Old 11-21-2011, 07:45 PM   #11461
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
Originally Posted by Rut Runner View Post
After a recent trip where I dumped my XR countless times, I have to finally ask the best procedure to restart it. It appears my XR will idle fine while completely horizontal on its left side, but will die quickly and become very hard to start if its dumped on its right hand side.
I know this question must have been asked before but the search engine didn't turn up anything.
Mike
I have heard a lot of guys say this
I just did a few laps around the Office and when i parked the pig inside the the office she peed all over the oak floors , so i took the float bowl off and yep set to high , and looked up in there and couldn't figure out why to fall over left or right , why should it matter every thing in the carb seems to be even left and right , but the wide open thing works
www.manracks.com
jungleplant is offline   Reply With Quote
Old 11-21-2011, 07:54 PM   #11462
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
Well, I finally did the deed. I swapped the mighty thumper for a 450. The xrr was a great ride, but apparently I wasn't up to it with the more technical stuff I like to do these days. Thanks for all the advise and tricks you guys taught me along the way!
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 11-21-2011, 08:03 PM   #11463
skibootdog
Oddometer: 275
baja
good move, 9 of the top 10 bikes at this years baja 1000 were CRF450X
skibootdog is offline   Reply With Quote
Old 11-21-2011, 08:23 PM   #11464
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,357
Pictures...
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 11-21-2011, 09:30 PM   #11465
Shibby!
Oddometer: 1,666
carbs are to be mounted vertical, otherwise your float height will be wrong, the fundamental setting of jetting.
It'll work, but they "should" be vertical.
FCR was too pricey for this guy. Went with the TM and have been happy. My stock carb didn't have the studder others talk about.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 11-21-2011, 11:50 PM   #11466
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Thanks RF, that makes sense.
I've got the Ross (std bore!) 11:1 piston at home, from XRsOnly, waiting for time to mount. I had it (optional) ceramic-coated, which turns out to be a surprisingly thin layer of stuff on the crown, almost transparent.
The skirt (under ring fields) is also coated, with (I presume, dunno for sure) Teflon or similar, slippery stuff. I didn't expect this to be so but don't complain, I have to assume this is part of the 'ceramic coating' option (ask them?).
I bought it from them when they had only 1 'ad' listed, where it was specifically mentioned that one did not know what brand one would get. Turned out to be a Ross which, visually, is a work of art, I just know you will like it. I recently bought a Wiseco piston (for a CRF230F, also h/c), but this Ross-one looks a lot better finished (if that is a fair comparison at all).
I see there's 2 different 'ads' on XRs' site now - which are confusing to say the least, they mix brands it would seem!
Anyway, they list the weights of the various pistons:
  • AL BAKER'S XR'S ONLY / ROSS PISTON - 334 grams
  • HONDA OEM PISTONS - 348 grams
  • JE PISTONS - 404 grams
  • WISECO PISTONS - 404 grams
If you're going to buy one I'd phone them to make sure you'll get what you want.
These weights do not correspond with what was posted here - where the std piston is reported to be substantially heavier than the Ross. Might be due to the pin, dunno.
Tonight I'll weight the parts and will post the respective weights.
Mind, don't have the OEM to weigh, only the (coated) Ross, may just help someone.
BuRPsa is offline   Reply With Quote
Old 11-22-2011, 04:43 AM   #11467
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
Originally Posted by Garthe View Post
Pictures...
coming today!
Old 11-22-2011, 06:41 AM   #11468
Garthe
Garthe's Avatar
Oddometer: 4,357
coming today!
2007 XR650R
2001 Montessa 315R
Old 11-22-2011, 08:11 AM   #11469
backdoc
bone cracker
backdoc's Avatar
Oddometer: 93
Usd
SO...I was finally able to take the pig riding after finishing the CRF-XRR USD conversion. I must admit that I like the look of the bike now a whole lot better as i'm partial to the gold anodized look. It mathces my gold anodized Unabiker radiator guards . AS for the handling on and off road..IMHO I think it handles much better than stock on the road and even better on the dirt. For all of the imates that helped with advise during the conversion a big THANK YOU is in order . I originally swapped the Clarke tank out for a Sahara tank, but the damn thing weighed so much and was uncomfortable on my thighs, so I went back to the Clarke tank and it rides 100% better.
