Old 04-15-2012, 10:36 PM   #12841
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Do the sprockets need to be replaced along with the cam chain?
Any issues with reusing the stock piston?
lstzephyr is offline   Reply With Quote
Old 04-15-2012, 11:18 PM   #12842
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,246
The sprockets don't normally require replacement, as for the piston, you'll have to measure it and compare it to the spec, it's anyone's guess.
I need to do the CC also, I can feel it starting to get a little lazy as it stretches and the cam timing shifts a little.
Here's a couple pics from today's DS ride.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 04-16-2012, 06:02 AM   #12843
offrdr1975
offrdr1975's Avatar
Oddometer: 113
I probably could have gotten away with reusing my Cam Chain sprockets,but they are fairly inexpensive and with the amount of hours on my bike I replaced them as a set. Just like your drive chain and sprockets they will wear together and the best combination is to replace them as a set in my opinion. As said earlier you need to measure your piston to make the determination of whether or not to replace it.
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 is offline   Reply With Quote
Old 04-16-2012, 06:54 AM   #12844
jules083
jules083's Avatar
Oddometer: 4,045
Originally Posted by offrdr1975 View Post
I finally got my XRR back together after doing a complete tear down and rebuild. The engine got a new Piston and rings, Kibblewhite valves, Cam chain and sprockets, Hinson Clutch basket with a new clutch, and a Rickystator high output stator. I had all of the suspension rebuilt as well as new bearings everywhere. I had new wheels laced up by Woody's along with an oversize front rotor and a new rotor in the rear. I also added a seatconcepts seat. It should be ready for another 10 years of great service.
Nice. Mine's probably getting this treatment next winter. I was going to do it this winter, but time and money said otherwise.
Just wanted to throw these pics up of my winter progress. I added the BD light, ATV high handlebars, new plate mount, speedometer from a 1984 xr250r, and the 4.3 gallon tank. A new skid plate is sitting in the house, need to throw it on one day. I notice the weight difference, but it's reasonable depending on the trail. Handlebars seem a bit high when sitting down, about right when standing up. The cables barely made it, another inch or two and I'd have needed longer throttle cables. I had to slide the compression release down a bit, but it's still reachable. The headlight is awesome, points down enough for street riding and I haven't been pulled over yet.
I'm thinking about maybe making the XRR more street friendly and dual sporting my XR250R for the harder trails. It's getting heavier as I go, and it's a handful on tight single track. The trail the pics were taken on was a bit much for me, I'm only 5'9'' and 150lbs. The only thing I would probably do is replace the Kenda Trackmaster II's with 606's or something when they wear down, which happens pretty often. I keep finding myself wanting to go on longer rides and exploring more, and the thought of the back tire melting off is always in my head when I get on the highway. I guess every bike is different for a different situation, and my local riding area is better suited for a lightweight 'flickable' bike. I'd like to get a WR250R, but don't really want to buy another bike or sell this one. The xr250r is a 1984 and not worth much, it'll just keep it for all that I'd be able to sell it for.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 04-16-2012, 07:01 AM   #12845
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Ist,
piston, measuring - dunno if you know how that works? (No, I didn't check on the manual, it may tell you this also).
You need a calibrated micrometer of the correct size (100mm), and use the ratchet-knob only! Then measure the piston at various heights/places - and measure at each place/height twice: you need to measure in the direction/plane the crank rotates as well as 90 degrees off this, so 'across'. The piston 'rocks' in both TDC & BDC, and this causes most wear, especially so with the modern short-skirted pistons. The 'lands' (correct word?) between the piston rings are normally most affected, this in the rocking-direction of course, as measuring 'across' you may find either zero wear or a lot less. Only if the piston measures fine I'd reuse it, with new rings that is.
Maybe best to take it - with the specs - to someone who knows, and has got that equipment?
How's the cylinder - the nikasil still fine, no edges and/or irregularities? Don't try to do any honing (way too hard), if it's fine just use a mineral oil to run the lot in. If you really really want to use a small piece of very fine waterproof sandpaper, and then clean it like your like depends on it afterwards! Oh, rub it only at 45 degrees, a cross-pattern.
Here's some advice to run-in - and yes, anyone may have (has?) different/other opinion(s) on this, but here's mine.
Once ready to run start it, and let it idle until really warm, hot actually.
Switch off and let it cool down fully, eg overnight.
Repeat 3 times.
Then the 4th time (day?) go ride when warm, and nurse (low revs & very low load, this all at low speeds) it around the block a few times. Then, park again to cool down fully.
The next time do a bit more of everything, a bit further too, and of course let it cool down again.
Then take it for a ride, still easy does it. Better up the revs than the load, your last thing of running-in is fully loading the engine - at some 250 miles or thereabouts.
