Old 12-22-2012, 10:09 AM   #916
ABADV
ABADV's Avatar
Oddometer: 639
Quote: Mostly just curious and trying not to eyeball the ribeye sitting in the fridge, right next to the Fat Tire Winter Ale and the German Chocolate Cake, all conspiring to lower my HP rating.
"There was a time when a man was so convinced that the world was round that he was determined to prove it."
~ Ernest Holmes
ABADV is offline   Reply With Quote
Old 12-24-2012, 05:34 AM   #917
nunzo
nunzo
nunzo's Avatar
Oddometer: 306
Originally Posted by SimpleSimon View Post
No kidding....the stock can is a boat anchor. The CS One ships with a silencer and sounds fantastic once you start climbing the RPMs. I took it out today and it ran like my 954! Very impressed with this setup.
New to the C14 and really like the looks and sound of the V&H CS one. With the increased flow, do you need to remap(reflash) the ecu?
nunzo is online now   Reply With Quote
Old 12-24-2012, 06:18 AM   #918
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 705
Not with just a slip-on
IBA #33260
cablebandit is offline   Reply With Quote
Old 12-25-2012, 05:34 PM   #919
Newbusa
Newbusa's Avatar
Oddometer: 624
I have one on my C14 and it runs fine without the PC or reflash,but having said that i will be reflashing the ecu for more bottom end.
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 12-25-2012, 06:43 PM   #920
thetable
thetable's Avatar
Oddometer: 1,468
I have a AreaP on my otherwise stock '09, and the exhaust gas analyzer on the dyno says I'm still running rich.
thetable is online now   Reply With Quote
Old 12-25-2012, 08:13 PM   #921
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,399
I pulled the flies when I put on the CS One and added a Power Commander V. I ordered the Power Commander from fuelmoto and the guy specializes in supplying various maps for the CS14. I had him provide me one and it works great. Definately sounds like a mean machine with that CS One rapped out.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 01-03-2013, 11:32 AM   #922
Bryn
Leicester England
Bryn's Avatar
Oddometer: 346
Well, I mentioned that I'm very close to Hilltop motorycles in Earl Shilton, (UK) and Geoff there has had a steady stream of GS's and various other bikes through the door for one of his dyno/remap sessions....
www.hilltopmotorcycles.com is where to find him
So on his advice I paid a visit today... and the first job was to whip the tank off to get to the secondary butterflies . I was pleasantly surprised at how easy it was to actually remove the tank, rather than prop it up and have to work underneath it
Anyway, you've no doubt seen what secondary butterflies look like... so I didn't take any photo's until they were off and the bike was up on the dyno. We didn't bother with an initial dyno run pre-butterfly removal, just the set up afterwards.
First thing Geoff did was plug in his box of tricks and download a completely different map into the ECU.... and then he was able to tweak the map to sort my GTR.
Haven't a clue what he was doing, and as it was quite ... noisy ... in there couldn't ask
Anyway, after a couple of hours of tweaking, and the revelation that the baffle in my Remus Okami was rather strangling the thing... so out it came....and the result of the tweaking is shown in the Dyno graph below
The lower line is the Torque... and it is fairly constant at 90+ ftlb
the upper one is the BHP power curve, which is according to Geoff pretty good, and nice and linear....peaks at 148bhp (back wheel )
He told me the fuelling is now spot on...
So off I went for a little ride...... first impressions A LOT more responsive, excellent when overtaking, and just as smooth throughout the rev range.
I never wanted more power, but a consequence is an increase ( I believe standard is around 150 bhp at the crank)
The extra get up and go though is another matter... much nicer for quick overtakes..
All set now for a summer of Euro tours
Eagles may soar, but Weasels don't get sucked into jet engines....
Bryn is offline   Reply With Quote
Old 01-03-2013, 07:17 PM   #923
thetable
thetable's Avatar
Oddometer: 1,468
Solid gains there. My US spec model with ~60k miles, with just a slip on, dynoed at 137RWHP.
Old 01-05-2013, 04:12 PM   #924
ABADV
ABADV's Avatar
Oddometer: 639
I have the black one on order!
~ Ernest Holmes
Old 01-06-2013, 03:56 AM   #925
cognosticator
cognosticator's Avatar
Oddometer: 816
Here is mine from an '09 C14, flies out, PCv, Muzzy slip on K&N filter and the map from fuel moto. I took it to a dyno tuner and he told me he could not improve on the map
http://www.pbase.com/cognosticator/i...36327178/large
Jerry Holland
COG 4478
2011 Triumph Speed Triple
Man, you were haulin' ass the other day when I passed you
cognosticator is offline   Reply With Quote
Old 01-06-2013, 06:33 AM   #926
Bryn
Leicester England
Bryn's Avatar
Oddometer: 346
Looks very similar to mine. .....
Old 01-06-2013, 07:26 AM   #927
LSGiant
LSGiant's Avatar
Oddometer: 1,111
Does anybody have a before and after and then how many dollars they spent to get there?
Just wondering how many dollars per HP you guys are spending?
Or how many dollars for what looks like about a 10% improvement?
I am going to try to loose about 25 lbs and clean my saddle bags. :)
"Keep it rural, don't over water"
2010 Concours, 2000 DRZ400E
COG 7524, IBA 46513, GLMC 214
LSGiant is offline   Reply With Quote
Old 01-06-2013, 08:32 AM   #928
thetable
thetable's Avatar
Oddometer: 1,468
Go ahead, try to financially justify a motorcycle, let me know how that works out for you.
Old 01-06-2013, 08:56 AM   #929
motocopter
new place explorer
motocopter's Avatar
Oddometer: 996
Seems like LSGiant's questions are reasonable. Financially justifying anything is individually subjective.
- marc
Kawasaki Concours 1400 (an adventuring bike!)
My only ride report | IBA member | AMA member
motocopter is offline   Reply With Quote
Old 01-06-2013, 09:24 AM   #930
FireIdiot
Lost in translation
Oddometer: 82
That's like justifying a boat. Or my wife buying shoes..... lol. Good luck
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
FireIdiot is offline   Reply With Quote
Times are GMT -7.   It's 08:15 PM.