Here it is with the Sahara tank.....the freakin thing is huge
I know its been a topic of much debate, but I must give a shout out to Mike at MANRACKS for providing me with a kick ass rack and under fender support for my XRR. I dont carry a whole lot of supplies or stuff when i ride, but it sure is nice when i have to .. The rear fender is solid as a rock and doesn't flop around like crazy anymore when i ride the woods or trails. I also love the MANRACK tie down brackets that mike sent. No more scraping up my pretty Renthal Fatties.
brackets on the top triple clamp
A shot of the Sahara tank and USD forks during the conversion.
WFO
2003 XR650R
1996 GSX-R-750 (bent in half by truck)
1984 XR500R (sold)
1986 TRX70 Fourtrax (sons)
backdoc is offline   Reply With Quote
Old 11-22-2011, 08:31 AM   #11470
Motomochila
Mad Scientist
Motomochila's Avatar
Oddometer: 1,114
Enjoy the USD setup. I did see that you retained the stock CRF clamps. Emig racing makes a great set with a stabilizer setup you might like even better. I did that a few years back before retiring the old girl. She's now sporting a CBR 600 front clip with F/R wheels to boot. The evil canyon conversion is almost complete. Amazing beasts the BRP's, they can do so much.
KTM-2014 500 EXC, 2014 690R, BMW- 2015 F800 GSA, 2012 K1600 GTL, Ducati-2015 Hypermotard SP, and 16 other motorcycles in various stages of restoration.
Motomochila is online now   Reply With Quote
Old 11-22-2011, 09:57 AM   #11471
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 170
Originally Posted by RideFreak View Post
It leans out the intake charge by opening a secondary passage in the carb.
Did you replace the cam chain while you were in there? Replacing a worn CC helps smoothness a good bit also, mine needs it so I going to tear into it this winter, I was considering a JE piston but you got me thinking I might try the Ross with it's lightweight.
Yes I did a chain at the same time, But what I feel as for less vibration, is in my opinion a result of weight reduction of reciprocating weight.
The removed chain was in really good shape. I suspect it was only at most 2 deg. retarded of a new chain chain?
FlyGuy is online now   Reply With Quote
Old 11-22-2011, 10:08 AM   #11472
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 170
Things that make me wonder why my stock bare piston with carbon weighs in at a hefty 414 grams
I am gona say that there might be two factory pistons of different weight or the XRs only site is wrong?
but what ever-lighter is better til it breaks then it isn't
here are the individual weights I have
Stock piston 414 grams
stock ring 24 g
stock pin 114 g
other notes stock pin is tapered but heaver than ross straight wall pin by 3 grams or so
Old 11-22-2011, 10:16 AM   #11473
lemanster
lemanster's Avatar
Oddometer: 92
Originally Posted by Agent2 View Post
Fire up the bike, see if the high idle is happening. If so, pull the gas tank, and disconnect the throttle cables. Fire up the bike and blip the throttle with your hand, if the high idle is gone, problem is most likely the cables, either kinked or adjusted too tight. Once I tightened up the cables using the adjuster on the return cable, resulting in instant hanging idle.
If the high idle still happens, perhaps a vacuum leak, A/P pump hydrolocking (doubtful since you said you replaced it), weak return spring, or ???
Where in California are you? I am in San Fernando Valley, would have no problem checking it out sometime, if you are local.
I'll try this today.
I am relatively local to SFV. In LA I'll send you a PM if I cant get this figured out. I'm leaning (quite far) toward pitching this carb, and going with an FCR. Thanks for the offer!
00 XR650R Cali plated motard/trail pig
04 CR250R
lemanster is online now   Reply With Quote
Old 11-22-2011, 10:20 AM   #11474
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,474
I agree, the less mass it's moving the better and easily the more significant factor when it comes to vibration and smoothness. I asked about the cc because in my expierence, the chain stretch make the motor start to feel a bit more lazy. I'm feeling it a little in my XR and plan to tear into it. The compression bump, a fresh cc chain and sorting out the valves is the same work I'm planning on doing in Jan.
Here's a video od a DS ride we just did, no rippin Just some easy stuff.
http://youtu.be/sC1nTy1oqug?hd=1
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 11-22-2011, 10:33 AM   #11475
BuRPsa
BuRPsa's Avatar
Oddometer: 548
OK, just finished weighing the Ross piston. Brandnew & clean, an 11:1 version, with ceramic coated top & Teflon coated skirt.
This is what I get:
- Piston 335 g
- Pin 109 g
- Ringset 37 g
- 2 Circlips 2 g
- weight of total (not plain added) 484 gram
Looks like:
Times are GMT -7.   It's 05:45 PM.