Then drop the oil & filter, put new stuff in and ride.
Yes, this whole scenario takes time and patience - but it's worth it I think. The various heat-cycles allow material to be taken off precisely there where it is needed, and also just by the correct small amounts rather than in (relationally) big lumps.
BuRPsa is offline   Reply With Quote
Old 04-16-2012, 03:47 PM   #12846
thouk
Oddometer: 196
Here ya go...
Hey Ya'll,
I have my engine broken down with the cases split. I called the local STEALERSHIP and explained the such. I asked how much to just press out the crankshaft. I was quoted $70 - $80. I about laughed in the guys ear after hearing that. Today I went down to the base, retired military, and went to the auto hobby shop. About twelve minutes and four dollars later I walked out $66 better off. I stopped at cabelas and got some ammo for the sporting clays shoot this weekend with that money I saved. It sure does help to be mechanically inclined. Ride safe, Tony
My Miss Piggie, a dual sported Honda Xr650r.
My Ottoman, a lovely Honda PC800 Pacific Coast
May God look upon you as you ride with Jesus with the Holy Spirit in your heart.
thouk is offline   Reply With Quote
Old 04-16-2012, 04:35 PM   #12847
Xr6FiftyRider
Oddometer: 1
Ticking noise.
Hi all. Im new to this forum and just purchased a 01' xr650r for a killer deal. Thing is it has been ridden hard and put away wet. the motor is all stock except for the removal of the emissions kit. The downer is that the motor is making a really loud ticking almost knocking noise. It starts and idles fine. I thought it would just be the valves. I checked them and one intake was a little tight and one exhaust was loose and the others were in spec. I tried to video it but you cant really hear the noise so well. http://s1157.photobucket.com/albums/p581/xr6fiftyrider/?action=view¤t=0416121553.mp4
Xr6FiftyRider is offline   Reply With Quote
Old 04-16-2012, 04:52 PM   #12848
Shibby!
Oddometer: 1,666
Few questions:
1) Is that exhaust leak you can see or breathing on the lens?? Exhaust leaks can be very loud.
2) Ticking is hard to hear, but be careful. Lots of people adjust valves when decomp is engaged throwing out one exhaust valve.
3) Check slack on decomp cable to be sure it's not partially engaged. There should be LOTS of slack in the lever, and the engine mounted lever should return to resting position.
4) Seeing the side cases with that much wear makes me think there are lots of hours and miles on that engine. Might be time for some work.
5) Idle seems odd or is that you adjusting it? Does it rev up on its own and stumble off when chopping throttle?
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-16-2012, 06:19 PM   #12849
Gunslinger1
GIVE'R
Oddometer: 627
More Porn...........
Gunslinger1 is offline   Reply With Quote
Old 04-16-2012, 07:18 PM   #12850
Starkman
Starkman's Avatar
Oddometer: 84
Tell us about that box mounted down on the skidplate.
No matter where you go, there you are...
Starkman is offline   Reply With Quote
Old 04-16-2012, 08:40 PM   #12851
Gunslinger1
GIVE'R
Oddometer: 627
Had a guy make this box out of aluminum...........trying to get some tool weight down low.
Old 04-16-2012, 09:56 PM   #12852
Shibby!
Oddometer: 1,666
They work well, until you crush them on rocks in Baja. haha.
I had one on mine too. I had an issue with rusting tools and being packed with fine grit. Might build a redesigned one here eventually.
Nice looking bike! One of the nicest XRR's I think. Black wheels on XRR's make them look delicious.
I see you have the wolfman tank bag too. I couldn't get along with mine. I had the Expedition model and sold it to get the Giant Loop Wrap. Didn't get in my way while riding. I like to sit right up front close to the filler cap. Do you have the same issues?
Old 04-17-2012, 05:09 AM   #12853
Gunslinger1
GIVE'R
Oddometer: 627
Same issue with rusting tools, grit, and moisture. This thing was made tight and I thought it would resist the water but not so. I have this tank bag on a lot of bikes and did notice it at first. I don't stuff it full and it is working OK. I mostly use this bike for Long Haul Trips like the Western TAT.
Old 04-17-2012, 07:52 AM   #12854
Agent2
Oddometer: 130
I'd like to build something like that, but out of PVC pipe, glued cap on one end, threaded cap on the other. Wondering how to attach it to the skidplate, guessing some sort of metal saddle brackets must be available.
Agent2 is offline   Reply With Quote
Old 04-17-2012, 11:08 AM   #12855
Shibby!
Oddometer: 1,666
Lots of people do that. Might be considered somewhat KLRish, but there is no denying it works. You'll get the odd dirty look driving past the BMW's at starbucks.
Instead of a threaded end you can use a pressure testing cap.
Times are GMT -7.   It's 05:46 PM.
