12-11-2008, 11:50 PM
#106 |
I see dumb people!
Oddometer: 1,129
Yeah baby,only been for a couple of rides but at 5th gear flat out on the rev limiter it's scarygood.
Have the Staintune headers on now but haven't been for a run yet,they should be the bomb.
The mighty XR650R. The old trail bike that all modern trail bikes are judged by. It's funny cause it's true!. |
12-12-2008, 07:16 AM
#107 | |
neck
Oddometer: 220
40 vs 41
Yea, I never even heard any one talk about a TM41. Maybe some will post up, I will do some diggin.
"Just some ass hole trying to ice skate up hill" "Another Day, Another poor soul left in my Dust" DT-100 XR-650R VTX-1800 |
12-12-2008, 07:22 AM
#108 |
I see dumb people!
Oddometer: 1,129
Dosco maybe it's an FCR 41mm,i know there's one of them.
12-12-2008, 09:00 AM
#109 | |
neck
Oddometer: 220
Yes
I don't want to get into carbs again, but I my memory is right the FCR is a good carb just more expensive than the Mikuni, Right?
12-12-2008, 02:32 PM
#110 |
neck
Oddometer: 220
Fcr 41
Well guys, I could not pass it up, he will take $250 for the FCR 41, and will send cables as well.
Any body have anything on jetting this thing for 1000 ft above sea level, or any jetting rec's at all? Or should I just order some jets and start working on it?
12-12-2008, 03:45 PM
#111 | |
I will ride my whole life
Oddometer: 860
My envirnomental conditions are on the link above but I'm at 400 MSL and currently 35-45 F and 75-80% humidity on a good day! Some Links I found on the topic of jetting these FCR's; http://29dreamsracing.com/FZRinfo/Fl...ng%20Guide.pdf http://www.thumperfaq.com/jetting.htm (This is an FCR carb for a different bike but concept is the same)
The grass MAY be greener on the other side but it's ALWAYS greener around the septic tank. |
12-12-2008, 08:53 PM
#112 | |
neck
Oddometer: 220
Thanks again
, I hope to keep in touch with you. I will PM you when I get it in, and we can talk then. I will look at the links, thanks again. I have to say, I am very excited about the FCR 41. I think it will make the BRP say HELLO.
12-13-2008, 05:50 AM
#113 |
Oddometer: 177
Hey guys I'm in the process of getting a BRP from NM and the elevation is arnd 8,000 ft and I live in NC at 850 above sea level, my ? is what jetting will I use and what do I need to change in the carb to make it run properly?
By the way this thread is awesome
12-13-2008, 07:36 AM
#114 | |
Oddometer: 860
I know you don't have the bike yet...but Fill us in on as many details/upgrades/mods done to the bike that you can think of, such as...any exhaust changes, has the airbox been modified, has the intake boot been upgraded/modified, cam changes, Carb change? Also what year is it? I don't know how familiar with the bike you are but since you are on ADVrider I'm sure you have searched it and know a good deal about it already has it been been "uncorked" (has the previous owner (PO)) unrestricted id? for your area (let us know the temp ranges you run in) I'd try the 172-175 (start with 172) main, the B53E needle on 3rd clip from top and the 68s pilot jet These settings can change based on what you tell us about the bike, no worries we'll get it running right and you will LOVE IT! ![]() XRRK
12-13-2008, 09:05 AM
#115 | |
Northwest Adventure Rider
Oddometer: 127
2002 XR650R...Uncorked Stock Carb Elevation: 400 ft 172 Main during summer months (70 - 95 avg temps) 175 Main during colder months (40 - 50 avg temps) 68s pilot Clip at 3rd position from top Look here as well - http://www.xr650r.us/jetting |
12-13-2008, 09:26 AM
#116 |
Oddometer: 154
stock lighting upgrades with stock stator:
If you are running the stock headlight (in the U.S.), an A3603 bulb is a direct replacement for the stock bulb-and much brighter. When you solder the posts together you have a 50 watt bulb. A pack of two costs less than $5. It does not melt the plastic headlight lens. This has been my favorite mod to my '01 650R I bought used in 2005 (I plated it).
I also installed the "LED tail light inner kit" from Wheeling Cycle Supply. I use the stock taillight for a brake light and this LED kit makes it much brighter. I run the stock stator, and because of the LED tail light, the headlight no longer dims when I apply the rear brake. These two mods cost less than $30 together, and drastically improve the stock lighting while keeping the stock stator.
12-13-2008, 09:32 AM
#117 | |
Oddometer: 127
12-13-2008, 09:39 AM
#118 |
Oddometer: 154
Yeah, the A3603 is a dual filament that will fit in the stock headlight assembly. I think a new headlight bulb from Honda is aroung $25.
12-13-2008, 12:33 PM
#119 | |
Oddometer: 860
12-13-2008, 01:01 PM
#120 |
Oddometer: 177
Thanks Guys,
First I think I know enough about the bike that I can tell you the main things, it is a 01 BRP, jetted, desmogged, uncorked, HRC tip on the stock exhaust, no header, (yet), as far as the airbox I can't say yet, no hotcam, no major engine work. The weather here right now is 40's thru the day and gets into the 20's at night and I ride whatever time, rain or shine. Hope that helps! And thanks for the chart! spoolie screwed with this post 12-13-2008 at 01:06 PM |
