Old 08-17-2012, 07:00 PM   #14101
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 704
Originally Posted by cragdweller View Post
Have any of you big guys (I'm 6'4", 240) resprung the stock XRR forks/shock without revalving? I'm about to do this just to see how the stock valving works for my type of riding. Just curious how this has worked for others...
I did this and I am 6.1" 250bls better than what it was but I am sure it would be better with the valve work.
BigNastybrp is offline   Reply With Quote
Old 08-17-2012, 07:04 PM   #14102
BigNastybrp
Big Nasty
Oddometer: 704
Originally Posted by Dread Pendragon View Post
I've got a Guts tall/soft seat kit that I keep thinking I need sell.
It's used in that I put it on my seat pan, but I didn't ride with it much after I tried my brother's SDG tall seat and decided to get one of those.
I can't remember what they cost new, but if anyone is interested we can figure out what a new one costs and I'll give you a great deal on it.
I think it was $60 foam and $60 for cover. some one should pick that up, I use the guts more than the others
Old 08-17-2012, 09:21 PM   #14103
Hoologan
Hoologan's Avatar
Oddometer: 254
Originally Posted by jwalters View Post
Hi ya'll,
I'm a bit overwhelmed trying to find a good aftermarket seat that fits the Acerbis tank. I've search and searched and there is almost too much information out there. Unfortunately, I haven't found what I am looking for. Some aftermarket seat makers (like corbin) have different model seats for different tanks, but none specifcally mention the Acerbis 6 gallon.
So here it is, I need a much taller aftermarket seat for my XR650R but it has to fit on an Acerbis 6 gallon tank. Let me know if you have this setup and what seat worked for you. Thanks!
I have the guts tall foam and cover and it works well with the acerbis tank.
Western TAT 2012
Prudhoe Bay 2014
Hoologan is offline   Reply With Quote
Old 08-17-2012, 09:58 PM   #14104
fire1998
Oddometer: 58
How the hell do you blow up an XR650!! Raced Vegas to Reno today. Made it 210 miles till motor locked up solid. Bike was running great until then. Bike developed a valve tick and it locked up a few miles later. Downshifted into a corner and it locked!! All I can think of is maybe oil pump failed. No leaks on bike oil or coolant. When bike locked I took air filter off and it was full of coolant and it was steaming out of airbox. Bike was double/ triple checked!! Ladt thing we thought we had to worry about was motor!!
fire1998 is offline   Reply With Quote
Old 08-18-2012, 02:06 AM   #14105
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Shibby, great post, appreciated. Your "I love my XXR" says it all
Gmanski,
pinging or detonation one does not get at partial loads, you mention "when running in mid revs". You'll get detonation when opening up, when loading the bike - so it won't be pinging. And no, your idling circuit/screw won't affect the mix here.
However, you said you did the valves 300km's ago - so check here, or rather re-check? Make ab-so-lu-te-ly sure that the engine does not reverse back, not an iota, as that will throw off the exhaust-valve's play (the auto-decomp system!) which you then will have set to 'too wide' - which you will hear. And do take the plug out when you get busy, makes life simpler.
If it is not this then others have given pointers which you better check if there's really something wrong, and do keep in mind that some have reported that this bike can be a bit noisy. You were the guy who's going to ride to Down Under aren't you? Better open it up at home & make sure than along route in some lost place where matches are had to come by.
Fire,
your head is ported? If so then they took off too much, head's cracked it sounds like. Don't tell me you run that never-boil-off coolant, forget the name, you better do too. If your (inner) jug is cracked then you've got quite costly problems, and do dig deeper than the base gasket as you seized it, cranks don't like this. Valve tick? When you take off the rocker cover and see shot followers you'll know if your oil pump resigned.
Sorry bru, time for some expenditure and extended TLC.
BuRPsa is offline   Reply With Quote
Old 08-18-2012, 09:09 AM   #14106
crypto666
Oddometer: 1,383
How much time on the engine? One thing I have always been worried about is blowing out the oil jet for cyclinder/c-rod.
Hopefully, since it sounds like you weren't under power when it locked, the damage is minimal.
That sucks. There is usually someone there associated with xrsonly, talk to them. I have a few spares over in Caliente, but you probably aren't in a hurry now.
Casey will be happy to sell you a new Beta.
crypto666 is offline   Reply With Quote
Old 08-18-2012, 09:29 AM   #14107
achile
achile's Avatar
Oddometer: 289
Hey guys
! I've started an interesting mod on my piggy. I'm talking about the shock bearings. The stock job is with needle bearings and bushings. Needle bearings and bearings, in general aren't really made for static loads and needles and balls tend to stamp themselfs into the raceways. I've ordered two uniball joints and started the mod. The top one is an easy fix. Just put the new joint in the housing and machine the inner bushing(the long one, part ) to 7.3 mm. The top part is now connected. Now the tricky part... I have to make two bushings to connect the lower part of the shock to the links.
Tech data:
-these are the unibals
http://www.skf.com/skf/productcatalo...odid=183201010
http://www.skf.com/skf/productcatalo...odid=183201012
And these are the bushings, and the materials we have to use.
Why did I do this?
