09-26-2012, 01:51 PM
#14671 | |
fishing with dynamite
Oddometer: 2,067
09-26-2012, 02:23 PM
#14672 | |
Oddometer: 248
A pair os MT21 in Luanda is about 500$...insane!!
Cheers guys Babuja ________ KTM 950 ADV www.babuja.smugmug.com http://www.nomadstrail.net/site/ |
09-26-2012, 02:32 PM
#14673 |
Oddometer: 966
Have you tried Mitas?
09-26-2012, 02:55 PM
#14674 | |
Oddometer: 96
. Using just past TDC approach, fwiw.Still idles weird- now it will drop to 1000/1100 and will usually die out without me twisting the throttle a little. Sometimes the idle will settle out (about 1600 rpm) after the twist, sometimes not. setup again: fmf/white bros can swiss cheese side panel/airbox 68s/180/3rd clip screw 1.5 turns out valves just checked. float level 16.5 mm. plug looks tan/brown I'm wondering if the gas when starting will maybe clue you gurus in to something cause I'm about ready to buy a tm40 and say **** IT!!!
#14675 |
Oddometer: 248
No, not yet...and they aren't available in Luanda...that's why the insane price for tires.
Never used any pair because I have the ideia (maybe wrong) they are ok but donīt last.
09-26-2012, 03:07 PM
#14676 |
Oddometer: 376
Anyone have a upper fork tube thats straight that they'd want to sell?
Would buy the whole assembly if needed. |
09-26-2012, 04:08 PM
#14677 | |
Torque Junkie
Oddometer: 3,634
![]() Here's some more XRR riding from last weekend. |
09-26-2012, 04:17 PM
#14678 | |
Oddometer: 376
09-26-2012, 04:19 PM
#14679 |
Oddometer: 308
09-26-2012, 04:21 PM
#14680 |
now in Mt. View, AR
Oddometer: 597
Coolant
Replaced my thermostat and lost about 2-3 cups of coolant in the process.
I am without my service manual and wanted to double check.... Just add the couple cups I lost taking out the thermo back into the top of the radiator, not the res at the bottom of the engine. Cheers
insert meaningless phrase here.... |
09-26-2012, 04:26 PM
#14681 | |
Oddometer: 308
Add it to the radiator, but make sure the coolant overflow bottle is filled between the "upper" and "lower" marks |
09-26-2012, 04:30 PM
#14682 |
now in Mt. View, AR
Oddometer: 597
Cheers and thanks for the heads up on that.
09-26-2012, 05:46 PM
#14683 | |
Oddometer: 376
This reminds me I need to install a thermostat in mine, its currently empty. |
09-26-2012, 07:31 PM
#14684 | |
Oddometer: 308
I fill it up to the top of the rad and let it "settle. Fill it up again, again.....however many times it takes for it to stop taking coolant. Once that is done, start it up for a few minutes to circulate, shut it off and then squeeze the lower rad hose coming from the water pump a few times. "Burp" it, like a baby. Never had any issues doing it this way. That is the way I'd burp my racecare motors too. Always worked for me. |
09-26-2012, 08:21 PM
#14685 | |
around the bend
Oddometer: 991
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding. All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV |
