Old 10-03-2012, 05:28 AM   #14761
juri.tabain
juri.tabain's Avatar
Oddometer: 31
My crank is still mocked up... The Germans seem to wreck their rods pretty often and push me towards buying a carillo. What would you guys go for? Just a complete OEM crankshaft+rod or the former plus a carillo (moneymoneymoney... ).
XR650R_K200642_KuWe_3 von jnk@tabain.eu auf Flickr
juri.tabain screwed with this post 10-03-2012 at 09:16 AM Reason: typo
juri.tabain is offline   Reply With Quote
Old 10-03-2012, 09:25 AM   #14762
crypto666
Oddometer: 628
When I researched it a little over a year ago, I concluded the Falicon rod was for me, despite the $$$$.
crypto666 is offline   Reply With Quote
Old 10-03-2012, 09:47 AM   #14763
medisyn
Oddometer: 102
Originally Posted by mattymurn View Post
Ok this is similar to my experience I had with my XRR this spring. I rode it one day and it was fine, the next day it would not start only backfire (reallly loud every once in a while). I must have kicked that thing 1000 times. Long story short you need 4 things to run the engine, fuel, air, spark, and compression. I had all but one (compression). Turns out my intake valves were worn down to knife edges, I still had lash but I guess there was not enough compression to start the engine. I did use a compression tester but the tests were a bit inconclusive. A leak down would tell you for sure. I took the top end apart and had the valve seats reground and had kibblewhite valves put in. When I put it back together the bike started first kick.
I hope this is not your issue , but taking the top end apart was not a big deal, a bit costly depending on what you do, ( I put new rings in at the same time and had the cylinder diamond honed)
Matthew
Last night I triple checked the valves insuring I was checking the clearances on TDC-C. Stuck my finger in the spark plug hole to feel the compression. Watched the intake valves come back up, there was a little wiggle room with the rockers etc. They all seem to be within spec. I tried also raising the float level a bit. I am just using a ruler and eyeballing so its not the best method. I raised it a few MM, looks to be around 15mm. I know this is not spec, I just wanted to change a little at a time. I also triple checked the pilot/main jets. Brand new and no clogs or anything. Threw it back together and it seems to backfire slightly more but still wont start or sputter.
I mean the engine was running fine before hand, but I guess I can buy a compression gauge. Right now I am grasping at straws. It has to be carb related, but I am still in the dark. I wish I didn't touch the valves. Now I will always have to wonder. For now on I am only changing one thing at a time on a kick start motorcycle. Its way too annoying kicking hundred of times, haha.
medisyn is offline   Reply With Quote
Old 10-03-2012, 09:56 AM   #14764
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 13,032
medisyn,
How are you finding TDC?
Plug out, 5th gear, rotate tire backwards to keep it out of the auto decomp until TDC.
Old 10-03-2012, 09:57 AM   #14765
Cpt. Ron
aka Birdkilla
Cpt. Ron's Avatar
Oddometer: 2,406
As others have stated, it could be a deeper issue. I've certainly observed that tight valves can cause hard starting. Or worse, worn valves. The last time I couldn't clear up the issue with a proper valve adjustment, I found I needed a top end job.
Have you tried push starting it? Usually, once it's running, it should run OK (even with a needed valve job).
Cpt. Ron
Sack-O-Tomato, CA
'05.5 950 Adventure S "Bad Mutha F@&ker"
'04 R1150RTP "cop motor, cop suspension.."
'00 XR650R Dual Sport "Lil' Mule"
'75 RL250
'01 TTR90
'01 PW50
Conti TKC80 tire swing
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 10-03-2012, 01:54 PM   #14766
medisyn
Oddometer: 102
Originally Posted by larryboy View Post
medisyn,
I pull the stator cover and spark plug off, then turn the crank anti/counter clockwise watching the intake valves to insure they have gone up. confirming compression by putting my finger in the plug hole and aligning the notch with the T mark. I then check if I can move the rockers slightly. This is what the service manual calls for. I dont have a stand yet, thats why I did not use the other method.
Old 10-03-2012, 01:58 PM   #14767
medisyn
Oddometer: 102
When I checked the valves they were all a bit tight. I loosened them up to .006in (insuring a .007 almost fits and a .008 cannot) intake and .008in (a .009in is a tight fit and .010in does not.) on the exhaust.
I will try a push start, need to get a buddy to come over. I don't have a truck so I cant roll it down a hill.
Old 10-03-2012, 03:23 PM   #14768
medisyn
Oddometer: 102
I will note that I do hear a click once I am getting close to TDC-C. Is this the auto decompress kicking in and messing up my measurements? How "loose" should the rockers feel? Mine only move slightly.
Old 10-03-2012, 04:12 PM   #14769
RalphyDo
Oddometer: 308
There was a Carillo in the flea market here for $200. I dont know if it is still there.
RalphyDo is offline   Reply With Quote
Old 10-03-2012, 05:10 PM   #14770
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 1,714
Send a message via AIM to jwalters
Hi Guys,
Quick question. I'm putting on new chain and sprockets on my XRR. I noticed the front counter shaft sprocket has some play after the #8 bolts are snugged down on the CS retaining plate. Is this normal? It's not excessive slop, but I'd guess it's almost 1mm of play. Never seen it on my other bikes...
-jw
See you at the Minnesota North Shore Shindig 2013 11-14 July (Finland, MN)
jwalters is online now   Reply With Quote
Old 10-03-2012, 05:38 PM   #14771
RalphyDo
Oddometer: 308
Originally Posted by jwalters View Post
Hi Guys,
-jw
Yeah, that is normal. 1mm sounds like a bit much. Did you check the splines on the counter shaft to see if there was excessive wear?
Old 10-03-2012, 06:27 PM   #14772
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 1,714
Ya, the splines look good. I don't think it's a full millimeter, I meant to say it was no more than a millimeter. I can feel it moving around on me when I move it side to side. thanks for the input.
Old 10-03-2012, 06:38 PM   #14773
RalphyDo
Oddometer: 308
Yep, it'll be fine. The sprocket is made to float.
Old 10-03-2012, 06:48 PM   #14774
bamfslap
Oddometer: 178
Yup.
That feeling when you jump back on your 650R after riding your 600R for two weeks. Feels like a raped ape bastard demon from hell (yes, that's the best I can describe it). And feels light as hell, even though it's heavier. Love this damn bike.
bamfslap is offline   Reply With Quote
Old 10-03-2012, 07:01 PM   #14775
Shibby!
Oddometer: 1,421
The retainer can wear, and some sprockets are tighter than others. Don't run Primary Drive. I normally use them, but find them too sloppy on the XRR. I've stopped using them in favour of other cheap brands like JT, etc.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Times are GMT -7.   It's 10:19 PM.