It's cheaper 12 $ per joint
It's better the static and dinamic loads are much bigger. You can check out the specs and make a comparison :). This is a needle bearing of similar size:
http://www.skf.com/skf/productcatalo...odid=146101047
P.S: you can use the stock seals :)
achile screwed with this post 08-18-2012 at 09:34 AM Reason: ...I'm a senile old man
achile is offline   Reply With Quote
Old 08-18-2012, 09:46 AM   #14108
frickenmotarded
frickenmotarded's Avatar
Oddometer: 447
XRR Noise Question for the Guru's
Guy's my BRP is fairly new to me so I need someone's ear that knows these things. I've had a ton of bikes and both my ATC250sx's have kinda sounded like this, but I want to check and makes sure I'm not about to loose a rod bearing. Some have referred the the XRR as have a marble in a can sound much like a diesel. I have the stock plastic skid on, fresh oil its fully up to temp. starting around 3500 rpm at light load it makes the sound and then becomes indistinguishable about 4200ish.
and also
you'll hear me say "right there" that's the noise in question but its audible longer on the first video. I'm going to recheck the valves but i'm fairly certain they are within spec and this doesn't sound like valve noise to me anyway. Please weigh and and let me know what you think. I have a tendency to over analyze things but I would rather fix it now before it does major damage later if so. Thanks in advance!
frickenmotarded is offline   Reply With Quote
Old 08-18-2012, 12:30 PM   #14109
cdogg44
Oddometer: 220
Originally Posted by Garthe View Post
"Question for those with the Acerbis tanks. Did anybody have issues with the supplied petcocks? Or did you switch out for a higher quality ones?"
http://www.clarkemfg.com/cart/index....ex&cPath=16_35
Get the 'with GROOVED' ones and one of each.
To bring up a post from last September...Has anyone had any luck with the Clarke petcocks on their Acerbis tank? I ordered a new Acerbis tank awhile back along with two Clarke 90 degree WITH GROOVE petcocks and they are leaking on me.
I have no experience with an Acerbis tank, but the petcock mounting surface is slightly dished out, so much so that I can see the o-ring (both the Clarke and Acerbis petcocks). Is that normal?
Any info?
cdogg44 is offline   Reply With Quote
Old 08-18-2012, 03:30 PM   #14110
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 571
and also
hard to say from the sound quality , but check the valve clearances again and the water pump also .
ZXRaziel is offline   Reply With Quote
Old 08-18-2012, 09:44 PM   #14111
chrish4ku
chrish4ku's Avatar
Oddometer: 861
Originally Posted by BigNastybrp View Post
Seat Concepts= I have not tried one but I hear good things
I have this five seats. corbin will not work with the 6.3
Renazco= best
Corbin= ok but will not do it again
gut tall soft= best deal and I use it more than the others
stock= sucks
sdg stock= sucks
Guts is the best. Over 800 miles and counting.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 08-18-2012, 09:45 PM   #14112
woodsxr
Oddometer: 220
and also
From your video's it sounds like mine.
When I picked up mu XRR, I was wondering about the noise and checked out a buddies XRR and it was making the same sound.
They are noisy engines.
I think the PO sold the bike because of the same noise. He sold the bike with a spare crank and carillo rod. He had the intentions of rebuilding the engine with a big bore kit with the new rod.
I may do that some day when I get bored with the power!!
woodsxr is offline   Reply With Quote
Old 08-18-2012, 09:59 PM   #14113
crypto666
Oddometer: 1,383
Originally Posted by Shibby! View Post
How did you know nitrogen was in your oil?!
Just use Borynacks site and use his valving. I'm 93.5% happy with it =) Don't think it gets any better once luggage is on either.
1.8 liters with filter, 1.6 wi.
You were right, it wasn't n2 in the oil, it was just foaming from being depressurized. My bladder was fine, but not now.
I also meant to say compression does nothing, but either way this rebuild is needed, the rebound stack is a little rediculous stock. I also notice that my rebound adjuster has the most nonlinear adjustment to it. I don't think I can fix that.
Doing the rebuild myself, I didn't realize the gold valve kit came with shims. Those freakin shims are expensive and they only come in five packs. Racetech prices are crazy for the bladder and bumper unless they are better than oem; 2x.
Old 08-18-2012, 10:08 PM   #14114
offrdr1975
offrdr1975's Avatar
Oddometer: 113
Seat Concepts Rock
Renazco= best
stock= sucks
sdg stock= sucks
I am a big boy 6'3" 300 and I just did 6 days and 900 miles on and off road through the wilds of Colorado on the XRR and I was comfortable through out the ride. This is the second Seat Concepts seat I have bought and they are the best bang for the buck you can get in seats. I will soon be ordering one for my 990 adventure as well.
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 is offline   Reply With Quote
Old 08-18-2012, 11:05 PM   #14115
fire1998
Oddometer: 58
Bike had roughly 1200 miles on it. 900 from baja 1000 in 07. Bike has pretty much sat in garage since then. Rode a couple times a year. Took oil filter cover off this morning in parking lot and there was no metal in there. Hopefully bottom end is still good. We have decided to retire XR and buy a new CRF450X for our desert race bike.
Times are GMT -7.   It's 06:27 PM.
