Old 05-22-2011, 08:53 AM   #286
Power of Soul
Power of Soul's Avatar
Oddometer: 110
Originally Posted by 4power View Post
I think someone came up with a way to replace just the battery, probably find that on the cog forum. I wouldn't let that deter you from buying an otherwise fantastic bike.
3 year wanrantee. buy the Kaw good times protection 6 years.
TPS is a non issue.
2010 Kawasaki Concours 14 - 4 cyl
2006 Triumph Tiger - 3 cyl
1995 BMW R100GS PD Classic - 2 cyl
Power of Soul is offline   Reply With Quote
Old 05-22-2011, 11:05 AM   #287
Barry
Just Beastly
Barry's Avatar
Oddometer: 7,378
That's actually a good point. I got mine used still under the 3yr. OEM warranty.
I got an additional 3 yrs. through Kawasaki for about $300, and got my updated warranty paperwork in the mail like 4 days later. So I have 6 yrs. unlimited miles of warranty.
See www.zggtr.org and drill into the C14 Bike forum. The dealer is in Richmond, Va., and you can do all of it via email. I did.
Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday.
Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot.
Barry is offline   Reply With Quote
Old 05-22-2011, 11:45 AM   #288
MrFurious
MrFurious's Avatar
Oddometer: 704
Yes it can be done, but it's a hassle (break into the sensor w/o destroying it, unsolder the old battery and solder in a new one, they try to get the sensor back together w/o breaking it) and you still have to remove the wheels and pull the tires to get at it. I still think the ideal solution would be for Kawasaki to come up with a TPS that by design has a replaceable battery. That way you can just replace the batteries every time you get new tires put on (or every other time) and it only costs you $10-20 for the batteries.
Originally Posted by Power of Soul View Post
3 year warranty. buy the Kaw good times protection 6 years.
TPS is a non issue.
I was told by my dealer that the warranty (standard or extended) doesn't cover the TPS batteries as they're considered a standard wear item just like brake pads. Some folks have reported select dealers going to bat for their customers to get them replaced under warranty, but I'm not going to rely on a dealers good will for something this expensive and common.
I haven't totally ruled out the C14 and still prefer it over the FJR, but they'll both do what I want with relative ease. I just don't like the idea of paying that kind of money for something and knowing it has a flaw (how significant is debatable, but it's still a flaw IMO) and the manufacture isn't doing anything to rectify it. Why should they, they're making a killing on selling new sensors (so much so that they're currently back-ordered with no ETA for availability).
Jim B.
MrFurious is offline   Reply With Quote
Old 05-22-2011, 05:36 PM   #289
tjhess74
tjhess74's Avatar
Oddometer: 589
warranty WILL cover the tps system. I have had both of them replaced twice since 08. the first time i got lucky and needed tires at the same time. since the tires have to come off to get the sensors out, i had new tires put on for free!
if your dealer gives you a hard time, tell them you will call kaw because you know thats not true...then find another dealer.
the cog forum has gone through a recent change, but still lots of good info there. member 'fred h.' is the guy who replaced his batteries. just takes some good soldering skills is all.
i think the issue will be resolved soon as kaw is getting tired of replacing these things. it has been a supplier issue.
avatar pic: Tathum Gap, Trail of Tears, NC.
my goal is to see how many gallons of dead dinosaurs i can send through my bike.
2008 Kawasaki Concours 14
2007 Honda VFR800 RWB
tjhess74 is offline   Reply With Quote
Old 05-22-2011, 06:06 PM   #290
MrFurious
MrFurious's Avatar
Oddometer: 704
From what I've read over at http://zggtr.org (used to be the concours.org forum), it seems Kawasaki Corp is the one who has changed it's policy regarding covering the TPS under warranty due to all the problems they've been having with them. As a result the better dealers are just replacing them at their own expense to keep the customer happy, while other's just quote Kawasaki's new policy. Now they're supposedly back-ordered with no estimated ETA on availability which makes matters even worse.
Fortunately one of the guys over there turned me onto a viable solution. His recommendation, if you don't want to be bothered by the Low Battery warnings just replace the sensors with standard valve stems when they go bad. I figured this would generate it's own error message, but he assured me that with no signal being received from the sensors the display will just read "--" for tire pressure and temperature.
Jim B.
