Old 09-26-2012, 12:17 AM   #14656
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,410
Originally Posted by bamfslap View Post
I am interested if the price is good! (but don't make one for me yet...I'd like to know the price first of course )
Plus 1 ....keen if there priced in the range
Sean-0 is offline   Reply With Quote
Old 09-26-2012, 02:26 AM   #14657
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Originally Posted by medisyn View Post
Anybody got a suggestion what to use to cut a slot into it so I can get it out?
A Dremel is your friend here, I'd use the thin cutting disc for it.
BuRPsa is offline   Reply With Quote
Old 09-26-2012, 06:59 AM   #14658
babuja
babuja's Avatar
Oddometer: 353
Originally Posted by babuja View Post
t's time to change tires and wondering about this set (stock rims):
Front: Michelin Desert 90/90-21
Rear: Michelin CROSS COMP. S12 XC 140/80-18
or
Front: Dunlop GEOMAX ENDURO F.I.M. 140/80-18 70
Rear: Dunlop GEOMAX ENDURO F.I.M. 90/90-21
Cheers
Cesar
I've decided for new "shoes":
- 140/80 18" Pirelli MT21
- 90/90 21" Pirelli MT21
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 09-26-2012, 07:26 AM   #14659
smoothride
smoothride's Avatar
Oddometer: 231
Wanted to put in the new jet and needle and this happened. http://i.imgur.com/ZhdMW.jpg
Man they were not kidding about them being soft. It was like literally the last screw to break loose. I bathed it in aerokroil and took my time with the right sized screwdriver. I wonder if the hardware store has bolts with the right thread pitch so I can just replace these shitty screws.
Try needle nose vise grips. the small ones.
00 XR650R plated
08 DR650
smoothride is online now   Reply With Quote
Old 09-26-2012, 07:30 AM   #14660
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 471
Originally Posted by RalphyDo View Post
Does anyone happen to know what the year model or part number is for the Xr400r CDI swap is?
It's 0700000-2650, I believe 2619 is the stock #. I found one on Ebay, make sure and verify the number visually!
Oddfellow
'06 Suzuki DR200SE
'05 Honda XR650R
'14 KTM 690 Enduro R
Oddfellow is online now   Reply With Quote
Old 09-26-2012, 08:41 AM   #14661
crypto666
Oddometer: 1,276
Originally Posted by Sutherngintelmen View Post
Posted q in 600 thread but does occur to me 650s got know too. If you have ideas I'm happy to hear em.
If it was a 650 I would say change the plug, But its not, so I won't...
crypto666 is offline   Reply With Quote
Old 09-26-2012, 09:41 AM   #14662
Shibby!
Oddometer: 1,657
Didn't like the MT21 rear. Never used the front.
After running another Pirreli after the MT21, I will no longer run any more P tires.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 09-26-2012, 11:52 AM   #14663
RalphyDo
Oddometer: 308
Yep, first try the Dremel with the cutting disc to make a slot for a flat screw driver. If that doesnt work, then only other way is to grind the head off and try a left hand drill bit and/or an EZ out.
RalphyDo is offline   Reply With Quote
Old 09-26-2012, 12:23 PM   #14664
babuja
babuja's Avatar
Oddometer: 353
I've been using them on Adv 950 with good results...first time on XR.
Not waityng for great performance offroad, but aceptable traction for about 5000km duration and confortable for everyday 5 min. ride with kid to school.
Tnks Shibby for your feedback.
Cheers guys
Babuja
________
KTM 950 ADV
babuja screwed with this post 09-26-2012 at 01:19 PM
Old 09-26-2012, 01:41 PM   #14665
Shibby!
Oddometer: 1,657
Their ok for guys that have to run DOT tires. Otherwise I just run full knobbies. Way better, and some last just as long. Maxxis Desert IT is a far superior tire if you can get away with it. Not great on marbles on gravel roads but what is.
Old 09-26-2012, 01:51 PM   #14666
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,390
Thanks guys. The machinist we've been using is really jammed-up right now, so we're looking for other manufacturing options. Will keep you posted, and please post-up in my thread about those tripleclamps if you're interested. Easiest way to keep track of everyone.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 09-26-2012, 02:23 PM   #14667
babuja
babuja's Avatar
Oddometer: 353
I've been earing a lot about those maxxis but donīt know were to find them in Europe...usually I buy tires in Portugal or Spain and send them to Angola...any store in Europe?
A pair os MT21 in Luanda is about 500$...insane!!
Cheers guys
Babuja
________
KTM 950 ADV
Old 09-26-2012, 02:32 PM   #14668
Kiko
Kiko's Avatar
Oddometer: 1,810
Have you tried Mitas?
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 09-26-2012, 02:55 PM   #14669
jcmcc
jcmcc's Avatar
Oddometer: 155
Originally Posted by jcmcc View Post
Hey guys I'm new to XR650Rs. Just picked up a sumo'd out 00 last week and working on getting it running just right...........
Just looking for any leads you guys have for me ...........
Just an update on this. When trying to start, gas dribbles from the vent tubes from the carb and it is still extremely difficult to start. I'm pretty sure its not just me as I'm kicking the ever loving crap out of the thing . Using just past TDC approach, fwiw.
Still idles weird- now it will drop to 1000/1100 and will usually die out without me twisting the throttle a little. Sometimes the idle will settle out (about 1600 rpm) after the twist, sometimes not.
setup again:
fmf/white bros can
swiss cheese side panel/airbox
68s/180/3rd clip screw 1.5 turns out
valves just checked. float level 16.5 mm. plug looks tan/brown
I'm wondering if the gas when starting will maybe clue you gurus in to something cause I'm about ready to buy a tm40 and say **** IT!!!
jcmcc is offline   Reply With Quote
Old 09-26-2012, 02:55 PM   #14670
babuja
babuja's Avatar
Oddometer: 353
No, not yet...and they aren't available in Luanda...that's why the insane price for tires.
Never used any pair because I have the ideia (maybe wrong) they are ok but donīt last.
Cheers guys
Babuja
________
KTM 950 ADV
Times are GMT -7.   It's 08:28 PM.
