Old 08-14-2012, 02:29 PM   #14056
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,361
Sean, tell us some info on those gas bladders...
Are they ment for gas use?
Do they leak?
How long do they last?
How much do they cost?
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 08-14-2012, 02:58 PM   #14057
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
we were going to go up north but theres to many trees ..hence a desert ride
Garth ....The bladders hold 12 ltrs ....they are made for fuel they are around 150 bucks each ...they will last a lifetime if looked after ..very tuff
has a screw on cap with a spout to pour fuel ....and ring eyelets on the seams to tie them on if need be
a mate of mine come up with the idea of getting a bag made to hold them each side of the tank
there very stable and dont move about ..they dont leak but they do leech fuel vapour so cant be packed in your bag when empty ..you can roll them up and tie them ontop of your gear Aussie made product
they can make them any shape you like and any size
work very well for long hauls ...should give me a range of about 550kms to 600 kms so 400 odd miles in range
we have a ride report we started and 1 of the boys is bringing his laptop to update as we go
here's the link
http://www.advrider.com/forums/showthread.php?t=815554
the stickers i had made up by a mate of mine ..we gunna stick em on shit when were out there
Sean-0 is offline   Reply With Quote
Old 08-14-2012, 04:39 PM   #14058
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,934
Originally Posted by Sean-0 View Post
Snakes ...and spiders ..we eat them suckers
Swags are the go mate ..yea i got tents and shit ..but there a pain in the ass to setup ..packup ..see my swag holds all my gear and my clothes ..roll it up strap it on .. im away
Hmmm, thought it was because they pack up quick in the morning to give you more time to get your bike started and be ready to leave with everyone else with tents. Have a safe trip Sean, when do you want to get that gear?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 08-14-2012, 09:21 PM   #14059
brapp-alot-puss
brapp-alot-puss's Avatar
Oddometer: 30
Oil change on the Pig...
So, I just changed the oil in the Pig for the first time. I feel like I did it right but need affirmation that the filter is in correctly. Since it shot out after loosening the last screw on the cover I could not refer to the orientation of the old one. It seems the spring installs into the recessed part of the filter? Also it seemed to take less than the 1,75ish liters. I ran it at idle, then checked it, then gently rode around the block and checked it. Both times it seemed fine. Any advice?
Life is not about the destination, it is about the journey.
brapp-alot-puss is offline   Reply With Quote
Old 08-14-2012, 09:37 PM   #14060
XRx
Broken Filter
XRx's Avatar
Oddometer: 505
Come clean Sean-0, you know those are front impact air bags.
Seriously though have a great trip. Sounds like a good time. The swag setup sounds pretty good.
"Get the hell out of my way." - John Galt
'78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
XRx is offline   Reply With Quote
Old 08-14-2012, 09:50 PM   #14061
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
your on the money mate
Airbags .... didnt think of that ...Yea gunna be a great ride ...i have total faith in my rig ....she'll get me home
Old 08-14-2012, 09:59 PM   #14062
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
Had a few ppl ask about the bladders and bag
heres a shot of them
the hole in the middle of the bags is to put over your fuel neck
the bags have eyelets to allow for the bags to be tied down but can still remove the bladders
the bladders are 12ltrs but hold about 11ltrs each side
they leech fuel vapor so cant be stored in your bags or tent ....hence the bag option when empty the bag just stays there ...is far enough forward to not impeed your knees
http://www.liquidcontainment.com/fuel_bladders.php
i think the bladders came from these guys
Old 08-15-2012, 07:18 AM   #14063
johnyrrr
Oddometer: 197
Need some Supermoto wheels
LEt me know if any of you BRPerz want to get rid of your XR650R setup. Also where can I find the backing plate for a Twin Air Filter. My bike came with a K&N and a Twin Air but just the filter foam for the Twin Air and I dont really want to run the K&N if I dont have to.
Shes got a stage 2 cam
Big Gun ()
and holy cow does she BRAP!
johnyrrr is online now   Reply With Quote
Old 08-15-2012, 11:10 AM   #14064
Shibby!