Old 05-23-2011, 12:16 PM   #291
tjhess74
tjhess74's Avatar
Oddometer: 589
if its that big of an issue, then kaw will be held to the warranty even more, not the other way around. the magnusson moss act clearly states the companys responsibility in that situation. mine latest set was replaced not too long ago, and kaw approved the warranty service. the problem is lazy dealers.
if indeed kaw is trying to opt out of there obligation, then it wont be long until alot of complaints with the feds should convince them to change thier mind. as i mentioned before, its not kawis fault, the manufacturer of the tps system (french company, iirc) will ultimately have to foot the bill.
Old 05-28-2011, 01:27 PM   #292
jasonc32amg
Hello Gubner
jasonc32amg's Avatar
Oddometer: 135
I picked up my '09 Red ABS last week and I am in deep lust with this bike. I had already sold my ZX10 and Nomad 1600 and was actually considering a big GSA but the dealer network is not that convenient. I also want to make some other investments so getting the Concours for half the price just made more sense.
The red color I find stunning. I'm still breaking it in but the bike clearly hauls and gives me most of the satisfaction from my prior ninjas with more comfort and those sweet hardbags. The biggest suprise is the handling; I can't believe how fine a 600lb pig can feel through an onramp.
12 1200 Tenere
13 Goldwing
jasonc32amg is offline   Reply With Quote
Old 05-28-2011, 01:28 PM   #293
jasonc32amg
Hello Gubner
Oddometer: 135
All shined up
12 1200 Tenere
13 Goldwing
Old 05-28-2011, 01:29 PM   #294
jasonc32amg
Hello Gubner
Oddometer: 135
Artsy fartsy
12 1200 Tenere
13 Goldwing
Old 05-28-2011, 01:37 PM   #295
dolomoto
Destroyer of Motorcycles
dolomoto's Avatar
Oddometer: 2,657
Originally Posted by MrFurious View Post
....snipped... but he assured me that with no signal being received from the sensors the display will just read "--" for tire pressure and temperature.
I can confirm that not having TPS installed does NOT generate any kind of error/light.
One was a casualty of a tire changer and the other went dead after nearly 50,000 miles.
I would like to have that info, but it's not a showstopper for me..I'm thrilled with the rest of the bike.
Hot, Nasty, Bad-Ass Speed tours: 2008,2010,2014
Things I've ate/cooked.
dolomoto is offline   Reply With Quote
Old 05-28-2011, 06:48 PM   #296
Behindbars
Let's Ride
Behindbars's Avatar
Oddometer: 698
Just picked it up today. 2011 Concours 14. First farkle is going to be a Kaoko throttle lock.
2009 KTM 950 Super Enduro
2015 KTM 300XC-W Street Legal
Behindbars is offline   Reply With Quote
Old 05-28-2011, 08:40 PM   #297
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 628
Man I love this bike...Maybe in the cards soon.
I have a buddy I ride with that has an 08 C14 and he has had the TPS sensor battery issue. I haven't read all 19 pages of this thread but forgive me if this has been mentioned here ( I know I said it somewhere before on ADVrider) but have you guys performed the " AIR PRESSURE " trick to get rid of the issue you're having? From what I gather from my riding buddy he was told by the dealer that in order to get rid of the TPS low battery issue ( not sure if it's a permanent fix) just inflate your tires to 70 Psi or slightly above and leave them for 24 hrs+ and it gets rid ( resets the sensor) of the stupid low battery warning thingy. He did it last june and it worked until he put his bike away just before winter. I haven't asked him if it came back but he never mentioned it...
Anyone else try it or have you tried it and it still comes back in the cold?
Thought I'd throw it out there, just in case!
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 05-29-2011, 08:12 PM   #298
MKorn
2whl Addict
MKorn's Avatar
Oddometer: 750
They sure are a hoot ... i like mine more and more everytime i ride it.
Always looking for a place to ride !
13 F800GS
09 Concours 14 ABS (sold)
02 Nighthawk 750 (sold)
06 DRz 400s
MKorn is offline   Reply With Quote
Old 05-30-2011, 05:01 AM   #299
Power of Soul
Oddometer: 110
70PSI!!!.
someone else chime in....Im guessing thats not good for the tire, maybe to pop the bead, but 24hrs? WTF.
Old 05-30-2011, 09:17 AM   #300
muguvian
lugrubious
muguvian's Avatar
Oddometer: 104
No, the sensors need to see above 50 psi to wake up but it is only necessary when they come from the factory.
muguvian is offline   Reply With Quote
Times are GMT -7.   It's 09:11 PM.
