Old 05-16-2012, 11:11 AM   #13246
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,250
Originally Posted by NMZens View Post
Pick a direction and ride.
I agree, but when routing a trail in unfamiliar territory, I'd prefer to be able to easily verify where I am in relation to where I need to go. Especially when I start exploring. The 60csx loses to much detail when zoomed out to figure which road/trail I need to take back. The Lowrance isn't too much larger than a commonly used Garmin 276c but it is quite a bit more powerful. Here's my route for BB. I can't afford to be endlessly lost in the desert with my buddies 1.9 gallon fuel capacity on is WR ;) There's about a bajillion dead end roads out in the Chihuahuan desert.
[/QUOTE]
The 60 isn't going to have that nice of a picture and I agree the lorance is better suited for OR nav. I've never found that I couldn't figure out where I was and follow a track using the 60, it's just not as fast and more of a PITA than the big screen. You def cant see the 60 while riding, if the size doesn't bother you, I'd say go for it.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-16-2012, 11:14 AM   #13247
NMZens
NMZens's Avatar
Oddometer: 78
[QUOTE=RideFreak;18700817][QUOTE=pigpen;18697697]
Originally Posted by jm-2008 View Post
NMZens, you should post up a better pic of your XR
This is loaded up for a self supported 5 day ride, I don't usually ride this fat.
"esp since you're still carrying the other gps.
Just taking the Garmin as backup since I'm unfamiliar with Lorry right now.
"A zest for living must include a willingness to die." ~R.A. Heinlein
NMZens is offline   Reply With Quote
Old 05-16-2012, 11:47 AM   #13248
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,356
As always Chris, excellent info given. In a very well thought out manner. I too was looking at that BIG Lowrance, severial years ago. For many of the same reasons. But, my KISS approach...finally made me see the light. I went with the Garmin 60. In dirt riding, sometimes you have to compromise.
NMZens, with all due respect...tell your friend to get a bigger tank. Also, very nice looking bike.
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 05-16-2012, 01:33 PM   #13249
crypto666
Oddometer: 1,388
So I have been using a 60cs for the past few years, and I notice that a lot of you have them mounted on the bars. I never had any luck with thay because it always shuts off (breaks battery contact) on hard bumps and vibration.
so I have just resorted to leashing it to my back pack strap. It is nice there because I can grap it and read it without coming to a complete stop, usually, sometimes I fall down.
So have any you had any issues with the 60 shutting down while in bar mounts?
I just lost mine and am getting ready to pull the trigger on a new 62.
Btw, that is a good looking bike of NMzens. One of the better looking xrr I have seen.
crypto666 is offline   Reply With Quote
Old 05-16-2012, 02:04 PM   #13250
Garthe
Garthe's Avatar
Oddometer: 4,356
^^^^ Due to injury, I have not been able to test this TT mount. However, friends of mine have used this TT mount for there Garmin 60's. It has gotten great reviews, from the owners that I know. Here in AZ, the roads are very rough. To me the only down side of this mount, is the price. If you want to play, you sometimes have to pay.
2007 XR650R
2001 Montessa 315R
Garthe screwed with this post 05-16-2012 at 02:09 PM
Old 05-16-2012, 02:19 PM   #13251
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 787
[/QUOTE]
Just my 2 cents here, but I agree with other inmates that you dont need the big GPS screen your carting around. The small Garmin will do just fine, and you have to zoom in to get the needed detail. In Big Bend where your going the roads are well established. Unlike other states, Texas does not have miles and miles of public dirt roads to get lost on. You wont really be exploring trails because there are none where your going, unless you have access to ride on private property that has them. You will be on park or county roads. You will find many locked gates and warning signs if you come up on private property. But, GPS and maps are CRITICAL to confirming you are on a public road, as often land owners will try to "fake you out" with a sign or chain and lock hung on a gate. Navigation inside Big Bend National Park is quite easy itself.
That big unit will get in the way, and likely bust when you fall or drop the bike.
If you have time, check out Big Bend Ranch State Park (BBRSP), note: STATE PARK, for the best dual sport riding in Texas. Check out report here:
http://ridedualsport.com/forum/index.php?topic=2515.0
Navigation in BBRSP is more difficult in some areas, but signage is pretty good. Your Garmin will serve well for bread crumbs. The 4x4 roads are lots of class 2 and 3, there is bunk house you can stay in. BBRSP offers more technical riding than Big Bend National Park. Each are great in their own way. Wear quality protective gear in BBRSP. It is very remote, and rescue is a min. of 4 hours just to get someone out to you.
