Old 04-16-2012, 08:40 PM   #12856
Gunslinger1
GIVE'R
Oddometer: 592
Originally Posted by Starkman View Post
Tell us about that box mounted down on the skidplate.
Had a guy make this box out of aluminum...........trying to get some tool weight down low.
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away."....Antoine de Saint Exupéry, 1939
Gunslinger1 is offline   Reply With Quote
Old 04-16-2012, 09:56 PM   #12857
Shibby!
Oddometer: 1,381
They work well, until you crush them on rocks in Baja. haha.
I had one on mine too. I had an issue with rusting tools and being packed with fine grit. Might build a redesigned one here eventually.
Nice looking bike! One of the nicest XRR's I think. Black wheels on XRR's make them look delicious.
I see you have the wolfman tank bag too. I couldn't get along with mine. I had the Expedition model and sold it to get the Giant Loop Wrap. Didn't get in my way while riding. I like to sit right up front close to the filler cap. Do you have the same issues?
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-17-2012, 05:09 AM   #12858
Gunslinger1
GIVE'R
Oddometer: 592
Same issue with rusting tools, grit, and moisture. This thing was made tight and I thought it would resist the water but not so. I have this tank bag on a lot of bikes and did notice it at first. I don't stuff it full and it is working OK. I mostly use this bike for Long Haul Trips like the Western TAT.
Old 04-17-2012, 07:52 AM   #12859
Agent2
Oddometer: 119
I'd like to build something like that, but out of PVC pipe, glued cap on one end, threaded cap on the other. Wondering how to attach it to the skidplate, guessing some sort of metal saddle brackets must be available.
Agent2 is offline   Reply With Quote
Old 04-17-2012, 11:08 AM   #12860
Shibby!
Oddometer: 1,381
Lots of people do that. Might be considered somewhat KLRish, but there is no denying it works. You'll get the odd dirty look driving past the BMW's at starbucks.
Instead of a threaded end you can use a pressure testing cap.
Old 04-17-2012, 02:56 PM   #12861
dohcfox
meh
dohcfox's Avatar
Oddometer: 102
A couple of strategically placed cuts in the skid plate will accept hose clamps large enough to secure a piece of pvc pipe. I run test plugs on mine; perfectly sealed every time.
dohcfox is offline   Reply With Quote
Old 04-17-2012, 08:39 PM   #12862
Hoologan
Hoologan's Avatar
Oddometer: 187
Here's the fan bracket that I fabbed up this weekend.
I mounted it low enough to work with both my Clarke 4.3 and of course the Acerbis 6.3.
I'm hoping that I won't lose too much cooling effect by ditching the KTM shroud, but we'll just have to see.
I also installed an Eastern Beaver 3 circuit fuse holder and relay tied into the ignition switch, so now my GPS, heated grips and fan are only enabled when the key is on.
I stuffed the fuse holder and connectors in the gap between the airbox cover and rear fender and used proper open barrel connectors for reliability.
2003 DL1000
2003 XR650R
2006 GSXR600
Hoologan is offline   Reply With Quote
Old 04-17-2012, 09:00 PM   #12863
windquest
windquest's Avatar
Oddometer: 503
A very nice fan bracket.... very clean. BUT could you please tell me about your headers?? where did you get them from?
Trans-Canol 2014ish
windquest is offline   Reply With Quote
Old 04-17-2012, 09:18 PM   #12864
Shibby!
Oddometer: 1,381
I believe they are Big Gun. As far as I know, they are the only header to fit behind the down tube.
Very nice crimp jobs. I love Eastern Beaver for quality connectors, but I'm ashamed to say I do it half ass without the proper crimper. I back that up by soldiering every wire connection though.
Old 04-17-2012, 09:44 PM   #12865
Hoologan
Hoologan's Avatar
Oddometer: 187
It is a Big Gun full exhaust. It was on the bike when I got it.
Thanks Shibby! It's my first time using these, but I got the right crimper so it wasn't too hard.
2003 DL1000
2003 XR650R
2006 GSXR600
Old 04-18-2012, 03:28 AM   #12866
BuRPsa
Pumpkinhead ;-)
BuRPsa's Avatar
Oddometer: 454
Hoologan,
"I'm hoping that I won't lose too much cooling effect by ditching the KTM shroud, but we'll just have to see"
No you won't, in fact the cooling effect remains same (ignoring fractionally higher friction of the now higher-speed air passing through the radiator, but this is only meant for those a bit nerd-inclined )
That shroud, when the fan is off, blocks/restricts the air passing thought the radiator, hence the cooling of the rad is less ergo the fan will come on more often.
When it comes on though it pulls air through a larger area (the entire shroud's), so it stands to reason that the fan will run a bit shorter (compared to no shroud).
Without shroud more air will flow through the rad (when fan = off) hence it will cool better, so the fan will come on less often.
And, when it is On, because it will cool a smaller radiator-area it will run a bit longer than before.
A "bit" yeah, because the airspeed is a lot more since it is a smaller area now, so it will cool that smaller area a lot better than when it has to serve a larger area (the whole shroud).
End of Leson Wan Zermodinamiks
BuRPsa is offline   Reply With Quote
Old 04-18-2012, 07:17 AM   #12867
Cpt. Ron
aka Birdkilla
Cpt. Ron's Avatar
Oddometer: 2,349
Solder joints are prime places to have the wire fracture since it is very rigid while the stranded wire is not. Fractures will occur right at the joint if they aren't restrained properly. And soldered wire connectors, since they get disassembled often, are more likely to break compared to crimped connectors.
Cpt. Ron
Sack-O-Tomato, CA
'05.5 950 Adventure S "Bad Mutha F@&ker"
'04 R1150RTP "cop motor, cop suspension.."
'00 XR650R Dual Sport "Lil' Mule"
'75 RL250
'01 TTR90
'01 PW50
Conti TKC80 tire swing
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 04-18-2012, 02:29 PM   #12868
PeteN95
PeteN95's Avatar
Oddometer: 1,681
But if you solder the end of the wire below the crimped connector, that is the best!
"If you ain't slidin', you ain't ridin'"
SVN/XRR/Christini
PeteN95 is offline   Reply With Quote
Old 04-18-2012, 03:24 PM   #12869
Shibby!
Oddometer: 1,381
This may be so, but I still believe if the proper crimpers aren't use soldiering can only help.
25,000 problem free km's and counting..
Old 04-18-2012, 05:21 PM   #12870
Hoologan
Hoologan's Avatar
Oddometer: 187
Originally Posted by BuRPsa View Post
Hoologan,
The shroud has a rubber "backdraft damper" in it to minimize restriction when the fan is off and the bike is moving.
Yes, I will lose effectiveness of the fan without the shroud. The shroud increases the surface area which decreases the velocity, increasing the DeltaT. Q=CFM x cp x DeltaT Higher velocity DECREASES the DeltaT and the total heat transferred.
Will it be enough to negate the effort of installing the fan, though? Probably not.
2003 DL1000
2003 XR650R
2006 GSXR600
Times are GMT -7.   It's 10:44 AM.