Oddometer: 1,656
Sounds right as long as you put "this side out" towards the outside...
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 08-15-2012, 12:10 PM   #14065
crypto666
Oddometer: 1,231
Wink rear shock
So what is your guys opinion on the rear shock. I am trying to do a mental cost benefit analysis of redoing the shock.
Everything on my bike has been rebuild/built up, except the rear shock (has 10kg spring). Last night I changed the bearings, flushed it, refilled and recharged. It had a considerable amount nitrogen in the oil which had to be effecting the rebound, I assume it seeped in osmotically through the bladder over the past ten years.
I was ready to send it to racetech for a rebuild and gold valve and maybe a rebound seperator valve, but was going back over the Bornyack stuff and he says the stock valve is pretty good. So now I am thinking to just rebuild it myself this winter, and just put new seals and redo the shim stacks.
What would you do? Send it to racetech for $250-350 and get everything done? Do it yourself and just replace the consumables? Redo shims also? Or just oil and nitro and ride the hell out of it?
I don't race so not interested in the cr500 hybrid.
I don't have any real complaints right now, but I am sure it could be better.
crypto666 is offline   Reply With Quote
Old 08-15-2012, 02:41 PM   #14066
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 454
The oil filter goes in with the rubber ring facing out from the engine , it takes 1.6 litres to change the oil and oil filter .
ZXRaziel is offline   Reply With Quote
Old 08-15-2012, 02:45 PM   #14067
ZXRaziel
ZXRaziel's Avatar
Oddometer: 454
Big Gun ()
Trow the k&n filter in the bin , no matter what some say they are very bad filters , bad filtration capabilities .
Old 08-15-2012, 07:23 PM   #14068
Shibby!
Oddometer: 1,656
How did you know nitrogen was in your oil?!
Just use Borynacks site and use his valving. I'm 93.5% happy with it =) Don't think it gets any better once luggage is on either.
1.8 liters with filter, 1.6 without.
Old 08-16-2012, 06:28 AM   #14069
mr. coffee
wingnut
Oddometer: 20
hey there guys. long time listener first time caller. wanted to first of all thank everybody out there for all of the help, support, and information you have made available to all xr owners in the adv. rider community. what a great group of people. i have learned so much from this thread.
purchased a 2000 xr650r from a fellow inmate back in feb. the bike has very low hours and seems to be well set up. uncorked, rejetted, nice seat, tank, etc. after owning many different bikes in the past, i am having an absolute blast with this one. until the other day.
with my truck in the shop with major timing sprocket issues. i have been happily commuting on the pig. then all of a sudden it will not start. usually 1/2 choke and a couple of kicks and it is good. i have kicked the thing a hundred times in the past two days and nothing. i feel like it is not getting a spark, but why. went to pull the plug last night, but didn't bring the right size plug socket. ( bike is at my girlfriend's house and thankfully she is letting me ride her sportster )
here is where you guys come in. i feel like it is something very simple that i am overlooking. the carb is stock and it is definitely getting fuel. ( i can smell it ) the kill switch is not stuck and the decomp lever is operating freely. it has plenty of fuel in the tank and yes i have opened the petcock valve. i will get the plug out tomorrow and see what is going on, but in any case i have been looking for an excuse to post something here, so now i have it. thanks in advance for all of your help
one other question is ... do y'all have any recommendations on spark plug types?
best of luck to everyone, and you fellows down under keep up the entertaining posts. cheers
mr. coffee is offline   Reply With Quote
Old 08-16-2012, 08:40 AM   #14070
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,270
For me, hard starting is usually a sign of either a clogged idle jet in the carb (not likely in your scenario) or valves out of adjustment. You'd be amazed at having the results of the right valve lash....
To check for spark, you don't need to remove your spark plug. Just pull the cap and put it on a spare (doesn't even really need to be the 'right' one, either). It's a bit more figgidy trying to get it grounded and kicked over by yourself, though.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Times are GMT -7.   It's 08:19 AM.
