10-18-2012, 12:06 PM
#14956 | |
Oddometer: 148
00 XR650R plated |
10-18-2012, 12:13 PM
#14957 | |
Oddometer: 172
I put it on the bike and it's even worse now since the tank pushed the top back. Wow. I am going through the bike and replacing old/worn stuff and it looks like shit compared to the rest. I guess I'll try doing it over (for the 12th time, not even shitting you). |
10-18-2012, 12:49 PM
#14958 |
Oddometer: 314
Thermostats
Interested on thoughts re need for the thermostat.
Noted previously here my BRP hasn't had one for some time and I don't appear to have any issues? Allways thought they were needed to speed warm up in extremely cold climates. Comments
10-18-2012, 01:42 PM
#14959 |
Oddometer: 341
I wish i knew the secrets of XR cooling. Mines always has run hot. Mine does not have a thermostat, but i plan on putting one in.
10-18-2012, 03:28 PM
#14960 |
Oddometer: 148
If it is jetted on the lean side it will run hotter.
00 XR650R plated |
10-18-2012, 03:47 PM
#14961 |
Oddometer: 102
10-18-2012, 07:35 PM
#14962 | |
Oddometer: 172
Never had mine boil and I do all sorts of riding, like slow trail riding in 100 degree weather, crazy hill climbs, etc. |
10-18-2012, 07:46 PM
#14963 | ||
Oddometer: 308
My toyota-head-bolt foot peg bolt replacements have been holding up for over 10 years of hard desert riding and wrecking Bottomed the suspension too many times to recallQuote:
Hmmm, you're a super hero! No one has ever been able to keep the XRR cool! You are right tho, most people run on the lean side but cannot figure out why it runs hot.
10-18-2012, 07:54 PM
#14964 | |
Oddometer: 172
I meant boiler over. I can hear the "sucking on a straw" sometimes, which means it's boils right just not boiling over? Or is that just the coolant doing its thing. I also live at high altitude which should make me boil at lower temps, too right? My friend just got a 650R and we did some slow trail riding (he's new) and his was good too, but his is really on the rich side at our altitude. Speaking of which anyone want to buy a Acerbis 6 gal Sahara tank from him?
10-18-2012, 08:02 PM
#14965 | |
Oddometer: 308
It does depend alot on how hard you are running it at any given speed. I have boiled mine a few times in deep, soft sand which was pretty slow going. And in the snow!! Running it too hard with not enough air flow will boil over every time. The hissing you hear is the coolant boiling into the overflow or the coolant being sucked back into the radiator after boiling over slightly. The XRR's cooling system is just not designed to cool that bike without it moving thru the air at a pretty good clip. Adding bigger rads and a fan does help alot. Jetting has a huge effect on running hot/cool.Pm sent on the tank |
10-19-2012, 03:49 AM
#14966 |
XR 650R Rider
Oddometer: 45
New dashboard for the Garmin Montana GPS
10-19-2012, 07:21 AM
#14967 |
Oddometer: 1,382
Dear lord..
Why do you need a T.V screen in front of you?
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
10-19-2012, 07:31 AM
#14968 |
XR 650R Rider
Oddometer: 45
because I'm a modern guy
10-19-2012, 08:48 AM
#14969 |
Oddometer: 609
Get them from the same place you get the shims; racetech. No real use in shopping around to save money, its not worth it.
10-19-2012, 08:58 AM
#14970 | |
Oddometer: 609