Also, your riding partner really needs a bigger tank.
Enjoy your trip to TX and looking forward to hearing about it!
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 05-16-2012, 02:30 PM   #13252
DocAxeYarYar
RideDualSport.com
Oddometer: 787
Gps
[QUOTE=crypto666;18701848]So I have been using a 60cs for the past few years, and I notice that a lot of you have them mounted on the bars. I never had any luck with thay because it always shuts off (breaks battery contact) on hard bumps and vibration.
QUOTE]
If your able to hard-wire you 60 series into the bike that is best. You can get the five-pin connector with hard wire, if you have 12volts DC to power it? I assume even a small nicad batter pack is enough?
And for mounts, I love Stovey's BuzzBomb Cradle! All handmade by Stovey himself!
Check these out:
http://gpstracklog.com/2010/05/a-new...gps-mount.html
My XR650R Build:
Old 05-16-2012, 04:25 PM   #13253
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,250
The battery cavity in the 60 series GPS units is a little too large, when hardmounted the batteries can move inside there causing connection problems with the main circuit board. A short section of adhisive foam weatherstrip attached inside the back cover will prevent it from happening but if it's already doing it (cutting off) the damage might already be done.
I use the hardwire so I can run full brightness all the time.
Originally Posted by pigpen View Post
It's an XR650R, just point in one direction, open throttle and sees where it takes you! I'm a tad concerned when there are too many KLR'esch posts in the xr thread. It's a damn dirt bike! Not a gs! Sorry!!! Just saying!
Where we take the XRs, ya better have a very good idea where you're at, easily multiple days of walking (in the desert) to get to help. Forget a cell signal
Chris
Old 05-16-2012, 04:47 PM   #13254
jm-2008
jm-2008's Avatar
Oddometer: 513
Borrowed a 60c once it too shut down just after the screen broke closely followed by my collar bone
Now I carry a 60csx in the pack and refer to it when stopped
Not always convenient but it has survived a few altercations with the TERRA FIRMA
and as noted by others not possible to read it when mobile
Have had no issues with it capturing track log data whilst in the pack
Would be happier with a bigger screen otherwise a great tool to use in conjunction with maps
Our rides are usually two day affairs run ing the return leg on the second day
TRACK BACK feature has been very useful in unfamiliar territory
JM
jm-2008 screwed with this post 05-16-2012 at 05:01 PM
jm-2008 is offline   Reply With Quote
Old 05-16-2012, 06:19 PM   #13255
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
+1 on stoveys buzz bomb cradle for the 60 series gps. Protects the unit very well and almost zero chance of loosing the gps in rough terrain like I've seen so many others do. Coupled with a ram mount, it's very stable and I haven't had any problem with the cutting out described here.
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 05-16-2012, 06:33 PM   #13256
Kiko
Kiko's Avatar
Oddometer: 1,857
If anyone is looking for a very clean XR650R loaded for dual sport, I spotted this one today:
http://www.twtex.com/forums/showthread.php?t=72741
I sent the owner a msg and told him to list it on Advrider.
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 05-16-2012, 07:50 PM   #13257
Garthe
Garthe's Avatar
Oddometer: 4,356
http://advrider.com/forums/showthread.php?t=684282
Hit on this link, if you REALLY want to get crazy with GPS/road book mounting...
2007 XR650R
2001 Montessa 315R
Old 05-16-2012, 08:25 PM   #13258
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Whoah, the difference between a Texas vehicle and a New England vehicle, I have a similar dakota, well sort of, my is in my back yard, looks just like that, except between the wheels instead of shiny body panels is a small shrinking mound of rust dust haha.
"Get the hell out of my way." - John Galt
'78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
XRx is offline   Reply With Quote
Old 05-16-2012, 08:27 PM   #13259
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Johnny Five is alive!!!!
Old 05-16-2012, 09:02 PM   #13260
hontri
Global Bummer!
hontri's Avatar
Oddometer: 305
hontri is offline   Reply With Quote
Times are GMT -7.   It's 05:57 PM.
