
Shibby!
Oddometer: 1,657
Originally Posted by JIPPERR View Post
I think you got that backwards Shibby! Bigger numbers for richer pilot jets on the TM40. With my open header and pipe i ended up at a 30 pilot jet and 1.1 air jet. Not sure how many turns out (at sea level in 60 degree f temps)
And that's what I thought....
If I think about it more that sounds right... Full in to stop flow with the 20, and full out to give more flow with the 25.
I'll want to put the 22.5 in.
I think I have the 1.2 air jet installed. Your 1.1 (less air I believe) would cause you go to a leaner pilot. Seems bikes are a bit differently set-up jetting wise. I guess you can't argue with proper running.
It'll be:
142.5 main,
3rd Clip Y-1 needle (forget about washer),
22.5 pilot,
1.2 air jet.
Full exhaust, twin air filter. 3450ft and cooler temps.
Will try to test a few clip positions to finish it off.
What I do notice and may try fixing is a slight surging at 35-50km/hr during constant speed. Not sure if it's in my head or not, but it seemed to have developed a bit while changing jetting. The airjet/pilot change might fix it but we'll see. I have to determine if it's just me or not.
Still have the studder when quickly going WOT, but I'm hoping the pumper solves that when set-up. I think it's a split second condition going lean.
Seems like people are scared of the TM because it's not a plug and play carb, but at the end of the day these settings are easily done and effects are easily noticed. Not sure why people are scared of setting up a TM. Change jet, 5 minute ride, change jet, 5-minute ride, etc. Shouldn't take more then a few hours not counting cool downs. I've just been doing it between other stuff at home so can't do it all consecutively.
Shibby! screwed with this post 09-15-2011 at 12:10 PM
Old 09-15-2011, 12:18 PM   #10168
Shibby!
Oddometer: 1,657
Sorry guys,
Didn't get to this. My parents are here visiting starting today so I won't be able to get to it for a few days.
I also have stock rads if that matters...
Old 09-15-2011, 01:39 PM   #10169
JIPPERR
JIPPERR's Avatar
Oddometer: 67
looks like i edited my post while you were writing your reply :) maybe we're talking the same language here but just in case... on the TM40 unscrewing the mix screw makes it richer.
For example, if 20 is a lean jet for you turn the mix screw out (max of about 3 1/2 turns) to richen it up. IF its still lean at 3 1/2 half turns out go to a richer jet, 22.5 or 25, and less turns out on the mix screw. Hope that helps!
Old 09-15-2011, 03:24 PM   #10170
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Rotella (= Shell) is, as far as I know, a single-grade oil, not a multigrade. Want Shell diesel multigrade? Rimula...
Bel Ray makes an excellent product for which they are worldwide well known - which is the foam-filter oil, the blue goo. I've heard rumours that they make more stuff, and now I notice that someone actually uses it. Take a hint if you spot one...
Whoever has the 'hanging/sticking decomp issue' I bet will answer 'yes' to all of the following: the bike's got plenty miles on and/or is old, the bike's used intermittently, it's seen mineral oils only, and probably you do not change the oil too frequently. My advice is to switch to a full synthetic oil, and Shell Helix Ultra is an excellent (and relatively cheap) option. Keep this oil in for a few changes - within Honda's recommended renewal intervals - and I bet your problem 'magically' disappears. Kasuyaho's on the button here.
Right, that was my 3c's for tonight
BuRPsa is offline   Reply With Quote
Times are GMT -7.   It's 07:46 PM.
