09-03-2009, 11:22 AM
#1471 |
Follow Me
Oddometer: 1,736
I did that exact procedure this morning. It started right up. I almost went with a 450x just because of the e-start. I'm so glad I didn't.
09-03-2009, 03:12 PM
#1472 | |
Oddometer: 1,678
I first found the fuse, replaced it, then discovered the still non-functional tail light. After removing the lens, I found the socket popped out of it's much too weak clip type holder and remains of the bulb. It also had a wire sheared off the socket, most likely due to the insufficient clearance for the back of the socket inside the lens, which is pushed hard against the wire connections. Nice!?! I also find they use an odd ball Euro bulb instead of something you can get at any auto parts place?!? Luckily, I was able to get a good old 1157 tail light bulb to work with a little re-engineering. I also was able to re-connect the wire to the socket using a large butt connector. And finally I used my favorite adhesive, GOOP, to make sure the socket wouldn't pop out of it's clip the next time I hit a bump on the trail. We'll see how long it lasts.
"If you ain't slidin', you ain't ridin'" SVN/XRR/Christini |
09-04-2009, 06:37 AM
#1473 |
Big Red Pig-FoxHondaRider
Chain Slider
Does Anyone know where I can pick up a chain slider for under $30 or does anyone on here have one they would like to give up. I need it for my XR650R. Part Number is: SLIDER, CHAIN (52170-MBN-670)- Thanks
2001 Honda XR650R Dual-Sport BRP(Big Red Pig) |
09-04-2009, 06:37 PM
#1474 | |
Chickenfat dirtbiker
Oddometer: 1,126
I originally had the BD standard bulb taillight setup, and when I tried to order a bulb from BD,the tech said he wouldnt sell me 1. When asked why not, he said "its just gonna burn up again anyway,they(filament bulbs) cant take the vibration" Uhhh, thanks,i thinkI ordered the LED replacement and it been workin perfect for 3 years. Tony |
09-04-2009, 06:58 PM
#1475 | |
RMAR
Oddometer: 3,062
http://www.hondapartsnation.com
Member of AMA, COHVCO, and RMAR On the Board of Directors for RMAR: Director of Promotions Our site: Rocky Mountain Adventure Riders |
09-06-2009, 12:54 PM
#1476 |
Rear Brake
Today as I was leaving church, I noticed I had no pressure to my rear brake pedal as it went all the way down. So I ended up using engine braking and front brakes to get home. When I got home I looked through my Service book and at online pics of the rear brake tubes. Then went out to my bike and noticed that brake fluid would come out of the top of the screw where this little red piece with two wires come out of it when I press the pedal. Now I notice that in the Diagram photos in my book and online, there is not any opening on top of the screw or any wires coming out of it, so does anyone else have something just sitting at the top of the screw (17)?
Not my bike but it also has the little red piece above the screw
09-06-2009, 01:10 PM
#1477 |
Oddometer: 1,678
The bolt with the wires coming out is part of the Baja Designs dual sport conversion kit. It replaces the stock banjo bolt and has a pressure sensor in it which actuates the brake light. You will have to get a replacement from Baja Designs. It is one of the ones on this page:
https://www.bajadesigns.com/NET/C-SWITCH/SWITCHES
09-06-2009, 01:13 PM
#1478 | |
Oddometer: 1,446
The piece you have is part of the dual-sport kit- it replaces #17 with a pressure switch to operate the brake light. It appears that yours has failed and is causing the leak. Baja Designs has 'em- https://www.bajadesigns.com/NET/C-SWITCH/SWITCHES |
09-06-2009, 03:50 PM
#1479 | |
Oddometer: 2,424
You in southern ohio? we should ride. |
09-06-2009, 05:59 PM
#1480 | |
NOOBish
Oddometer: 611
+1 Service Honda has great prices and a handy web parts fiche ordering system. Just don't use them if you need anything fast.
09-06-2009, 06:10 PM
#1481 | |
Westside Trash
Oddometer: 723
09-06-2009, 07:52 PM
#1482 |
£Bob£
Oddometer: 4,476
Rear wheel bearings
Why does my XR eat rear wheel bearings? I doubt I get 1,000 miles out of a set. Cheap Chinese junk, or is something wrong with my hub?
Grammar: It's the difference between knowing your shit, and knowing you're shit. |
09-06-2009, 07:59 PM
#1483 | |
Torque Junkie
Oddometer: 3,539
09-06-2009, 08:02 PM
#1484 | |
£Bob£
Oddometer: 4,476
09-07-2009, 04:10 AM
#1485 |
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
are you putting factory honda parts in or using some aftermarket junk like me and blew right threw one set
and Im the one always preaching about using factory parts
2002 XR650R (plated), 2000 XR650R (trophy), 2013 CRF250L, 1990 Transalp, 2002 CR125R (woods weapon), 1977 CT90, 2009 Big Red, 2008 CRF230L (wifeys), 2003 XR650R (boys), 1972 XL250 (boys), 1997 CR80R (boys) |
