Old 03-13-2012, 01:48 PM   #12526
dohcfox
meh
dohcfox's Avatar
Oddometer: 150
I might have a look at that too, if I can't resolve starting with adjustments in the fuel screw and idle setting. Thank you!
Originally Posted by crypto666 View Post
Check you valve gap (lash). I have heard that tight exhaust valve lash will make it hard starting too.
dohcfox is online now   Reply With Quote
Old 03-13-2012, 02:06 PM   #12527
Gildus
Gildus's Avatar
Oddometer: 238
Originally Posted by Burgman View Post
Hi All, I am in the middle of rebuilding my 04 XRR, and have been curious about the stock aluminum sub-frame .
The bash plate on the bike when I bought it was basically scrap metal ! but most of the rest was OK , so I was kinda expecting to see some stress cracks on the sub-frame, none anywhere! the top frame mount was ovaled a little on both sides, TPO had a billet rack mounted, one bolt was sheared. So to get to the question, I am planning on loading my bike with the same type bags and eqipment and tools, are you running the stock sub-frame or have you reinforced it ? The rest of the BRP riders here, what is the percentage that find the stock set up adaquate or working fine, to those that have found it neessary or prudent to replace with steel or re-inforce with more aluminum ?
The direction I am leaning now is,a steel suf-frame along with a bolt-on steel cargo rack that has lashing points and lighting mounts. I am looking at a l.e.d. strip type light w/ tail-stop-and turn all in one, that will mount up under the
cargo rack, and still alow the plate/ holder below it. If the rack is detachable it can be repaired or replaced seperate
from the sub-frame.
Some have used the stock subframe with heavy loads without a problem - others have had them fail under moderate/light loads. From the posts I've seen, there doesn't seem to be a pattern to the failures, i.e. loose bolts, etc. It may just be an issue of metal fatigue over time. I was looking at the steel subframe too but decided to reinforce the stock aluminum one. It's a lot cheaper and lighter. If I was planning an epic trip with a seriously overloaded XRR, I might go with with steel but not otherwise. Just my 2 cents ....
Gildus is offline   Reply With Quote
Old 03-13-2012, 04:26 PM   #12528
Ironwood
Friday Harbor, WA
Oddometer: 753
Sub-Frame
Re-enforcement makes sense to me. So where are the common failure points on the sub-frame? Thanks, Joe
Ironwood is offline   Reply With Quote
Old 03-13-2012, 04:51 PM   #12529
Jungle Man
frenzied adventurer
Jungle Man's Avatar
Oddometer: 497
Sub frame reiforcements.
Check on page 834. There is a good picture of a strengthened sub-frame. They usually fail where they are through bolted to the frame up top.
"50% of our maintenance is caused by 50% of our maintenance." -Dave. "If you're too busy to hunt and fish, you're too busy" -Jase Robertson. "...it's not the years in your life, but the life in your years" -Abe Lincoln
Ride it like you stole it
Jungle Man is offline   Reply With Quote
Old 03-13-2012, 05:07 PM   #12530
Gildus
Gildus's Avatar
Oddometer: 238
Old 03-13-2012, 06:33 PM   #12531
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by NMZens View Post
Loaded up!
4 hours later found Hunt's Lodge to dry out and revel in a day well spent in the Smokys!
That is one BAD ASS XRR!!
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 03-14-2012, 12:05 AM   #12532
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
i think most subframe issue's come from the owner not setting suspension up correctly ....this has a lot to do with carrying loads
Sean-0 is online now   Reply With Quote
Old 03-14-2012, 04:01 AM   #12533
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Fox,
allow me a thick question: do you know how to start this bike?
I'm asking because you mentioned 20 kicks or so, and if this would be normal for this bugger then I'd hate the thing... but love it instead, zero need for a fag button.
1 kick, maybe 2 are required..... however, that's the "power"-kick, pls note. On 'cold' starts (not minus gazillion, no gletchers neither frozen deers, just on a coolish morning) set the choke on the first click (not closed), cycle the kickstarter a few times (3? Whatever, a few) whilst pulling the decomp and with closed throttle. Then kick without pulling the decomp until it gets 'hard', pull the decomp and inch the kickstarter an inch down further. Then come up with the kickstarter and hammer it down, and don't even touch the throttle.
If that does not do it on first try, or the second, then up the idling screw (the slide-screw, the stopper!) a bit, and repeat all.
I up the screw most of the time when cold, but then again it never gets real cold here. And mind, my male chicken on a block mine is jetted correct.
This "upping" of the screw is very little so btw, it will idle just quick enough to get some heat in, and I quickly - after letting the choke go of course) turn it back again. As a matter of interest, this exact procedure is identical for the std carb as well as the TM40 (no, I don't have to squeeze some juice in, however that helps I'll admit).
