Old 04-14-2012, 05:06 PM   #12826
aiMhi
Now with Titanium
aiMhi's Avatar
Oddometer: 686
That bike looks badass with those black rims and the upside down forks - those are the bomb
Originally Posted by Starkman View Post
And now for some XRR porn.
[IMG][/IMG]
aiMhi - Honda XR650R - AMA- RMAR
aiMhi is offline   Reply With Quote
Old 04-14-2012, 05:33 PM   #12827
hontri
Global Bummer!
hontri's Avatar
Oddometer: 303
Originally Posted by NorCal Dog View Post
where's the best ( & cheapest ) place to get a longer brake line, clutch cable, throttle cables, ect ?
You can try here: http://www.motionpro.com/motorcycle/...tegory/cables/
hontri is offline   Reply With Quote
Old 04-14-2012, 05:54 PM   #12828
NorCal Dog
NorCal Dog's Avatar
Oddometer: 44
Originally Posted by hontri View Post
awesome, they're local
thank you much
NorCal Dog is offline   Reply With Quote
Old 04-14-2012, 07:15 PM   #12829
Starkman
Starkman's Avatar
Oddometer: 84
Originally Posted by jungleplant View Post
NICE RACK
This rack is perfect for what I need. It's small and compact and is a great anchor to attach my 20 liter dry bag. Here it is in action in Mexico.
I also have a Texas Turbo rack and it's too big and the inner brace interferes with the tire on full bump.
Thanks for the great product!
No matter where you go, there you are...
Starkman screwed with this post 04-14-2012 at 07:37 PM
Starkman is offline   Reply With Quote
Old 04-14-2012, 07:28 PM   #12830
Starkman
Starkman's Avatar
Oddometer: 84
Originally Posted by Ironwood View Post
But can that dog hunt??
Not a poser, last month I rode her over 1800 miles in Baja. Didn't burn any oil and worked great. There is a lot of talk of the steering head breaking off and death wobble with the USD swap. I can tell you they work right. Progressive in slowing full compression and stable as before swap. High speed rock hits are less harsh then before also. Believe me I hit some nasty rocks at very high speeds and no issues, other then my own stupidity...
I guess there is a few hundred miles left.
[IMG][/IMG]
Old 04-14-2012, 07:34 PM   #12831
Starkman
Starkman's Avatar
Oddometer: 84
thank you much
I got a set from them a few months ago. Great customer service and great product.
Old 04-14-2012, 11:40 PM   #12832
mattymurn
mattymurn's Avatar
Oddometer: 25
question on rekluse EXP install, replacing a completely trashed clutch
picked up a rekluse exp clutch
when you install these do you still use the judder and the thinner fiber at the start of the pack ?
also, when removing the old clutch it was really fried, some fibers were pretty badly worn, my downtube oil screen was also pretty full of debris from what looks like the disintegrated fibers, do you think I should pull the right side crankcase cover and clean the larger screen in the bottom of the engine ?
I flushed oil thru the frame and its clean now but am concerned if thats good enough..
thanks
mattymurn is offline   Reply With Quote
Old 04-15-2012, 06:05 AM   #12833
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,129
[IMG][/IMG]
Starkman, I'm pretty sure the cracked steering head was a rumor started over on TT, never seen a pic of it or heard from anyone who actually had first hand knowledge of one breaking, the XRR frame is very stout up front. Most of us don't subject it to any serious stress anyway. I call BS on the whole USD/frame issue. I wouldn't hesitate to do the swap if I could lay my hands on the parts for a decent price.
Looks like a great ride!
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 04-15-2012, 09:47 AM   #12834
Starkman
Starkman's Avatar
Oddometer: 84
Agreed! If Johnny Campbell didn't break frames I can't.
As far as parts go, I used a 2001 CR250R set. I had them so the price was right. Interesting thing is they are stock with stock springs and valving. I'm sure you also read a lot of talk of spring rates and valving being off with the USDs. I ran damping at 3 clicks in from full soft on both sides and it seems real close. Of course running a 6.5 gallon fuel tank makes it too soft when the tank is full and too hard when empty. But they resisted bottoming well when heaviest and didn't hit my hands too bad at the lightest. I will say it has been a success. I used the adapter bearings and had to file the steering stops to get full range of motion on the CR tripples but not too hard to do. Another interesting thing I found was the CR brake hose was too short and interfered with my headlight, so I used the complete XR brake master cylinder, hose and caliper. It was direct bolt on. Also, I had Warp 9 wheels mounted on the stock XR forks and when I called Warp 9 to see what I needed to swap them to the CR forks they told me that the XR wheel was a CR wheel with adapter spacers and to make them fit just use the stock CR spacers. All in all the swap was pretty easy.
Old 04-15-2012, 10:45 AM   #12835
NMZens
NMZens's Avatar
Oddometer: 80
RideFreak, if you're serious about a conversion PM me. I've got the CR500 triples, a set a 47mm Showas, and even the front axle that you can have. I had to bite the bullet and buy Emig clamps because I had minimal time to get Burpy ready for last months ride in TN. You'd just need a wheelset and some machine work to complete. I'd rather have the parts go to an inmate that would use them then sell it all through FleaBay. I'm in Abq. If interested. I figure I owe you anyway because I used your schematic as the foundation for my DS conversion.
"A zest for living must include a willingness to die." ~R.A. Heinlein
NMZens is offline   Reply With Quote
Old 04-15-2012, 02:22 PM   #12836
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,129
NMZens, Let me first say, Welcome to ADV, that's a great way to start off on here Def interested in the conv parts and I sent you a PM. Let me know how I can return the favor!
Chris
Old 04-15-2012, 02:45 PM   #12837
offrdr1975
offrdr1975's Avatar
Oddometer: 113
Finally got my XRR back together.
I finally got my XRR back together after doing a complete tear down and rebuild. The engine got a new Piston and rings, Kibblewhite valves, Cam chain and sprockets, Hinson Clutch basket with a new clutch, and a Rickystator high output stator. I had all of the suspension rebuilt as well as new bearings everywhere. I had new wheels laced up by Woody's along with an oversize front rotor and a new rotor in the rear. I also added a seatconcepts seat. It should be ready for another 10 years of great service.
From This
to this
to this
To finally this
Now it just needs a little more fine tuning and it will be ready to go.
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 is offline   Reply With Quote
Old 04-15-2012, 03:04 PM   #12838
Starkman
Starkman's Avatar
Oddometer: 84
I forgot to mention that the best thing about this rack is that you can remove the side cover with the rack in place, no other on the market allows you to do that. One design feature of the XRR and most enduro type bikes is to be able to check and change the airfilter quickly. Nice!
Old 04-15-2012, 03:07 PM   #12839
Starkman
Starkman's Avatar
Oddometer: 84
Nice, seems like quite a few XRRs around Denver. We should have a Colorado XRR rendezvous.
Old 04-15-2012, 04:43 PM   #12840
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,253
Do it RideFreak. Looks looks like a great mod.
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo is offline   Reply With Quote
Times are GMT -7.   It's 08:13 AM.