If the above does not work there's something wrong: foul/old plug, or carb-settings, dirt or whatever, but you better find it. This bike starts very easy if all is right.
If you knew all of this - sorry for the lecture bru, find what's wrong.
BuRPsa is offline   Reply With Quote
Old 03-14-2012, 04:23 AM   #12534
BuRPsa
BuRPsa's Avatar
Oddometer: 548
You clever dick you
'Course it has, plus add that sitting types (me mostly. Anyone else?) will add to possible woes.
I don't think this is a real "weak" spot, like a flaw in the design, as it was designed a racer.
But start adding luggage, an arse, bad setup and other types of abuse, and it just mgith say 'no more'.
There is an easy patch for this though.
Drill out the thread of the threaded LH-side (size drill same as the hole in the RH-side), and put a bit longer bolt through the lot, then add a washer and a nut (a nyloc one I'd recommend).
This way both sides of the square tubing, on both sides of the frame, are equally loaded in tension - instead of on the LH-side on ONE side of the square tubing only.... hence the cracking/tearing here, and always only here!
No welding, just a drill + bolt.
Use it, don.t...
Old 03-14-2012, 06:50 AM   #12535
dohcfox
meh
dohcfox's Avatar
Oddometer: 150
Hey, no worries, I've got thick skin! And I thank you for taking the time to write so much about the proper starting routine for the XRR. :cheers:
Anyways, it turns out that the starting routine that you mention is the exact same routine that I use: pull in decomp, cycle the motor a few times, let out the decomp, cycle until you find the hard spot, pull in decomp and push the kicker just a hair further, and kick, all the the way down to the foot peg.
It's been cold up here in these parts; about 3 degrees celcius when I ride to work in the morning. That said, I might have a look at the idle setting, although it seems to idle at an acceptible RPM. Did I mention earlier that the bike starts up super easy when warm? Rides absolutely wonderful too. LOTS of power.
The guy that sold me the bike also included the specs on the jets that he put in the carb. I'll try to find them and then post them here.
Hey, enjoy that warm weather you lucky SOB! Take care! JT
Originally Posted by BuRPsa View Post
Fox,
Old 03-14-2012, 07:06 AM   #12536
M.A.G.
I heart Penalties
M.A.G.'s Avatar
Oddometer: 1,010
Fox,
Don't forget to yell, "Startpiggystartpiggystartpiggystart!" too, whilst kicking...
M.A.G. is offline   Reply With Quote
Old 03-14-2012, 08:40 AM   #12537
Jungle Man
frenzied adventurer
Jungle Man's Avatar
Oddometer: 497
Interesting, I never thought to yell anything at the bike that wasn't a profanity. I'll have to try it sometime.
Old 03-14-2012, 08:47 AM   #12538
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 831
NMZens, what kind of forks are on your XR?
2000 XR250R - Tagged
1998 XR400R - To be tagged
2003 XR650R - Sold 2006 Ducati Monster -Sold
'Cause I like to party - Story of 2 XR650s conquering Florida
http://www.advrider.com/forums/showthread.php?t=754094
SpeedoJosh is offline   Reply With Quote
Old 03-14-2012, 09:04 AM   #12539
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Fox,
the bike changed altitude when you bought it, say over ~500 meters? Not impossible, just asking.
If so you'll know you have to re-jet - that's the main but also, to a lesser extent, the idle-circuit too.
Here's some common wisdom.
On most (I almost said any, but I haven't seen them all) carbs the mixture-screw (the quality-screw that is, not the quantity-screw - but this carb doesn't have one) is set anywhere in a 3-turn range from closed - mind, full turns. As this indicates an average setting of 1.5 turn you should aim for this, let's call it the sweet spot, and indeed this is often indicated in manuals: 3 half turns!
Because I am anal I will not allow more than a half-turn off that mark, unless it's a temporary setting (change of altitude say). Bear in mind that this screw is the only variable of a system consisting of a fuel-jet (idle jet) plus an air-jet which doses the air mixed with this fuel into a spray. Both jets are fixed but changeable to another size.... which means if I feel I'm too far off the "1.5 turns" I change the jets accordingly. Yes, I'll admit that the latter is a bit of 'feel', or experience, but right I will get it, and you should too.
0.5 and 2.5 turns is way too far off in my books, never mind what others (will) say, and if yours is set thereabouts then you know what you'll have to do.
Good to know you've got a thick skin, because I've another thick question: you have seen the altitude-dependent jetting-table floating on the net somewhere? If memory serves me well some Tim compiled it, and it is quite close if not spot on. Find it & check against what you have?
Old 03-14-2012, 09:10 AM   #12540
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,977
I never yell at an XRR, I beg and plead.
Times are GMT -7.   It's 05:45 AM.
